Question about Insignia Audio Players & Recorders
What kind of wirewound resistor is used on the crosssover board for the amplifier?
Insignia SW-51A home theater amplified subwoofer UL tag 80 NA audio/video apparatus E210860
  • 38 Answers
SOURCE: Home theater
Brave and hands on!I like that from a user,but you should pay a professional to connect it for you for your first time.Since you have paying him to do this,you should learn from him so next time you know what is the right way and avoid problems.
Joe
Posted on Feb 04, 2008
SOURCE: remote control codes for insignia stereo
Try the Orion or Slyvania codes. Orion worked for me.
Posted on May 10, 2008
SOURCE: No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
I have a high definition Polaroid tv which I bought in 2007. I have it connected to Dish tv. It worked fine at first. Now when I use the Dish tv remote, the television won't power up. The red light, which appears when the television is off turns blue when I attempt to turn the tv on, but the screen stays black. Why won't the television come on anymore?
Posted on Nov 02, 2008
  • 398 Answers
SOURCE: How do I connect a subwoofer to an amplifier marantz pm-68
double up the speaker and then use the two extra screw to hook sub and center
Posted on Feb 27, 2009
  • 3 Answers
SOURCE: No Audio with home theater system
have you tried infra red link?
Posted on May 07, 2009
Kenwood sw-35ht Replace with a kicker sub
I suppose you could, but you are talking about a driver (speaker) that was not designed for that cabinet size and amplifier used in the Kenwood, There are differences in speaker design besides power rating and impedance.
Jun 10, 2014 | Kenwood SW-38HT Subwoofer
Protect subwoofer showing on power amplifier
Check your owner's manual for a Factory Reset, or Return to Default. Try that first. If it still doesn't work, try disconnecting the sub completely, and see it that resolves the issue.
Feb 03, 2014 | Sony MUTEKI HTDDW1600 Theater System
I was given a Jamo sub 1810, but have no instruction manual. I'm trying to hook up to my Pioneer HTP-2500 home theater system. What would be the correct way? Also if you could help me with the setup,...
Find it here...
http://www.jamo.com/na-en/support/owners-manuals/
http://www.jamo.com/images/download/779.aspx
The Jamo is self-amplified and accepts Line Level input ONLY.
The HTP-2500 receiver drives a subwoofer directly with SPEAKER LEVEL output only and does not have a volume-controlled output for driving externally-amplified devices.
May 21, 2011 | Jamo SUB 1810 Subwoofer
I need to power-cycle the board, but how?
This speaker system is described as consisting of "passive" satellite speakers with an "active" subwoofer. Passive means they require an external amplifier to work - and conversely active means there is a built in amplifier. To "power cycle the board" simply disconnect the power cord for a couple minutes (allows capacitors in the circuit to discharge) and plug back in. That's it.
Sep 15, 2010 | Jamo A 102 HCS 5 System
CAN I POWER UL15 AND XT115 [WITH CROSSOVER] WITH 1 AMP
You need 1 channel of amplifier per stack. Assuming the ul 15 is a full range box, and the XT115 is a subwoofer. But be careful with your Ohm ratings for the speakers and your power ratings of your amps. You want the proper Ohm load on the amplifier for maximum power. And use proper speaker cable, with correct wiring.
Wire the to the sub first, and then jump to the ul 15.
Feb 20, 2010 | Peavey Pv 2600 Power Amplifier
I have a subwoofer with standard speaker wire connection, how to I attach to a receiver with a subwoofer cable?
The Subwoofer is Likely Passive....meaning no amplifier is within the enclosure itself....the incompatible connectors mean you cannot connect the subwoofer itself to your surround sound system.
look for a Suitable stand-alone (1 Channel) Amplifer with sufficent power.....connect the RCA Imputs (subwoofer cable) to the Recievers RCA subwoofer output....then connect the amplifier's output to the the wire going into the subwoofer enclosure....if there is a plastic connector simply cut it off and strip the wires down a sufficent lenght....then secure the wires to the output of the amplifier.
if you do this make sure you know the ohm rating of the subwoofer and the minimum ohm rating of the amplifier your using.
Nov 24, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Speaker wire for subwoofer
Usually, a subwoofer will have its own built-in power amplifier. Thus, it will be designed to plug into a standard RCA jack (the type used for DVD players, etc). rather than having wires to connect to a speaker terminal block. Look for a jack on the back of the receiver called "Subwoofer", or simply "SW". If your subwoofer has 2 single wires, it WON'T work with your reveiver's subwoofer output, as this output only carries a line-level signal and is not amplified. You would need a separate power amplifier for this type of SW. If your SW speaker has a DVD-type plug, it should work fine with the receiver's SW output jack.
Jan 02, 2009 | JVC RX-554V Receiver
Connection system
hi,
connect satelite speakers to the amplifier and connect signal cable (RC pin) to the woofer from amplifer ie subwoofer out from amp. ok na.
-kanny
kanny-sounds.blogspot.com
Dec 15, 2008 | JBL 5.1-Channel Home Theater Speaker...
55 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
