Question about Cell Phones
How to qpair with my s5 phone? - Cell Phones
How to unlock a Samsung galaxy s5
this is what i have just found on the internet now remember its from the internet so its upto you if you try this.
Unlock Samsung Galaxy S5
  1. Insert the foreign SIM card into your Samsung Galaxy S5.
  2. Turn your handset off and back on again.
  3. On the dialpad on your phone, type in *#197328640#.
  4. Then select [1] UMTS > [1] Debug Screen > [8] Phone Control > [6] Network Lock > Options [3] Perso SHA256 OFF.
More items...
How to Unlock Galaxy S5 for Free? - Samsung Rumors
How to unlock Samsung galaxy s5 Google Search
Dec 23, 2016 | Samsung Cell Phones
How do I remove Samsung Galaxy S5 Active imei number from blacklist?
You will need to ask your cellphone provider. Normally blacklisted because it is stolen, or has been moved to another carrier when the previous carrier still owns the phone under an unexpired contract. This is the official line on this
You can check your IMEI number is Blacklisted in AT&T, Verizon, T-Mobile, Telus, Sprint...Blacklist IMEI is lost, stolen or ineligible (Bad, Barred, Blocked, Financed, Under Contract) mobile phone. Always check blacklist before buy, sell or get phone.
http://www.protectyourdata.ca/check-the-status-of-your-device-in-canada/
http://imei-number.com/imei-blacklist/
https://imeidata.net/blacklist/check
Unlock Bad IMEI Phone that Blacklisted Blocked or Stolen
Mar 04, 2016 | Samsung Cell Phones
How do I enter new contacts
How do I Create, Delete, Edit, and Manage the Contacts on ...
www.samsung.com > ... > More Cell Phone Providers
Samsung ElectronicsTouch the "Create new contact" button and select the location or account you want toadd the contact to. ... or Custom by touching the label field (by default, this will showMobile). Touch to add more phone number fields, or touch to delete a field. ... Openthe contact you want to edit, and then touch Edit at the top of the screen ...
Manage Contacts on Samsung Galaxy S5 - VisiHow
visihow.com/Manage_Contacts_on_Samsung_Galaxy_S5
5 Parts: Create a new contact on Samsung Galaxy S5 Edit Contacts on SamsungGalaxy S5 Delete Contacts on Samsung Galaxy S5 Questions and Answers Comments ... Using Contacts, you can save a person's name, address, cellphonenumber, home number ... On the Phone field, enter your contact's phone numbers.
[PDF]User Manual Manua - Verizon Wireless
Jan 08, 2016 | Samsung Cell Phones
Can a lg g pad 7.0 be qpaired with an iphone
Until iPhone 5s the Bluetooth profile was A2DP, meaning that it's only to pair with Bluetooth headsets. Apple said that in the new iPhone 6, new Bluetooth profile would be added.
Oct 18, 2014 | Cell Phones
How so you operate Samsung Galaxy S5
With all that the S5 can do, that is a pretty vague question. This thing can monitor your activity like a fitbit, it can check your heart rate, keep track of the food you eat. The camera is capable of very high definition as well as fancy effects, voice commands, the list goes on and on.... oh and the darn thing can even make phone calls! For the online manual and tips on how to use your S5 you can go here Samsung Galaxy S5 Manual User Guide and Instructions
Oct 13, 2014 | Samsung SGH-S5230 Cell Phone
I need a manual for samsung s 5
http://www.scribd.com/doc/215906940/Samsung-Galaxy-s5-Manual-SM-G900F
Jul 09, 2014 | Cell Phones
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
Cell Phones Logo
47 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
