Question about KitchenAid KFP600 Ultra Power 11 Cups Food Processor
How do I fix my Kitchenaid food processor? Motor hums but center shaft is stuck and won't turn.
The motor hums but the center shaft is stuck (can't be turned by hand). Took off the base but don't know what to do to get the shaft to spin again. Wonder if this is related to liquid overflowing from the bowl and making the shaft stick. How do I clean and lubricate the shaft so that it spins?
  • KitchenAid Master
  • 1,238 Answers
Hi Eric, you are going to have to get the motor out and yes it will be because of the spilled liquid fusing/rusting the motor armature shaft into the bronze bush. Those motors are very expensive so worth a go to save it. You will have to get the plastic sleeve off that shaft first before you can get the motor out. Removal will destroy the sleeve. I drill a hole through the top of the sleeve, side to side leaving about 5mm of meat at the top. I shackle a chain through it and attach it to my bench leg and then accelerate the whole motor unit away in a straight line. The shaft needs to be pointing at the attachment point on the bench or it can slip from your hands creating more grief. It will only take 1 to 3 pulls, 1st one doesn't work do it harder, same with second pull and harder for the 3rd. The chain needs to have welded links or the chain will break. That is far the easiest removal method I have found, other methods could involve hacksawing it down one side being careful not to damage the metal shaft or melting a line down 1 side to split it open with a soldering iron. Once that is off then remove base, detach motor wires from pcb and remove the screws under the plastic caps on top of the top housing. Then it will be working away with levers and a spanner on the shaft and CRC, sweat and time. If you strike trouble after that email me
screaming_skull@hotmail.com Cheers Ross
Posted on Apr 04, 2015
How do I remove my cracked support bearing on my Kitchenaid food processor 1333?+
Do you mean the bearing on the motor shaft within that circular plastic ring that moves up and down when moving the slicing thickness lever? If yes then a couple of screwdrivers under it one on each side to lever it up. At the same time it will force the black shaft sleeve up and off the motor shaft.
Oct 13, 2016 | KitchenAid Food Processors
KFP750 Food processor: motor seems to be frozen. Can it be repaired?
repairing these items are not cost effective
you can take it to an appliance repair shop but parts if available will be close to the cost of a new unit
Aug 24, 2016 | KitchenAid KFP750 Food Processor
My kitchenaid food processor won't work
Does the actuator push down far enough to catch the button at the bottom? I repaired one simply by adding a vinyl screw cover to the top of the button so it was tall enough to be reached by the actuator.
Dec 20, 2011 | KitchenAid Food Processors
How to remove motor shaft sleeve from KitchenAid Food Processor?
I just did this. I used a screwdriver and some needle-nose pliers to wedge and separate the shaft from the base. Once you've separated it by about 1/2 inch, it will come off easily. I simply used a mallet to install the new one.
Mar 06, 2010 | KitchenAid KFP750 Food Processor
Attachment stuck on shaft of food processor
put the mixing bowl up as much as possible. spray some wd40 into the groove between the attachement and the motor shaft. Wait for several minutes, then with a hammer and a piece of wood, give the bowl a good wack. With a few goes, it will gradually come off. I will be putting some butter inside the attachement from now on to keep it lubricated
Jan 11, 2010 | KitchenAid KFP750 Food Processor
My disc stem is stuck and will not come out.
Without careful use and care, there is a possibility that the disc stem can become fused with the motor shaft. If excess pressure is being applied to the slicing or shredding disc, this can cause immense friction and cause the plastic disc stem to "weld" onto the motor base itself.
I would suggest calling Kitchenaid Customer Service to see what options are available.
Their toll-free number is: 1-800-541-6390.
Jun 06, 2009 | KitchenAid KFP740 Food Processor
Makes humming sound motor will not spin
Did you replace the start capacitor or start relay first ? This is the most common problem & a hell of alot cheaper than a new motor. Did you replace the motor shaft seal (around the shaft on top of the unit ? if not you will be replacing the motor sooner than you need to because the acids from veggies eat these things up & is the main reason why the motors fail, next in line is overloading or forcing product.
Sep 15, 2008 | Robot Coupe Blixer BX6 Food Processor
KitchenAid KFP600 Ultra Power 11 Cups Food Processor Logo
370 people viewed this question
Top KitchenAid Food Processors Experts
Shehu Pro
Shehu Pro
Ted Maxwell
ray gallant
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
