Question about Moen Plumbing
With my new moen faucet came a tool for tightening the faucet down. In that bag there was packet with moen p/n 99915 written on it. what is that for?
    Top Expert:
  • Moen Master
  • 51,484 Answers
That is plumbers grease to lube the orings and gaskets with
Posted on Apr 03, 2015
  • 171 Answers
SOURCE: Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 21, 2008
snap101
  • 117 Answers
SOURCE: I have a Grohe Ladylux Plux kitchen faucet that
you can pull the faucet arm off, the part right on top of the base , if my memory serves me correct you can tighten it with a creset wrench and the neck will pop right back on after
Posted on Aug 04, 2009
  • 49 Answers
SOURCE: My Moen kitchen faucet stopped working suddenly in
wow... I wish you hadn't gone thru the expense of replacing the faucet... it's perfectly good... your problem was the aerator, it unscrews at the tip of the water spout and had collected too much sediment which eventually blocked water flow. Often happens quickly after your water is shut off at the main valve. Aerators cost about 50 cents...
Posted on Sep 03, 2009
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
  • 129 Answers
SOURCE: My moen single lever faucet is loose, how do I
On the back side of the lever you should see a button cover. It pops out exposing a allen key. this will tighten the lever
Posted on Nov 08, 2009
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    How do you tighten the swivel part of moen faucet
    you need to take off the handle and tighten up the bonnet nut becarefull not to damage the o-rings inside or it will leak yu just need to make sure and take care that the spout is all the way down before you crank down on the bonnet nu
    May 11, 2014 | Moen 7840 Camerist Single-Handle Kitchen...
    My Moen 87560SL has come loose, do I need the installation tool (#118305) to tighten it?
    Hi, Installation tool can be found on amazon, here: Amazon com Moen tool. I hope this was helpful. Cheers
    Mar 05, 2012 | Moen Plumbing
    LEAKS. HAVE GASKET KIT. BUT CAN'T GET IT APART!!
    MOEN ARE NOTORIOUSLY difficult to get appart. There is a "Special tool" just for Moen faucets/tubs/showers. It is like an old "Brake drum puller" or "Faucet handle puller". I think about $10 to $12 at Home Depot or Lowes. FYI Moen and Delta both give "FREE PARTS" on "MOST" faucets for many years if not life, if your not in a hurry. Check your original paperwork for warranty. The washer at the end of the valve after being installed for more than a year, usually binds up and gets torn apart when removed. It makes it VERY difficult to remove, even with the "Special tool". They (Moen) give you a plastic wrench like thing that almost never works, with the purchase of a "New valve" DELTA800-345-3358 ..MOEN-800-289-6636
    Aug 22, 2010 | Moen 87555C Trianna Single Handle Pulldown...
    Faucet is dropping it is a one handle
    First turn water supply to faucet off and remove handle. Remove cartridge from inside faucet and replace with new cartridge. Make sure you tighten cartridge to snug. Don't over tighten.
    Aug 10, 2010 | Moen & Villeta Two Handle Lavatory Faucet
    Handle is loose water flow weak
    to tighten handle, you hold lever(top of handle) while unscrewing round piece below, entire assembly should come off.look down and should be screw down there, tighten it up. flow problem could be the areator, unscrew and clean if need'd. check supply tube's,shut off valve's, (if you have them)make sure they are wide open.
    Mar 22, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    How do I fix a dripping MOEN T4572 lavatory faucet
    If you contact Moen, they will send you a new cartridge, as well as tool to replace it. ( 1-800-buy-moen )
    No charge.
    Jan 18, 2010 | Moen Monticello Single-Handle Kitchen...
    Own a Moen 87888 kitchen faucet. The handle has gotten wobbly. How do I fix this?
    Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
    Thanks and Please Rate jj505
    http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
    Mar 10, 2009 | Plumbing
    Hi varn4620,
    Thank you,
    Sep 14, 2008 | Moen 2919 Chateau Two Handle Tub and...
    Plumbing Logo
    207 people viewed this question
    Top Moen Plumbing Experts
    john h
    Don Numinen
    Don Numinen
    Mike
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
