Question about NEC Computers & Internet
I just got a refurbished computer off of Amazon. When I hooked it up, it will turn on but go straight to an amber blinking light. How can I fix this?
  • 1 more comment
  • Tim Ehm Apr 03, 2015
    Hi Tammy Shaver, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    -Did the monitor come with the computer? or, did you already have the monitor?
    -Where is this blinking light? on the monitor screen? On the monitor, near the On/Off switch? or on the computer?
    -Is this a Windows-based computer? or, an Apple?
  • Tammy Shaver
    Tammy Shaver Apr 03, 2015
    No amber light on the monitor screen. Sometimes it will show a small box stating something about D-Sub, and other times it goes straight to the amber light blinking
  • William Alequin Apr 03, 2015
    OK, I saw that it's a desktop, this is the kind of info we need when you post the question so we can help you better. Disconnect the power cable, take out the Ram, clean the memory Ram with a pencil eraser, do not install the memory yet nor connect the power cable, press and hold the power button for about a minute. Now connect everything back and check if it works. This usually because of a memory Ram that could be faulty.
    Genius:
  • 2,568 Answers
Make sure the battery is fully charged. connect the charger then try again , If it loads now the battery is more likely not charged. If it will not load up get in touch with Amazon.
Posted on Apr 03, 2015
Testimonial: "It is a desktop, not a laptop"
  • 928 Answers
Amber light from the case? If that is the case, and I'm just thinking outloud here, it could be the battery or the HDD light. For as long as the PC turns on, everything should be OK.
Testimonial: "No, it is an amber light on the monitor. It will start to load, and I either get a blank screen or one that has a small window real quick saying something about the D-Sub"
  • Stan Ford Apr 03, 2015
    return to Amazon
How do I fix my Dell computer that keeps blinking amber color light and does not turn on?
You are going to get a range of opinions on this one. Some suggest a new power supply and others more invasivel repairs involving removal of the front panel and soldering!
http://www.tomshardware.com/answers/id-2277673/dell-wont-boot-amber-blinking-light.html
Apr 21, 2015 | Dell OptiPlex Computers & Internet
Optiplex 755 blinking amber light, simple solution, I'm no IT professional.
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.A power supply or system board failure has occurred. Try to isolate the problem by removing or disconnecting all cards, i.e. video, sound cards and disconnecting CD/DVD and hard drives.
Oct 20, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
Blinking amber power button light on Optiplex 990
It seems you have a problem with your Processor regulator that is why your computer sending an amber message.
This problem always happens to Dell Optiplex mostly and there is no solution for this except replacing your Motherboard.
To verify this problem unplug yellow (2 yellow and 2 black cables) cables near the processor and then try to turn it on when you see the fan processor can run smoothly and the power light getting green that is the sign that your processor regulator having some sort of problem.
Hope this will answer your problem
Apr 30, 2012 | Dell OptiPlex 990 SFF 1 x Core i7 2600 34...
Dell precision workstation t7500 won't boot. Showing solid amber.
You may have to reinstall operating system by buying a Dell cd(from amazon) that reinstalls the operating system you had on the workstation.
Dec 07, 2011 | Dell Precision T7500 Computer Workstation ...
Blinking amber light on the on/off button.
No light : The computer is turned off (S4, S5, or mechanical OFF)
Steady green :The computer is in a normal operating state
Blinking green : The computer is in a power-saving state (S1 or S3)
Blinking or solid amber See "Power Problems"
check power
Sep 06, 2011 | Dell Dimension 4300 PC Desktop
Computer won't start. PSU good. Amber light on mobo. What gives?
It is probabley the power supply is bad the amber light should be green Get yourself another power supply and see if that don't fix your problem
Sep 01, 2011 | Dell Dimension 4300S (Refurbished)...
My GX520 was shut down as usual last night...I turned on this morning and I get nothing...just a little yellow/amber light blinking where it is normally green....help
Here is the info straight from Dell. looks like you have an internal power issue. You will most likely need to contact Dell directly for assistance, they are pretty good about giving support even if the system is no longer covered under warranty.
If the power light is blinking amber -
The computer is receiving electrical power, but an internal power problem might exist.
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
Dec 28, 2010 | Dell OptiPlex GX520 PC Desktop
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Computers & Internet Logo
88 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
