Question about Garden
I have a fault code f486 can you tell me what it is
How do I decipher the fault code on a amana tandem 7300 front load warshing machine
what is the fault code? I can tell you if you tell us the code!
Apr 27, 2016 | Amana Washing Machines
Fault code is P0183
this is the fuel temperature sensor a circuit high input reading
Jun 28, 2012 | 2005 Kia Sedona
What does f 22 code mean
if you could tell me the make & model I could tell you what the code fault is f22 applys to 8 different makes of machine and they all mean different faults
Dec 02, 2011 | Washing Machines
My car has 12,000 miles and my engine light came on?
Hello! The Check Engine Light (CEL) is the vehicle's Electronic Control Unit (ECU) telling you it has found and stored a fault...These faults are handled by On Board Diagnostics Version II (OBDII)...Take your MPV to an auto parts store and they will decode the fault as a courtesy...Typical faults begin with a letter "P" followed by four digits (P0402 as an example)...That code tells a technician what area or circuit is at fault...When you have the code, send a comment and I'll FixYa...................Guru.....saailer
Nov 14, 2010 | 2000 Mazda MPV
What does the yellow light that looks like an engine block represent when it comes on?
hi this is the engine management system light, this is telling you that you have a fault and has been recorded in the ECU, you will either have to take it to a garage, or main dealer, to get the codes read to tell you what the fault is, or you can purchase a cheap diagnostic code reader from the net, but to be honest if you do not know what the code faults are, i would suggest you take it to a garage so they can tell you what the fault is..hope this helps
Aug 08, 2010 | 2005 Mitsubishi Outlander
Trouble Codes
1. VW VAG type 5 digit fault code 19497 = EOBD type P3041 fault code:
Fault location = CAN data bus, instrumentation - implausible Engine Coolant Temperature (ECT) signal
Probable cause = Wiring, matching resistor in Engine Control Module (ECM)
2. VW VAG type 5 digit fault code 18032 = EOBD type P1624 fault code:
Fault location = Malfunction Indicator Lamp (MIL) - request signal active
Probable cause = Trouble code(s) stored in other system(s)
3. VW VAG type 5 digit fault code 01039:
Fault location = Coolant Temperature Sensor (G2)
Probable cause = Open or Short to Plus, Short to Ground - Intermittent
4. VW VAG type 5 digit fault code 01304:
Fault location = Radio
Probable cause = No Communication
5. EOBD type P0761 fault code:
Fault location = Shift Solenoid C
Probable cause = Performance or Stuck OFF
Feb 03, 2010 | 2002 Audi A4
Where is "check engine" sensor?
lol
thats a new one
there is no check engine sensor.
theres lots of different sensors take tell a computer to set a code and turn on that light.
ask autozone to check the codes for you for free.
its a free service they offer.
the codes will tell you whats wrong
probably an o2 sensor.
ask them if they have it in stock.
keep me posted
thank you
jm
Jul 29, 2009 | 2004 Ford Freestar
Engine light,how you tell if its o2 cens.evac/gas cap?filler neck,or cat.converters
By a cheap OBD2 (95 or newer) scanner (Kragen auto) and retrieve the fault code(s), if it is a 1995 or newer many of the basic codes are common to all cars, reference this code to a repair manual at your local libary or go on line and type in the fault code, many times an explation and common parts that fail to set the code will be posted, remember the code tells what system is at fault, it can be wiring or a hard part like an O2/Cat sensor or the power train control module to name a few.
Jul 17, 2008 | Subaru Forester Cars & Trucks
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
