Question about Biostar P4VMA-M Motherboard
No power I bought this board new it wont spin any fans power up or make any noise. I returned it and was told it tested good I have a 3.4 prescott 2 gigs of ram a 128 asus video card and a turtle beach sound card. I do have fairly cheap ram any chance it dosent like it?
1st get a 450 or500 w power supply 2nd cpu intel pentium 4/celeron D or celeron,cpu fsb 533/800 and also support Intel hyper threding technology. Driver you shuld download online go to biostar .good luck.
Posted on Sep 28, 2008
  • 87 Answers
1st of all change ur power supply may be it is coz of it coz if da fan is not spining then i am sure there wud be sum problem of power supply n as u said it was returned n tested good by the owner then i am sure u mite have some problem in power suppy n i prescribe use some good quality of ram like kingston if ur a gaming freak!
Posted on Nov 18, 2007
Error code 11 flashes shown on the power LED
HI:
Sorry for your luck. If you just bought it I would definitely return it. Here are the codes for your set.
12G Models :
X24 / C2 / U2 / S2 / G20 / G25 / VT20 / VT25
Code:
BLINKS PROBLEM CHECK POINT
2 blinks 15v SOS D-Board / P-Board
3 blinks 3.3v SOS D-Board
4 blinks Power SOS P-Board
5 blinks 5v SOS D-Board
6 blinks Driver SOS 1 SC-Board / D-SC FPC
SC Energy Recovery Circuit
D-SC FPC DET
7 blinks Driver SOS 2 SU-Board / SD-Board
SU/SD Connector DET
SU/SD Scan and Logic IC
8 blinks Driver SOS 3 SS-Board / SS2-Board
SS FPC Detect
SS Energy Recovery Circuit
9 blinks Discharge Control SOS D-Board
10 blinks Sub 5V SOS / Sub 3.3v SOS A-Board / SC-Board / SS-Board / P-Board
Sub 9V SOS / Tuner Power SOS
MIHO 3.3 SOS / LED 8v SOS
11 blinks Fan SOS A-Board / Fan
12 blinks Sound SOS A-Board / Speaker
Good luck
Apr 20, 2011 | Televison & Video
Error code 11 flashes model TCP50VT25
12G Models :
Code:
D-SC FPC DET
SU/SD Connector DET
SS FPC Detect
Good luck
Apr 20, 2011 | Panasonic 50 in. Plasma TV
I have a an35n ultra v1.1 motherboard I power on my tower,it does power on but it wont post I dont see anything wrong with cap's cpu was tested and checks out Power supply is good Tryed a new video card...
Hello Phenom, Hi.... to properly run/test a motherboard, you need to make sure this parts are good with no doubt functioning. 1. the power supply, 2. Memory, 3. keyboard, 4. Processor with FAN 5. PC speaker(built on-board or the thumb speaker) and 6. monitor How to test. First remove all motherboard connections. Now reconnect the following. 1. make sure that the power supply 20/24 pin is connected properly to the motherboard (and please test this power supply before making connections. To test independently short green wire to ground and plug the unit. you should see the fan spin) 2. make sure that the 4 pin 12volt power connector is also plug in nice and tight. 3. clean the memory slot using a clean paint brush and the module (DDR/2) terminals (the contacts) using an eraser, 4. connect the keyboard, 5. make sure there is a PC speaker connected. 6. connect the power switch of the front panel, 7. Connect a monitor on the VGA port 8. Power on the PC. 8. Look at the keyboard lights 3 LED momentarily. num lock + caps lock + scroll lock and after several seconds 1 LED light, num lock only. If you reach this part you should also hear a beep. then the POST will appear. If you don't reach this part, start again from the top. do this several times. Still no response? you motherboard is bad.
Jan 07, 2011 | Shuttle AN35N Motherboard
My conputer ( desktop ) turns on but no image on the monitor it shows a message no sync. i already tested the monitor and it works fine.
there are several things that could be causing this issue. 1) could be the power supply has died. It may get some fan spin but never power the motherboard. This would cause what you are seeing. 2) could be the motherboard. If the video is built into the mother board it either could be the adapter or the motherboard itself. If you get no beeps or drive spin noises it is probably either the power supply or motherboard. ( I would try to test the power supply first, very often that is all the problem is, just happen to my dad's computer) 3) if you get some beeps and lights it could be just the video card. If you have one on the mother board try plugging another into one of the slots.
Those would be my first 3 guesses, good luck
Nov 29, 2010 | Computers & Internet
Infocus LP130, Bulb fires then goes out
there is a problem with the power to the front fan from the main board. there are 3 wires going to the fans: one power, one return, and one signal. if the main board reads no signal from the fan's speed, it'll shut down. check the power going to the fans and the signal. you may need to replace the main board.
Mar 03, 2010 | InFocus Office Equipment & Supplies
Laptop not booting up
Ok it's probably not the battery. Try taking the battery out and run it just by the cord, if it works, than return the battery and get a genuine HP one. If it is a genuine one,save it.If fails i'ts the power board or even worse, the motherboard. Now it could be a CPU overheat, look up on google "taking apart HP zT1260". and clean fan and mainboard. if that fails, it's the video card, again look and take apart and see if the graphics card is removable, if it is replace it, if not. You got ripped off and he was bluffing :( Trust me I'm a computer IT worker. Try returning it, if that fails, tell people that he shouldn't be a repuatable seller. Good Luck
Nov 29, 2008 | HP Computers & Internet
Compaq armada m700 wont power up all the way
Sounds like you may have a problem with the internal power supply box? I am not sure but that may be at least something for you to have checked out. If the fan is not spinning this is usually a sign this may be what the problem is. GOOD LUCK!
May 13, 2008 | Compaq Armada M700 Notebook
Power supply fan is makeing a lot of noise
1) Unplug the power cord and give the fan a good cleaning
with a soft paint brush and a vacuum cleaner.
i.e. Let the fans spin up by the vacuum and than bring
the brush against it.
2) If this fails, it's time to replace the fan:
a) Upgrade or replace the power supply enclosure with more
power/higher quality.
This is usually a good investment anyway.
b) Replace the fan only as described below:
Open up the computer (remove sides)
Unplug all the power supply harnesses from
the mother board, drives and chassis fans.
Unscrew and remove the complete power supply
enclosure at back of computer (ie top of the tower)
Vacuum it out as much as possible.
Disassemble the power supply enclosure by removing
more screws and removing the metal cover.
Unplug the fan from the circuit board, remove it
and take it to a computer store/ builder.
buy another fan just like it
reverse the process to put your computer back together.
1) A new power supply should cost $65 to $120
depending on power and quality. The bigger the better.
But make sure it fits mechanically into the existing chassis
and that the AT generation matches ***********-board.
2) A new fan should cost $15 to $25. Makes sure it runs on
the same voltage, and that it is physically compatible.
Martin
Apr 24, 2008 | Computers & Internet
New Computer Wont Boot!
when you say "the fan makes a noise like its getting ready to spin", which fan...power supply's or cpu? if you answer power supply, then the POWER OK signal is not returning to power supply and it then quickly shuts down to prevent further damage. double check a firm connection to mother board. If you answer CPU, then it becomes far more complicated. Try re-seating the memory chips.
Jun 05, 2007 | Systemax Venture PC Desktop
Biostar P4VMA-M Motherboard Logo
206 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
