When activated, the thermostat stays on for about 45 sec. and then kicks out indicating a gfi problem . . . this seems far too sensitive . . . can I override this in some manner?? Thanks, Wayne
    New Friend:
    Problem Solver:
  • 19 Answers
If this is a window unit check max amperage on window unit should be on tag than check breaker size make sure breaker is big enough for unit and is there anything else on this circuit that could be tripping gfi also.
if not to difficult take unit to different room and see if works on that circuit. If it does either breaker to small or to many things on that circuit
if trips breaker in other room to there is something wrong with unit check fan motor or compressor
Posted on Apr 03, 2015
    Master:
  • 459 Answers
You can replace the wall outlet with a GFI type and cut the ac cord end off and install a basic 3 prong for 120 volt system. AC unit controls don't like ground faults and should be corrected. The cord gfi may be going out.
Pump does not turn on. there is power to the board but nothing lights up
No power supply to "board" possibly 24vac, or an air type of control, so that the air supply pump is not active. Possibly the power supply to the pump and control board has "popped" the
circuit breaker. Check, the circuit breaker. There may also be a GFI Ground Fault Indicator that acts like a circuit breaker but is more sensitive, especially near water. Look at the receptacle that the motor plugs into. GFI has a test button and a reset button.
Mar 26, 2015 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Ge 50amp gfci trips, worked great before I bought it
Hi hondo,
When an electric motor kicks on there is an in rush current called FLA(full load amps), it is usually about 125% of rated circuit amperage. Try a 2 pole 60 amp gfci circuit breaker and see if that solves your issue. Going up to this amp breaker will not be a fire hazard or cause any anomalies.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Oct 19, 2008 | Spa Parts Plus GFCI, Circuit Breaker, 40...
When I plug the monitor it won't stay on. Why?
1. CRT or LCD?
2. Do you have an image of any kind for that 45 sec.?
When it drops out after 45 sec, do you have any strange behavior as you look at the screen (colors, blinking, lines, squiggles, noises, smells)?
3. When failing, does the power drop out (ON light goes OFF)?
How long do you need to wait until you can turn it ON again?
4. What is the status of your screen saver/power saver? 45 sec seems pretty short but it's still possible.
5. What does the manufacturer's website have to say about this problem? What do other users have to say when you search for your model?
I know these are just more questions but your question is too generic to offer specific comments that might be more useful.
Apr 12, 2013 | Computers & Internet
I removed the Ground Fault Interrupter plug from my new GE window air conditioner to fit it in my camper, i put a normal AC plug on it now the thermostat stays on all the time. David
First, the GFI was placed in the system for a reason. On ANY part of an HVAC system, if it has a safety, you NEVER remove it. If you place a regular plug on it, I would replace the breaker that feeds that circuit with a GFI breaker. This will still give you the protection it needs without compromising safety at all. As far as your thermostat, does it have batteries in it or is it ran off your power input. If you have no power to your system and your thermostat was off before, but now you removed the GFI and the thermostat stays on, I would think you have a battery back up that will lock out the thermostat on a ground fault.
Sep 28, 2010 | Heating & Cooling
GE Simon 3 Installation Transformer vs. GFI...Need Help!!!
I have been installing alarm systems for over 30 years. A GFI circuit's main purpose is to kick the breaker to prevent electrical shock. You will most likely find these in kitchens, bathrooms, outdoors and basements. The reason most alarm manufacturers do not want you plugging into one of these is they are sensitive to humidity and are more suseptical to cutting off electric power to the outlet. Therefore they are less reliable in providing power to your alarm system. Over the years there have been situations where I had no other choice but to plug into a GFI circuit. Doing this will not harm the system but it will increse your chances of losing power to the system.
Nov 24, 2009 | GE Security Simon 3 Wireless Home Security...
Kicks off imediately ground faught on karcher pressure washer
This is a serious situation. It means there is a short circuit somewhere. You need to have a certified technician or electronics person look into it.
Aug 21, 2009 | Karcher 1750 psi Electric Pressure Washer
Duo-Therm air conditioner/thermostat problems
The solution was to purchase and install a new thermostat. Works perfectly now.
Jun 01, 2009 | Dometic Rooftop RV Air Conditioner
Kenmore 417.40412700 tripping GFI circuit breaker
Unfortunatly washing machines are too sensitive for GFI outlet.only way to fix is too take it off the GFI.
Mar 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Fedders Window AC
You may have thermostat problems. If the blower and compresssor kicks on, that indicates their ok. If you have a two wire thermostat, you can tie those wires together to see if the unit will operate. BE SURE TO DISCONNECT POWER.
Aug 16, 2007 | Fedders X Chassis A6X08F2A Air Conditioner
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
