Question about Continental 1995 Lincoln Radiator - 95 Lincoln Radiator dpi 1729
95 linclon continental
No gauges no lights on the dash
    Habit-Forming:
    New Friend:
  • 11 Answers
Have you checked the fuses for the park lights because they usually work hand in hand with the cluster lights.The fuses for the ignition usually works for the instrumentation gauges on the cluster. You can also check the connection of the ignition wire from the battery that gets damaged by battery acid that seeps in the the wiring and corrodes the wire inside the insulation and you can see it because the outer insulation is still in tact..
Posted on Apr 03, 2015
I need the color code for speakers in a 1994 Linclon Continental.
LF: + ORG/LT GRN, - LT BLU/WHT
RF: + WHT/LT GRN, - DK GRN/ORG
LR: + GRY/LT BLU, - PNK/LT BLU
RR: + ORG/RED, - DK GRN/ORG
Mar 06, 2017 | Lincoln Continental Cars & Trucks
95 bmw 525i no dash lights no tach no tremp gauge and fuel gauge pegged way past full
Why was the battery missing to begin with? I would start by checking all fuses under dash and Central hub. Check for burned in-line fuses,if any, coming off of battery cables.
Jan 16, 2014 | Cars & Trucks
Need a wiring diagram for the entertianment system for a 1997 Linclon Continental
Use a multi meter to determine the two feeds of 12v and the earth ,then use a small 9v battery to check the speaker wires to determine which wirecolours are for what .its easier than you think to determine the wiring .
Jan 31, 2012 | 1997 Lincoln Continental
What's VDM where is located on 1996 linclon continental
well that stands for vehicle dynamic module and it is locate on the back of the back seat in the trunk. it is the square box that is about in the middle and is mounted underneath the rear deck. so when you get the trim panel off and expose all the wires look up where the speakers are mounted. might be just a little closer to the drivers side speaker.
if you have any more question please ask. good luck
Sep 24, 2009 | 1996 Lincoln Continental
Can't get the air compressor to run on my 1996 linclon continenta
check voltage or the power source, ohm out wiring to check for continuity
1994 Lincoln Continental Executive Series oil level indicator
A common problem in the continental (my 95 had the same problem). You can TRY to reset the error. The link below lists step by step instructions for the error reset. Best of luck.
Greg
http://www.synthetic-direct.ca/technical/reset_oil_service_light_lincoln.htm
May 27, 2009 | 1994 Lincoln Continental
Continental 1995 Lincoln Radiator - 95 Lincoln Radiator dpi 1729 Logo
Top Continental Heating & Cooling Experts
Tim Whalen
Fotis Papastamatiou
jasbo
jasbo
Are you a Continental Heating and Cooling Expert? Answer questions, earn points and help others
