Question about Car Audio & Video
Stereo stopped working will not turn back on - Car Audio & Video
  • 1,606 Answers
Many car stereos use an anti-theft pass-code scheme. If the stereo is removed from the vehicle, lock-off is triggered by the loss of battery power to the stereo, and the only way to get it to turn on is to enter the pass-code on the front panel buttons. If you had to disconnect the battery, or it went completely dead on you, that's your problem. Check the manual for your stereo for details.
Note: some stereos requiring entering the pass-code before disconnecting the battery - for those who might have such systems, save yourself some grief and check your user's manual ASAP so you are prepared.
Another possibility is a shorted speaker amplifier has blown the radio fuse. Check the speaker wiring for damaged insulation before you install the repaired or replaced stereo. A competent electronic technician can generally check the amplifier modules or transistors for shorts and replace them as needed. Be sure to ask which speaker output is bad so you know which one needs a wiring check.
Posted on Apr 03, 2015
2010. Why does it keep failing?
Kia Rio Maintenance & Repair Questions - Page 4 - CarGurus
www.cargurus.com > Questions > Kia > Rio
CarGurusGet fast answers to your Kia Rio Maintenance & Repair questions from experts in the ... the stereo stopped working,all of the fuses in the car and in the engine .... ljsiler asked a 2010 Kia Rio LX Maintenance & Repair question 8 months ago ...
Sep 30, 2015 | Kia Rio Cars & Trucks
How do you reset the system.
To reset the component Hi-Fi stereo system to factory settings.
  1. On the stereo system, on DECK B , press and hold the STOP button.
  2. While holding the STOP button, press and hold the TUNER ENTER button.
  3. While holding the STOP button and TUNER ENTER button, press the POWER button.
  4. Unplug the power cord from the electrical wall outlet.
  5. Plug the power cord back into the electrical wall outlet.
  6. Turn on the stereo system.
Sep 30, 2014 | Sony STR-DA3000ES Receiver
Car stereo just randomly stop work doesnt allow me to turn up volume or change stations or set it to aux none of the buttons work but the stereos turns on.. what could it be???
Well knowing what stereo you have would help, but mine, the volume knob doubles as the settings knob if you press it. In some newer systems like mine, you should find a "back" button (small arrow) like on a cell phone. Trying using that to escape the settings mode that you might have activated.
May 28, 2014 | Car Audio & Video
Car stereo problems
Do you have an amp? Remote wire might have come loose and the amp is telling the speakers to stop playing. Or, you might just have a setting problem, like it\'s turned on to just the rear and the rear is set to sub. Try dinking with the settings and running flat eq....(+/- 0 on bass treb and mid). If not, then there is a master plug in the back of the system: unplug and plug back in. If none of this works, trace the speaker wires back and make sure they are connected and not melting somewhere hot.
Jun 17, 2013 | Car Audio & Video
Car stereo not working
somthings wrong with your ignition wire run your stereos power on a toogle switch
Jan 08, 2010 | Kenwood KDC-MP205 CD Player
The stereo just stopped working.
If you remove the pcm there is a small 10a fuse in the back, to remove the pcm remove both centre console side panels and turn the 4 (2 each side) allen screws 1/4 turn, also dont forget a small 6 or 7 mm screw on nearside of pcm that needs to be loosened. otherwise try a software reset by disconnecting the battery with ignition on and reconnecting after a couple of mins. hope this helps
Aug 18, 2009 | 2005 Porsche Boxster
Stereo stopped working along with speedometer
It's probably not a fuse. It sounds like your vehicle speed sensor went bad in the transmission. The reason your radio stopped working was because your radio is probably equipped with speed sensitive volume and it requires a speed signal to work.
Apr 10, 2009 | 2001 Ford Taurus
Shelf stereo turns off by itself and stops working all together.
how loud u cranking it? cause i've tested my stereo to its max...and it suddenly dies...reason: its juss like a small scale car stereo system...the built in AMP cant handle the out-put..
Feb 04, 2008 | Philips FW930R Shelf System
Clarion DXZ655MP Speakers worked then stopped...
sounds like the ohm load of your speakers is incorrect and overloaded the amp,....check all your specs, i.e. max, min ohm load on stereo, and speakers,...this stuff is important and must be within the range allowed or stuff like your experiencing happens,.....it's happened to me before,.....fried my amp because i had house speakers in my van, was great for about 3 loud days,....good luck, cracklin joe,.......
Sep 26, 2007 | Clarion DXZ655MP CD Player
Car Audio & Video Logo
136 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
