Question about Hampton Bay Dryers
CAN NOT GET THE CODE FORMY HAMPTON BAY FAN TO WORK,IT HAS A 4 DIP AND I HAVE TRIED EVERYTHING JUST NEED CODE TO SET PLEASE
    Genius:
  • Hampton Bay Master
  • 1,617 Answers
You have to match the code to the receiver code.
Posted on Apr 03, 2015
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
I purchased hampton bay 4 pack solar led landscape lights 237 002 - 2 lights work, 2 don't, I put in new batteries but still can't get them to work - they have been outside for a month. They worked last...
Sun burns out the photocell in lights. Hampton Bay uses cheap components in their Fans and Lighting all made in China for a fraction of what you paid. Dont waste time calling gpwarranty.com they dont care.
Best option..buy a good set and dont buy them from Home Depot, Hampton Bays primary retailer, sort of voting with your wallet.
Sep 23, 2009 | Hampton Bay 24002 Ceiling Fan
Cannot set remote code for fan/light(dip switch)
The remote dip switch setting must match the fan receiver dip switches. Set them both to 2 on
Jul 04, 2009 | Hampton Bay 52 In. White Redington...
I bought a hampton bay ceiling fan model uc7083t but i didn't
hi there i can help. There is a "dip switch" on nearly all fan remote units, much like a garage door opener has. To keep all the fans in your home from operating at one time, each fan needs a seperate "code". To use your other remote, you need to locate the receiver unit in the fan, usually in the "canopy". This is the bowl looking piece against the ceiling. then note the "code" which is the position of the switches. For instance, most have a block with 4 switches, and if the first is "on", and the remaining are "off", that is it's set code. This "code" can be changed to any combination of "on , off" that you like. BUT, you must also open the remote control and set it's switch to the exact same "Code", or order of "on off" as your Fan receiver. (Usually the control "Dip switch" is in the battery compartment.
Jun 19, 2009 | Hampton Bay 24002 Ceiling Fan
Need code for remote to ceiling fan
There is no set code from the factory; usually all the dip switches are in the same direction. In order to find the code, you will have to take the fan down, pull the remote out far enough to observe the dip switches, and then set them the same way on the remote.
May 19, 2009 | Hampton Bay 13087 70450 Carousel II...
Hampton Bay Windward II dip switches
The CODE SWITCH RECEIVER should be located in the CANOPY (the bracket hanger). !!WARNING!! YOU ARE ENTERING A HIGH VOLTAGE ELECTRICAL ZONE!!
It will be tucked in among the electrical wiring and inside the hanger bracket.
Simply pull it out and you will see the CODE SWITCHES. There are 16 CODE combinations that can be used. Both the REMOTE and the RECEIVER MUST be set with the SAME CODE.
Good luck. :)
Apr 19, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Remote control
most common is a flat remote battery, even strait out of the box,
the DIP should match the DIP on the fanlight
Sep 08, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
I need the default code for a hampton bay fan
I checked the hampton bay site and unfortunately whatever dip switch setting on the fan is, the remote needs to be matched to it. better get out the ladder!
Sep 11, 2007 | Hampton Bay 48670 Flemish Pewter Finish...
Dryers Logo
78 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
