TD-W8961ND ddff
    Top Expert:
  • 10,875 Answers
Wwwwwhhhaaatttt
Posted on Apr 03, 2015
Error 49 in HP LaserJet 100 color mfp m175a
HP printer error 49:
Error [b][i][u]49[/u][/i][/b] is [b]'Firmware Error'[/b].
[i]Firmware[/i] is the built-in software on the printer's electronics.
In layman's language, your printer's brain has become confused.
Here are several steps you can try, to hopefully clear the error:
[table]
[tr]
[th]01:[/th]
[th]Cancel Print Job[/th]
[th][b]Cancel[/b] via printer menu [i]and[/i] via Windows' Control Panel, to make sure.[/th]
[/tr]
[tr]
02:[/td]
Turn Printer Off[/td]
Power it [b]OFF[/b], then [b]ON[/b] again.[/td]
[/tr]
[tr]
03:[/td]
tESTING..[/td]
Try reprinting, to [b]test[/b] if [b]error[/b] has [b]gone[/b].[/td]
[/tr]
[tr]
04:[/td]
Try Different App[/td]
In case the [i]application[/i] is [b]corrupt[/b] or non-compatible, try printing from [i]other software program[/i].[/td]
[/tr]
[tr]
05:[/td]
Try Different File[/td]
In case the [i]file[/i] is [b]corrupt[/b] or non-compatible, go back to your [i]original application[/i] and try printing another file.[/td]
[/tr]
[tr]
06:[/td]
Upgrade Driver[/td]
If you find that [i]only certain files or apps cause problems[/i], [b]upgrade[/b] the printer driver to the latest version.[/td]
[/tr]
[tr]
07:[/td]
Upgrade Firmware[/td]
If the driver upgrade does not give you any joy, a [b]firmware upgrade[/b] may be necessary.[/td]
[/tr]
[tr]
08:[/td]
Refresh Entire System[/td]
Failing all of the above, an entire refresh / reboot may be necessary:[/td]
[/tr]
[tr]
09:[/td]
Freshen Up[/td]
Turn printer [b]OFF[/b]. Pull all printer-connected cables [b]OUT[/b]. In Win Control Panel / Devices, [b]DELETE[/b] Print-Queue. Switch [b]OFF[/b] computer. [b]REBOOT[/b] computer and printer. [b]RECONNECT[/b] cables. Try [b]PRINT[/b] again.[/td]
[/tr]
[tr]
10:[/td]
Clean Computer Registry[/td]
In addition to the 'Freshen Up' steps, a [b]registry cleaner[/b] application can clear software junk or old settings that may be causing a conflict. [b]360 Amigo Speedup[/b] does the job well.[/td]
[/tr]
[tr]
11:[/td]
Remove EIO Devices[/td]
Certain hard-drives, cards, etc are EIO * devices. Identify then [b]REMOVE[/b] all of these, and see if problem vanishes.[/td]
[/tr]
[tr]
12:[/td]
Re-install EIO Devices[/td]
Plug in the EIO devices again, one at a time, rebooting and testing printer each time [u]until one causes the error[/u].
[/tr]
[tr]
13:[/td]
Still failing, all EIO devices removed?[/td]
The memory cards (DIMMS), aka '[b]D[/b]ual-[b]I[/b]nline-[b]M[/b]emory-[b]M[/b]odules' of the printer itself may be damaged or corrupt.
[/tr]
[tr]
14:[/td]
Remove Printer DIMMS[/td]
Turn printer [b]OFF[/b]. Remove all DIMMS (memory and 3rd party if any) from the printer. DO NOT remove the FIRMWARE DIMM. Printer [i]will[/i] [u][b]CEASE[/b] to function[/u]![/td]
[/tr]
[tr]
15:[/td]
Try DIMMless analysis[/td]
Turn printer [b]ON[/b]. If error 49 remains, [b]RENEW[/b] the [b]FIRMWARE DIMM[/b]. If this doesn't work, [b]RENEW[/b] the [b]formatter module[/b]. May require [i]qualified personell[/i].[/td]
[/tr]
[tr]
16:[/td]
Test for faulty DIMM[/td]
Turn printer [b]OFF.[/b] Re-insert each DIMM, one-by-one, switching [b]ON[/b] then testing error each time, then [b]OFF[/b] for next one.[/td]
[/tr]
[tr]
17:[/td]
Faulty DIMM found - NOW what??[/td]
If one of the installed DIMMS re-creates the error, [b]RENEW[/b] the DIMM with a new one.[/td]
[/tr]
[tr]
18:[/td]
Hookup everthing again[/td]
Once all tests have been done, [b]restore[/b] all printer / computer [b]cables[/b] to the way they were before, for normal operation.[/td]
[/tr]
[tr]
[/td]
* EIO[/td]
No, NOT vowels of the alphabet. In this case it's an acronym for [b]E[/b]lectronic [b]I[/b]nput [b]O[/b]utput device[/td]
[/tr]
[/table]
In fact, the above steps can apply to [i]any[/i] printer, as well as many other computer peripherals.
Causes of the error can vary, including but not limited to:
electronic failure, power surges, strong EM fields, static, corruption, etc.
First, if you don't have one already, suggest you invest in a socket or multiplug outlet with a built-in '[b]Surge-Arrestor[/b]'.
A good, updated AV is also a necessity to safeguard against cyber-attacks (see [i]corruption[/i] above).
Jul 10, 2018 | HP Office Equipment & Supplies
What's your question?how do i fix error 360 on my ricoh mp6501sp
• Black TD sensor disconnected
• Harness between TD sensor and PCU defective
• Defective TD sensor, replace the PCU
Note: The TD sensor cannot be replaced independently. The PCU must be replaced if the TD sensor is defective.
Feb 23, 2016 | Ricoh Office Equipment & Supplies
TD-W8901G issue after upgrade to V6
I'm an electrical and electronic engineer (Iranian and Persian native speaker) that had the same problem,exactly my modem went to death (just power LED is ON) after upgrading from version 3 to 6 and I have precisely similar TP-LINK TD-8901G ADSL2+ router but I found a great "step by step" tutorial in a Russian website(in their forum) which contributed me significantly;
I hope it might help you too.
iman28aban@gmail.com
+989358817467
http://www.lan23.ru/forum/showthread.php?t=6859&page=1
Dec 27, 2012 | Computers & Internet
What does the error C390 on an aficio 1013 photocopier mean
TD sensor error test value abnormal the TD sensor output voltage is less than 0.5v or more than 5.0v after 10 consecutive times during copying the possible cause willbe TD sensor defective,TD sensor not connected or connector damaged ,poor connection between the TD sensor and the I/o board (IOB),I/O board (IOB)defective ,toner supply defective
May 20, 2010 | Ricoh Aficio 1013F Copier
I need a user manual
i provide you user manual for NX-542 in portable TV,
Product MPN
MPN NX542
Key Features
TV Type   Portable Screen Size   13 inch Display Type Color
Other Features
Remote Control   With Remote Control AV Inputs Composite 1 Sleep Timer   With Sleep Timer Antenna Capability   External
Physical Characteristics
Power Source DC Adapter, AC Adapter Type Portable Display Type Color Screen Size   13 inch Depth 14.75 in. Height 14 in. Width 14.75 in.
Miscellaneous
UPC 840005000977 Product ID 77523163
i hope this is helpful to you.
Thanks,
Dec 04, 2009 | Naxa Electronics NX-542 13 in. Portable TV
Ricoh 6513 Service Code 370
HI there I hope it is the colour machine version so below is the description from the service manual.
Thanks J
SC370 Abnormal TD
sensor
information (K)
- Timing -
When communicating with
TD sensors, during
printing process, or
process control self-check
- Condition -
TD sensor output exceeds
4.5V or drops below 0.5V.
• Poor connection
• Dirty sensor surface
• Toner density is out of
range
• Not enough developer
3-007-001 1. Make sure the TD sensor is properly
connected.
2. Check if the connectors on the TD sensor
interface board 1 and the slip ring and the
TD sensor interface board 2 are properly
connected.
3. Clean the surface of the TD sensor.
4. Replace the TD sensor. If it becomes OK
after the sensor is replaced, replace the
developer of color related to the problem.
If the problem is related to the toner density
(too low or high), find the cause and fix it.
Jan 23, 2008 | Ricoh 6513 Copier
Computers & Internet Logo
408 people viewed this question
David Payne
David Payne
