Question about Viking Kitchen Ranges
Surface indicator light does not lit up - Viking Kitchen Ranges
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 35 Answers
Http://www.vikingrange.com/MEDIA_CustomProductCatalog/m3640063_F20586A.pdf
Posted on Apr 03, 2015
Surface unit light stays lit. even when burners are turned off
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on heatman101
Aug 04, 2011 | Kenmore Kitchen Ranges
My craftsman garage door opener will not close. It travels a short distance then reverses, lights flash. All indications are that this is a sensor problem, yet both sensors are lit brightly. The door will...
If the door does not close but only if you hold the button down then yes it probably is a sensor problem. Holding it in bypasses the sensors. Make sure the lights are on(sunlight will make it look like they are lit). Also make sure the surface it is attached to s secure. Watch the sensor as you press the button to make sure it does not shift. If it is not the sensor(s) or the wiring to them, it could also be in the logic board. I would start with the sensors. They are sold in pairs. You can find replacement parts at searspartsdirect.com. Thanks BB
Sep 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
How many lights should be on my westell model327w?
The Westell has several lights on the front that have various meanings
Power = When lit, this light indicates there's power to the router. It should be solid green.
Ethernet = When lit, this light indicates that the modem is communicating with your computer. This will be on only if you're using the Ethernet cable to connect the modem to your computer
Wireless = When lit, this light indicates that the wireless function of the Actiontec is working. This will only be lit if you're using the wireless function.
DSL = When lit, this light indicates the modem is speaking to the central office (phone company). When working, the light should be solid green.
Internet = When blinking, this light indicates that you're receiving information i.e., you're able to browse from site to site. This light will be blinking as you're receiving information.
Sep 16, 2010 | Computers & Internet
Wireless light not lit
The wireless functionality of the router is no longer working. The light is always turned on on all wireless routers
regards
Sandeep
Nov 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Whirlpool Range Stove Top Indicator Light Stays Lit
Hi, You will need to change the burner switch as well. It shorted out when the element went bad.
Please let me know if I can assist you with part # or anything else.
Vic
May 30, 2009 | Kitchen Ranges
Hot surface light indicator stays lit
The hot surface light is controlled by a part attached to the element called a limiter. For your model, the limiter is not available as a seperate item. The element/limiter assembly has to be replaced as a single unit. The top assembly, elements and limiters are all fragile parts.
If you are making this repair yourself, make sure the range is disconnected from it's power source prior to service.
Apr 27, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
The hot surface indicator light remains ON all the time.
Your hot surface indicator light might have a short that causes it to stay on all of the time. If you can, try unplugging it for a little while and plugging it back up. If the light is still on, you have a short. You can still use the stove, but the light staying on will not be any help to you.
Oct 22, 2008 | Frigidaire FEF366EC 30" Freestanding...
When heater fails to start
if the flue is warm that would indicate that the flames lit for a short while. furnaces sometimes have limit switches that shut down the gas if the heat exchanger gets too hot. I would verify you have clean filters. and all registars open fully.
If the flames are not lighting verify gas valve is recieving the 24vlts. to open.
Also check ignition system it will be a piolet light or hot surface ignitor. you should be able to see both without much trouble. hs ignitor should get bright cherry red.
Sep 24, 2008 | Heating & Cooling
Blue light will not stay lit
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset
boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator
light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The
indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Jun 30, 2008 | Motorola Mobility H700 Wireless Headset
Kitchen Ranges Logo
62 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
paulcarew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
