Question about Air Tools & Compressors
Compressor won't fire up ......tried hitting reset button which will normally get it going but now has died.....any ideas on how to start?
    Master:
  • 507 Answers
Remove the splice box from the motor and check for power on the lines coming in connecting to the motor. If there is power, the motor is bad. You can try removing the motor end bell and bypass the overload button but this eliminates the motor protection, just for testing is ok, then get a replacement overload if you can find one.
Posted on Apr 03, 2015
Window Air Conditioner will not turn on, I hit the reset button and it turn on for two seconds and then it went off.
You may have a bad compressor or a faulty start relay that will overheat the clixon when compressor does not start normally. The clixon on overloads under those circumstances and shuts down the power.
Nov 02, 2016 | Heating & Cooling
My kindle won't charge. I have tried 3 different chargers.
Lillian, May have to try hard reset or possibly repair charge port to get battery to start charging. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Kindle won charge
Kindle Wont Start or Charge How to Reset Kindle
Troubleshooting Kindle Fire That Won Charge
Kindle Fire Won Charge Fix
May 22, 2016 | Tablets & eReaders
Fully charged. Why doesn't it turn on?
Ruby, try pressing and holding on button or you will have to reset.
Reset Kindle Fire When it Won Turn on or Charge
My kindle won turn on
My kindle won turn on Is it the battery Kindle Fire HD
Amazon Kindle Won Charge Quick Fixes
Mar 12, 2016 | Amazon Kindle Fire HD
My Avanti CF142 chest freezer won't work on normal setting. It will work on Quick freeze so I know the compressor is good. Any ideas why it won't work on normal setting. The green light won&
Sounds like your control switch is going bad. Good thing you have the quick freeze button. You may want to go ahead and replace it. The whole thing will go out soon. This is something you can replace yourself.
Jan 27, 2013 | Avanti 5.3 cu. ft. / 150 liter Chest...
My a/c unit keeps tripping when i plug it in. i've tried to hit the reset button on the plug but doesnt do anything. i unplug and plug back into outlet and it trips again. what can i do to fix it?
There is nothing you can do to fix it... the compressor is trying to start and cannot so it trips the plug. The plug trips to protect the house circuit from being overloaded and causing a fire.
Getting the compressor replaced is cost prohibitive, it is cheaper to buy a new unit.
heatman101
Aug 06, 2011 | Frigidaire FAH106N1 Wall/Window Air...
My ASus eee pc is in a constant loop. It starts up with start windows in safe mode safe mode with command prompt or start windows normally... After I select start windows normally it's in a loop and starts...
Ok-Go to Safe Mode-any-click on start menu-run:msconfig-hit enter-click on restore option-choose date-go! If you can't do that, on boot you machine should tell you what other option you have-like"push ESC button to aces setup" or something like that. Hit that button and go to RESTORE function.Good luck and Happy Holidays!
Dec 27, 2010 | ASUS Eee PC 901 XP Notebook
Air compressor won't stay running even with resetting
How quickly does it shut off? Is it reaching the turn off psi? or is it immediate.
If it is immediate then it is probably a power supply issue.
Air compressors are power hogs. For instance, a compressor may work fine on an outlet using the supplied power cord, but plug it into an extension cord that is insufficient for it and a repeat of your problem will occur. If you use an extension cord make sure it is made just for this kind of application. Also, if possible, give the compressor a dedicated circuit.
Another problem might be your unloader valve not working correctly. This reliefs the pressure inside the pump after the motor has stopped. it would sound like the pump is working extra hard at start-up.
May 19, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
VW Passat TDI turns but won't start.
99 vw passat 1.9tdi was driving sound but just died just turns but wont fire up
Apr 18, 2009 | Volkswagen Passat Cars & Trucks
Air Tools & Compressors Logo
130 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
