Question about FreeMotion 350R Recumbent Bike
No pedal resistance during cycling constant low resistance only
Need replacement pedals for my resistant exercise bike
Rob, try any sporting goods that carry bicycles or bicycle repair shop for replacement pedals or order online.Check the attached links for replacement pedals. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
VP Exercise Bike Replacement Pedals 1 2 Stationary Bicycle Pedal Set with...
Parts for Life Fitness Bikes Pedals Battery Pedal Straps SPORTSMITH net
Exercise Bike Pedals eBay
Apr 12, 2016 | Cycling
Tip
Too Much Resistance on Stepmill
The first step in troubleshooting too much resistance or constant resistance begins with the lower board. You will want to first verify that the Field LED is lit on the lower board. As shown in the video, the Field LED is off initially, when the steps are engaged it lights up, after about 5 seconds the light should go off. If the Field LED stays lit during a workout or after a workout is completed, this is a sign that the console is faulty. There is constant power being supplied through the console keeping a full load and causing no change in resistance. If the Field LED remains lit, the console needs replaced.
Too Much Resistance Troubleshooting Video for Stairmaster Stepmill SM916
on Feb 11, 2015 | Stairmaster Stepmill 7000 Pt
How to fix Maytag dryer MED9600SQ0
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jan 26, 2016 | Maytag Dryers
Dryer not heating model #LEA30A amana commercial quality
You need to unplug it and locate the high and low limit switches. These sense the heated airflow temperature. If it gets too hot, the high limit switch kicks off until it cools back down. The low limit switch is used most if the time to cycle the heating element on and off during a normal cycle. I suspect the low limit sensor switch is "open" (has gone bad) and needs replacing. When completely cool, both switches are supposed to be in the On or closed circuit position. You can test them with a ohm meter, looking for low resistance similar to when the two ohm meter test leads are touched together. Again, make SURE the power is off at the breaker or the dryer is unplugged.
Feb 27, 2014 | Amana Dryers
My Proform 100 ZLX Exercycle is stuck in low/zero pedal resistance, and doesn't respond to console settings. Can this be economically fixed?
follow the steps, and fix it. God bless you
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
Dec 05, 2012 | Exercise & Fitness
Is Pilates different from weight training?
When lifting weights the resistant on the muscle remain constant rather than the increasing resistance during the progressive resistance with the Pilates machine.
Aug 30, 2012 | Allegro Exercise & Fitness
Kenmors 110 keep spining
The tranny should either spin or agitate not both
Nov 02, 2008 | Kenmore 24032\24036 Top Load Washer
Noise during wash and rinse cycles
Got a response from another site - the noise was due to the recirculation pump (situated low down at the back on the other side from the drain hose) which was working, but clogged with a nasty grey 'porridge' of limescale and powder residue in the pipes either side of it. Dismantled, cleaned out pipes and ran a wash cycle to clear any remaining crud out. Seems ok now and wash jet working, noise gone.
Mar 28, 2008 | Zanussi WJD1457W Front Load Washer / Dryer
FreeMotion 350R Recumbent Bike Logo
371 people viewed this question
Top FreeMotion Exercise & Fitness Experts
Howard
Howard
ray gallant
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
