Question about Home
Need instruction on adjusting the RLS on my peerless cartridge.
The check valve that attaches to the cartridge was broken so I replaced it but, not the cartridge. Once finnished replacing all the parts I can't get the shower to turn off completely. I think I need to adjust the RLS but, not sure how to do it on the model I have. Can you help with this? Thank you
  • 8 Answers
SOURCE: shower leaking at showerhead when off, can't identify model
please email pics to kjfournier@verizon.net
Posted on Jan 08, 2009
SOURCE: Need instructions
Sterling has a video on their website that explained what I needed.
Posted on Aug 17, 2009
  • 349 Answers
SOURCE: adjusting the scauld guard on a shower mixer valve
Uue a 1/8" allen wrench to remove handle to access the dial that set's the mixture of water.Remember or mark where it is and remove and reinsert counter clockwise about a 1/4 turn to start to you reach desired temperature setting. Be careful not to set it at a hot enough setting to burn you.
Once dial in place slide handle on and turn on to check water temperature.
Posted on Aug 01, 2010
  • 81 Answers
SOURCE: need an instruction sheet for
This link will get you to the Danze illustrated parts list for the Sheridan single control tub and shower valve.
http://www.danze.com/products/pdfs/D510055_ip.pdf
Posted on Aug 08, 2010
ftw1952
  • 10319 Answers
SOURCE: Have a moen shower/tub model #82300 2300 series.
here is a web site with the original wooksheet that came with your faucet. All replacement parts are listed as well. Home Depot will stock your item if needed
http://homeappliance.manualsonline.com/manuals/mfg/moen/2300_series.html
Posted on Nov 07, 2010
We recently purchased a peerless #p188720. It came with no insructions and a flange valve cover piece missing. I attempted three ×'s to installe it any way. I thought 3'd's a charm,so i crossed my fingers...
Take it back to the store you bought it from. Get a new one. Otherwise, go to the Peerless web site and search for the instructions for your unit.
Jan 14, 2018 | Plumbing
Valve clearance
Valve clearance Google search your year make and model valve clearance. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Checking and adjusting valves
Engine Valve Adjustment Procedure The Right Way
Valve Clearance Adjustment
Valve clearance Google Search
Aug 10, 2016 | Cars & Trucks
I have a single handle shower faucet, turn all the way and you get only hot water.... It has been dripping over the last few weeks when off, hot water. now it's a steady flow. How do I adjust...
hi there:) your problem is caused by the cartridge inside the valve body. could be one of 3 things...1)the cartridge is damaged 2)hard water build up 3)foreign matter. it is not to difficult to replace it yourself: first turn off the water then find the set screw, which holds the handle in place, usually located at the base of the handle and remove it. (look closely/carefully cause it's hiding) then remove the escutcheon ring and the trim sleeve to expose the "bonnet" (lock ring) and remove it. (ritey titey lefty loosey) now you can remove the cartridge and inspect it for debris/damage. if you need a new one just take it w/you to any plumbing supply including home depot and/or lowes and they will help you find it. here is the installation/owners manual from peerless: http://peerless-faucet.com/customer-support/find-repair-parts/documentation/P8760.html hope this helps but if you need anything else just ask:)
Jul 30, 2011 | Peerless Industries Peerless& Single...
Shower drips - seems to be increasing
Need to replace your internal seals inside the shower valves.
Go to Home Depot, Lowes,etc. and make sure you take your model number and maker of your shower and they can get you the parts to repair the valves to stop your leak.
If you do not repair it soon, the water leaking by will cut your metal seat and it will never stop dripping, you will have to replace the valve and it is a MAJOR job.
This is a free answer, Please rate me
Oct 16, 2010 | Peerless Industries Peerless& Single...
Just had a contractor give me an entire new bathroom. The Peerless Single Handle Tub And Shower Faucet will only go from 90 deg down on the cold side to straight up. it want go to the hot side. What is the...
if u have the paperwork for the unit--in it will explain how to adjust the anti scold settings single handle units are shipped in cold setting u have to adjust the hot -- remove handle and on shaft will see blue and red clips adjust the red till hot water is to ur liking replace handle
May 18, 2010 | Peerless Industries Peerless& Single...
Peerless faucet P99196 dripping; tried everything. Only made it drip more. How to fix?
If you have replaced boots and springs and or cartridges. Did you replace with after market parts or OEM. If after market parts were used use OEM. Hope this helps.
Apr 11, 2010 | Delta Faucet DELTA/PEERLESS FAUCET CO....
I have a two-handle Delta faucet that drips.  With both handles turned completely to off, the faucet drips at a about 1 drip every 15 seconds
sounds like you need to replace the valve seats. if you shut the water off and remove the handles you will see the valves. you have to remove them and under that you should see these little black things. they come out but have springs under them so be careful. the black things are the valve seats. i would start by replacing them
Dec 15, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Instruction manuals
http://www.peerless-faucet.com/customersupport/requestliterature.html
Click on the link above and you can request the literature you are requesting. Peerless is made by Delta.
Mar 18, 2009 | Peerless Industries Peerless& Single...
I have a peerless tub diverter and I need to replace it because it leaks. Where can I find a replacement unit?
the kit to rebuild the peerless diverter is very common. take the cartridge to any hardware store and ask the plumbing clerk to assist you in getting the correct kit. good luck
Jan 19, 2009 | Peerless Industries Peerless& Single...
Shower temperature too hot
Shower valves that have anti-scald features are renowned for this problem. Usually it is caused by not being used regularly. It can be repaired usually without replacing the valve, but you will have to dissemble it, clean, and use some plumbers grease to reassemble it. It should work fine after this. If it still does not work you will need to replace the cartridge.
Dec 10, 2008 | Peerless Industries Peerless& Single...
Home Logo
75 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
