Question about Vacuums
Vacuumcleaner starts and stops repeatedly
No hoses blocked clean filters
    Sergeant:
  • 250 Answers
Have you been pulling the plug out of the socket by the cord>\? If so, the wires near the plug may be broken. If this is the case, you need either an electrician or Repair Shop to fix it. If not, the problem is probably in the Vaccuum Cleaner itself.
Posted on Apr 03, 2015
  • bart alberts
    bart alberts Apr 03, 2015
    John thanks have wriggled and pushed and pulled plug no difference
  • bart alberts
    must have something to do with a censor
    New Friend:
  • 6 Answers
Check your plug,
Testimonial: "plug ok"
    Master:
  • Vacuums Master
  • 894 Answers
Hi, this is Jim with Crucial Vacuum,
First thing to check is your vacuums electrical cord. Unplug the vacuum and look for any rips in the cord. This usually happens when you unplug the vacuum by the cord itself and not the plug. If the cord is in tact there may be a clog disrupting the flow of air within.
You mentioned that your hose isn't blocked and your filters are cleaned so instead be sure to check your vacuums brush roll and dust bin. After every use you should empty your vacuums dust bin to help prevent clogs, which can cause your vacuum to stall.
The brush roll is the easiest part of your vacuum to clean. Be sure to rotate it manually to help unclog any hidden debris. If you notice hair wrapped around it, cut it with a razor. After clearing out your vacuum of any clogs should it still not work then the problem is most likely electrical. Try using another outlet to plug it into and see if the problem still occurs.
You can purchase a wide variety of replacement parts and accessories for your vacuum directly from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Posted on Apr 29, 2015
Where can I get a new hose for my vacuumcleaner. DURBAN
Hirsch near Gateway usually stocks spares for household machines, try them. perhaps you may phone them to check availability.
Feb 08, 2017 | Vacuums
Why does the motor stop after 5 min then start back up then stop? It does this repeatedly!
if its overheating it will cut out,check for blockages in the hoses and clean the filters
Apr 17, 2015 | Vacuums
I want to check out my Wertheim 3180 my daughter borrowed @ it has lost a lot of suction filters are clean
If the filters are clean, try removing the hose from unit whilst switched on, if the sound changes then you may well have a blocked hose or tube
Jan 12, 2015 | Vacuums
Lost all suction? what happened?
Give it a good cleaning, the hose or vents could be blocked up. Make sure you check the air filter (intake vent) if this is blocked it will stop a vacuum cold.
Mar 01, 2011 | Euro-Pro EuroPro Shark Navigator Vacuum
I have suction through the hose but not when using in the upright position. The problem started once I removed the filter to clean it.
there is a chance that the hose between the ground pick-up and the suction hose is clogged,, this happens when the filter is blocked and all the dirt and stuff only makes it part way up the hose and then settles at the bottom. run a wire coat hanger down the line to break up the blockage.
c...
Dec 30, 2010 | Hoover U5507900 Elite Rewind Bagless...
Shuts down after 10 min use
I would clean or replace filters on it check the hose to make sure it is not blocked . It sound like it is over heating and making the breaker kick off and after it cools down it resets this is caused by dirty filters or blocked hoses.
Feb 22, 2009 | Hoover U5753-900 WindTunnel Bagless...
My filters? need cleaning
most likely the hose is blocked, drop a coin down it to confirm. You are best to replace the filters, they are not very expensive; though they are not likely to be the cause of your nilfisk over heating
Sep 26, 2008 | Nilfisk Family Vac Bagged Canister Vacuum
Hoover eite rewind vacuum has blocked airflow, how do i fix?
Is there suction at the end of the hose, if not then the blockage is in the hose, unhook the hose and dig out the debris, if hose isn't blocked, then clean out the filters, if they get clogged, then air can;t flow thru them and you won't have suction. If you have suction at the end of the hose, then it is clogged down in the nozzle asm. there is an inlet by the brush roll and it comes up to where the hose plugs into. Clean the clog out.
Jan 03, 2008 | Hoover U5507900 Elite Rewind Bagless...
Vacuums Logo
208 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
