Question about LG Washing Machines
I put a large blanket to wash at wool cycle at Time Save and started , took water and after a small spin stops , takes more water and spins I saw that the drum was 1/3 rd full . what is wrong ,
  • 954 Answers
I agree. A large blanket full of water is very heavy and can put undue stress on your washing machine. I would take it out and go to a laundry mat where they have industrial machines designed to handle such a heavy load so that I would save my own washing machine.
Posted on Apr 03, 2015
    Genius:
  • LG Master
  • 1,585 Answers
Probly over weight
  • Kanwarjit Dhillon
    Kanwarjit Dhillon Apr 03, 2015
    Probably the case , I used this machine after a gap of 5 yrs and was making all sorts of noises which eventually decreased .
Kenmore Elite Model 44836
Check that the feet are level to the floor as this may cause the vibration. Also set the machine to wool mode this then knows what material you are putting in the machine then should cycle to that material.
Thanks J
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Washing Machine Leaking At top During Spin Cycle
Is it possible that the water level is too high. This can be caused by the sensor that controls the amount of water. The control knob that says small low medium large does it work if you put our small setting is the water stopped early like it is supposed to. If the water level is too high during spin cycle it is possible to run up and over the side. Let me know Ed
Nov 28, 2011 | Whirlpool Washing Machines
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Washing machine wount spin
Lasat time I saw a similar problem it turned out the motor had a low insulation reading.Check the motors insulation and that should put you on the right track
Sep 22, 2009 | Washing Machines
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag heavy duty top loading washing machine stopped and won't restart
remove console screws behind timer is lid switch if you have a volt/ohm meter with washer disconnected ckd switch operation also there is a fuse on same assembly ck it
Aug 17, 2008 | Washing Machines
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Damaging clothes
How long is the gentle cycle?. I prefer to make my own delicate cycle. I let the machine fill, agitate about 1 min. then turn off and let soak about 15 - 20 min. Make the machine pump out and start spin very briefly. stop machine. let fill up again and repeat to rinse. Don't let agitate for more than 3 or 4 min total wash and rinse don't let spin completely.
May 06, 2008 | Frigidaire GLTR1670A Front Load Washer
Frigidaire FTF530FS Front Load washer
Take off the lower panel. Inspect the shocks too see if they are damaged. If they are OK turn the wash basket by hand if the knock is heard then most likely you have a broken wash basket.
Jan 13, 2008 | Frigidaire FTF530FS Front Load Washer
Washing Machines Logo
64 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
