Question about Dryers
Cloths spinner wont rotate under load
When clothes are put into the spinner the spinner will not rotate and the motor hums
    Habit-Forming:
  • 131 Answers
EITHER bad motor are broken belt ,if u. Don't know how to fix dryer call for service
Posted on Apr 03, 2015
Won`t start to dry second load of clothes after the first. dryer humms?
If hum is coming from motor and it won't restart until it cools down, it usually means the motor is going bad and overheating. This could also be caused by excessive lint around motor area or blocked vent but usually the motor itself.
Mar 22, 2015 | LG Dryers
DRYER MAKES HUMMING NOISE BUT WONT START
Sounds like the capacitor on the motor is faulty
Mar 21, 2014 | Kenmore Series 70 80 90 PN281798 Dryer...
Replaced the clutch and motor coupler a month ago. Ran great. Washed tennis shoes. Came in to remove clothes, didn't spin. Wont agitate or spin, i could hear the motor running. Just replaced the motor...
Check for a failed capacitor under the control panel It is a start/run capacitor that the motor needs to start running. The motor will hum and if left will eventually burn out.
Aug 17, 2013 | Kenmore 23822 Top Load Washer
When you turn on the dryer you can hear the motor hum but the drum wont turn ...i checked the belt and it is not broken
When you checked the belt, did you check to see if the motor would turn by hand, if not the motor is locked down and that's why you hear the hum noise, it still has power and still trying to rotate, but from being locked down it has no option but to strain and hum. If that's not it, check around the drum for a sock or small piece of clothing, it can wedge between drum and dryer frame and cause the tub not to rotate just like if the motor were locked down.
Jan 06, 2010 | Washing Machines
Wont spin
motor coupling is the problem. You have two one for the motor and one for the transmission one of these are broke.It does agitate doesn't it?
Sep 03, 2009 | GE WBSE2090A Top Load Washer
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
KitchenAid Clothes Washer, Fills and then Hums, Blew Breaker
no, need to empty water theres enough room to pull to side, and yesathought it spins by hand i like to see it spin under load. its possible you have a bad capacitor
Jan 31, 2009 | Washing Machines
Whirlpool Ultimate care ii Dryer wont tumble
If your dryer doesn't tumble, check these:
Belt,
Motor,
Door switch.
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
Remove the belt,
Check for obstructions in the blower fan housing,
Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
Go here to see a diagram for your model:
one of two types. "H" or "J"
http://www.repairclinic.com/0079.asp#DiagramH
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Dryer wont spin
If dryer does not spin it is usually a problem with the belt or the motor. Check also door switch.
See also following indications from Repairclinic:
It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Aug 27, 2008 | Dryers
Simpson Ezi Loader 5.5kg 45S558E does not complete a cycle when loaded with clothes. Will complete a cycle when no clothes placed in drum.
I'd say that belt might be loose a bit so it slips under load. That would explain why the motor can rotate empty basket but not the loaded (heavy) basket.
Apr 20, 2008 | Washing Machines
Dryers Logo
59 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
