How do I program the channels to my Phillips PC0125 C321
I have a Phillips SRU3006WM/17 remote I need the
just press your setup button untill the red light stays on then hit TV or what ever your trying to program then keep clicking channel up until the channel changes and once it changes hit enter or setup button
Jan 08, 2010 | Philips Televison & Video
I cannot auto program tv
Only a universal remote of Philips has the 2 buttons to use the autoprogram,all other won't work.
Aug 29, 2009 | Televison & Video
Dvd player doesnt have channels and i want to program my remote
Check your sentence?
You will have to have a learning remote, which even the cheap Phillips are. To do that you need the original or access to one in a store. Be warned, any mistake in programming a button can only be undone by erasing the whole set of buttons you have programmed for that selector or picking a different button if any are left. I have a 3 or 5 (stopped using it) selector Magnavox Phillips and filled it with buttons for a DVD+R and it is frustrating when you mess up near the end and have to start over as all buttons were used. -Ken
Aug 18, 2009 | Philips 5-Device Universal Learning Remote...
Can't find dvd channel on my tv...
hi does your dvd player have scart lead connection if yes select av1 or ext1 thanks
shaun
Mar 06, 2017 | Zenith SY2569X TV
Hotel TV remote
for phillips tvs that come out of a hotel try this code with RCA universal remote. the big remote not a small remote. 319753 followed immediately by the mute button. this will pull up the tv setup menu.
Jul 31, 2008 | Philips Magnavox REM-350 Remote Control
Phillips tv 32pf77320A/37
problem was with the FIOS Box not the phillips TV. The box appeared to be working but would not respond to channel changes and is being replaced.
Jul 12, 2008 | Philips TV Tuner Video Capture PCI Card -...
I need the codes for a universal phillips remote controler
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 14, 2008 | Televison & Video
Need code for phillips remote
Hope this helps :)
Jun 09, 2008 | Philips Televison & Video
Phillips pm3s lost code book:
Hope this helps :)
May 31, 2008 | Philips PM3S Remote Control
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
