Question about Plumbing
I need help on hoe to get clean out lid off that was put on crooked
The lid to the cleanout has been put back on crooked and I've tried everything we can think of and we can't get it off
mmnhltm
  • 695 Answers
SOURCE: i've tried already all the solution that you
format operation
you have to download nemesis service tool program from internet to your PC
and read the instructions
then connect your mobile phone with the PC via usb cable or box cable and continue
Posted on May 09, 2011
rockmeister
  • 2047 Answers
SOURCE: Black areas have white strip
This is a sign that the print head is faulty and might need replacement. If you have replaced the ink cartridges and also cleaned the head and deep cleaned then this means the print head is bad and might need replacement. Although usually the cost of replacing the head is almost the same as purchasing a new printer. get the print head checked and if possible replaced if you can get it for a reduced price.
Hope this solution has been helpful?
Posted on Jun 27, 2011
SOURCE: I removed all the racks
There is a button on the top receiver bracket on the left side... when you take the rack support bracket out you will see it. Take a damp sponge and go over that area, pressing the plunger/button in several times. That should do it. Sometimes grease build up can prevent the button from popping out all the way, so the oven thinks that the racks are still in there.
Posted on Oct 16, 2011
SOURCE: I've a smart UPS 1000VA SU1000INET I've had new batteries fitted. I put on to charge everything seemed ok. Went back to it about 2 hours later to find the 6 middle lights flashing.
this link may help there is a good section on replacing batteries and doing self test again
click here for manual
Posted on May 17, 2012
SOURCE: i can't get my bobbin thread to pull up on my brother bc-1000 sewing machine
have you tried changing the needle?
if you have & it doesn't help then it's possible that the machine is out of time & needs to be serviced
Microphone Problem MSI / Realtek
disable your internal mic, go to start--type computer management--go to drivers-- sounds and audio-- right click, and disable the one you dont use.
Jun 18, 2013 | MSI Microstar GE60 0ND-257US 15.6" Gaming...
New magimix won't start
It is most likely the way the bowl and lid are set.
Facing the machine:
the bowl locks in, with the handle to your right directly above the switches. The lid has a double tab...see underside of the top of the lid. Place the lid on tightly with both tabs locked into bowls handle. It really clicks in.
Feb 01, 2013 | Magimix 4100 Cuisine Systeme 1268 Cups...
Noisy bobbin bounces in case
If you just had serviced a month ago I would take back and tell them to fix the problem you did not have before they serviced it, or try calling maybe then can advise over the phone.
Jul 17, 2017 | Sewing Machines
Canon sx20 lens error
From your description it appears to be a mechanical problem. I doubt you can get it repaired in time for your trip.
I suggest you put your money towards a new camera and you maybe able to use the SD memory card from the old camera after you format the SD memory card in the new camera.
Apr 16, 2012 | Canon PowerShot SX20 IS Digital Camera
How do i get the bottom off the blender jar?
The best way that I've found to remove the bottom from the blender jar is to put the blender jar back on the blender base (make sure it locks in place) and then turn the jar to the right. You'll feel the jar detaching from the base. Once it's loosened up, remove from the base and finish turning the bottom, manually. Before I found this method, I had tried everything to get the plastic bottom detached from the jar. Without removing the bottom, there's no way to clean it properly and rather than be unsafe I'd need to throw the whole works in the trash. But the method I've described above works every time!
Aug 13, 2011 | Jenn-Air JBL800 Work Top Blender
I have the bissell pro heat turbo microban cleaner. It's about 2 1/2 years old and maybe used 8 times. The brushes do not work and it's not suctioning up the water. I've checked the belt on...
You already said it, so check the carbon brushes. Once it is no longer able to push the rotor or stator it need to be replace. Carbon brushes are customized at the machine shop, so you should bring it so that you have a sample of the brushes itself. Just be observant when disassembling the motor so that you put it back to exact place.
Thanks for asking.
Jul 13, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
I wanted to take out the carpet from our living room tiled floor. We used rugby (contact cement) and don't know how to clean the stains left on the said floor. What' s the best way to clean it?...
use a strait garden hoe its about 6 inches wide find it at any hardwhare . homedepo, lows etc. its just like a regular garden hoe eccept it is not turned at a 90 degree its strait get a long handle one so your not on your hands and nees find an edge you can get under between the carpet and tile and start chiping away at about a 45 degree angle with short powerfull strokes . I had the same problem when i bought my house tried everything I could think of and this worked the best and was easer on my back and nees
Jul 07, 2011 | Computers & Internet
My Slim Ps2 crashed!!
hi is your ps2 the one where the lid lifts up to put the disk in if so their can sometimes be a problem with switch on the lid when you press the button to load the game push down on the lid and hold it down and if this is the problem then the game will load.
My ps2 has this problem and i have to put books or bottle of somekind on the lid to keep the lid pressed down far enough so that the switch works and loads the game.
Also you could try cleaning the laser lense you can buy a lense cleaning disk and that will clean it for you and if thats the problem as moving it might have caused the dust to move inside a bit affecting the laser have a go at these ideas then get back to me ok
Mar 31, 2008 | Sony PlayStation 2 (PS2) Console
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
