My phillips flat panel model #42PFL6704D/F7 won't turn on with remote or power button. It turned off while watching tv
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
Try a hard reset to this set first. If it do not help you, its SMPS circuit should be checked. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Apr 03, 2015
  • 77 Answers
Probably the power board capacitors if you are confident remove the back and look for blown capacitors on power board they ate round cylinder shape with silver tops usually are they black colouration or bulging replace the with exact same parts and it should be fine. it would be the one the power cable is attached to if you are competent you can do for a few pounds /dollars good luck
SOURCE: Phillips 42FD9954 plasma will not turn ON
I have a Phillips 42FD9954/17S and every time I try to turn it on I also get the power red light blinking and sometimes it will try to turn on with a bunch of clicking noises and it will be green for a while then turn red. What I do and its very weird but works, put a blow dryer on hot and blow it under the tv on the side of the power button for about 10 minutes and it will turn on. I took it apart and there is a heat sink that if i put the blow dryer directly onto it on heat it turns on in less than a minute. Can someone tell me how I can fix this heat sink? I cant take it off. I want to put some thermal compound to see if that works. Give it a try I promise it will work. The Red Light has to be on put the heat on it and then press the power button, if you hear it clicking and green then back to red you are almost there. Keep putting heat on it and it will turn on.
Posted on Mar 31, 2009
  • 92 Answers
SOURCE: what size screw for holes on back of set
go to this size to figure out the screw size. http://www.tvwallmountguide.net/
Posted on Jun 18, 2009
SOURCE: my rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Posted on Aug 25, 2009
  • 17 Answers
SOURCE: My plasma TV won't turn on (Phillips model
these tv have a comon short problem w the video &audi bord shield if you remove the cap only it usally fixes this
Posted on May 13, 2010
Ecollier2012
  • 3459 Answers
SOURCE: phillips tv model 47pfl5603d/f7 power
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Posted on Jun 10, 2011
Unable to turn on tv at the base of the tv or the remote
check make sure you have power
check the power strip is working
check electrical and power cords
unplug the tv from the wall and remove the plug from the tv
inspect the wire or plug connectors and plug areas
check the batteries for the remote, if not sure replace them all
go to fuse panel reset breaker, trip and reset breaker
than reconnect everything and try turning tv on
see if you can find reset button, push to reset
find out if the tv has a fuse, check the fuse
after all that a new tv/ see if it worth repairing most of the time it cheaper to buy new one or a referbushed unit.
Sep 17, 2015 | Philips Televison & Video
Why my 42pfl5907 tv will not turn on?
Plug it in.
Check your internal fuses.
Then check the power cord for continuity.
Nov 01, 2014 | Philips 42PFL5907/F7 42 Class Led Lcd...
What code for ge universal remote 24991 operates phillips dvp 3982/f7?
Note: most remotes allow you to find the code by manually turning the TV (or other device) on first, then press the appropriate button (cable, DVD, surround, etc) then setting the the remote in the "program" mode, then keep pushing the "off/power" button until the TV (or other device) turns off, at that point the code is set.
Aug 15, 2014 | GE 24991 3-device Remote remote Controls /...
Why does my Philips 40" flat screen tv shut off 15 seconds after I turn it on?
The symptom you describe suggests power supply failure. It is still working but fading fast
Mar 24, 2013 | Philips 40pfl3706/f7 Lcd Flat Panel Tv
Philips tv will not turn off
So it won't turn off via remote or side buttons?
Nov 13, 2012 | Philips Televison & Video
Phillips
The main power regulator board is faulty. It should be replaced.
Aug 13, 2012 | Televison & Video
Phillips 27PT5445/37 TV won't turn on
Sounds like a power supply issue possibly bad caps. You can get replacement power supplies from www.tvrepairworld.com just hit the contact us button on their website to leave a email with your model number if you dont see your model listed.
Aug 05, 2012 | Televison & Video
I have a 42" LCD
Some of these TV were equipped with very short connections from the infared board to the small signal board. Remove some of the shrink tubing from the wires of the IR cable to relieve stress on the individual wires. Trim the other end of the cable as well. We are talking about one half to three quarters of an inch.If this does not help you will need to order a new IR cable. Please show this info to an authorized Philips dealer and have them do this for you. Thanks for asking and show a few hands of support.
Feb 19, 2011 | Philips 42PFL5332D 42 in. LCD Television
New phillips tv model 42pfl7403d/f7. remote quit working. Also dtv remote not working either.
then i would say the remote diode in the tv has malfunctioned. you will have to have it tested and replaced.
Aug 03, 2010 | Philips Televison & Video
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
