Question about Boating
Tachometer 90 horse mercury outboard engine quit working any suggestions
    Champion:
  • 243 Answers
Hi Royscarrow,
This Could Be A Few Reasons Causing The Tachometer Not To Work.
The Voltage Regulator Mounted In The Engine Compartment Has A Grey Wire Coming Out Of It Together With Two Yellows,Two Red's and One Black. The Grey Wire Is The Sender For The Tachometer.
Check That It Is Connected.
Is The Battery Getting Charged When The engine Is Running?
Is The Potting In The Regulator Discolored Or Burnt Looking ?
Check The Plug For The Gauge Loom At The Control Box Is In Correctly.
Let Me Know What You Find.
Posted on Apr 04, 2015
  • 3 Answers
SOURCE: I have a 90 Horse power Mercury outboard Boat
Sounds like the starter. Check if you have power at the solenoid from the battery with just the power on (key turned on, power switch on.) thats good-- you have power-- if not you have a wiring problem from your battery or main switch.
Otherwise you have a starter problem probably.
Posted on May 17, 2009
  • 5677 Answers
SOURCE: I have a 1984 90 horse Mercury outboard motor and
If there is a difference in end play see if there is more play in the throttle cable than in the shift cable. It may be switched in either the motor end or the shifter box. Or a gear inside the shifter (less likely) is reversed. The only other idea I have is if that does not work to test the location of the shifter and let it hang down freely. The cables are grouped in sizes like 15 to 17ft, 17 to 19ft, and so on for a reason.
Posted on Jun 11, 2009
  • 5677 Answers
SOURCE: mercury 90 outboard transmission slipping
Check your prop hub. The rubber isolator is probably bad.
Posted on Jul 06, 2009
  • 5677 Answers
SOURCE: I have a mercury outboard 50hp engine that will not start
If you are saying the Flywheel is locked or Frozen then I imagine the starter Bendix was found extended and jammed against the Flywheel.
If the motor ran when it was shut off last, then your rings and/or bearings rusted in place. You don't want to grab the prop to turn it because it will strip the Rubber hub.
I would take out all the spark plugs, tilt the engine up as close to level as you can get it and spray WD40 into the cylinders. If you did not have water connected to the engine the pump may have crumbled but if the engine did not turn at all the pump may still be good.
Give the WD some time to penetrate and crank the engine to see if it broke loose. If it did not, you may as well drop the lower unit and eliminate jammed gears with a second try at cranking the engine.
If still no luck, you might try to rig an Air fitting to the Sparkplug holes and hit each with about 80PSI and another squirt of WD. This will force the WD deeper and force the pistons down with no damage.
Still no luck, then its disassemble time. Good luck on this.
Posted on May 27, 2010
  • 747 Answers
SOURCE: 1987 90 hp mercury outboard kills when putting it in gear
sound like a fuel issue if the engine set for a long period you may need to clean the carburators sounds like they are clogged
Posted on Jul 07, 2012
2017 Mercury 90 horse outboard won't go up or down
Is trim motor turning, when switch is engaged? If not, can you hear the trim relays click with switch engauged? Do you have switch on engine as well? Did you check the fuses?
Sep 20, 2017 | Mercury Boating
1996 mercury 60 horse 3 cylinder 2 stroke
problem in the idle settings of the carby
could be rubber bits from deteriorating rubber hoses /water in the circuits but it needs attention from accredited mercury service centers
Apr 25, 2017 | Mercury Boating
What year is my Mercury outboard
with out information as to size, hp, band color on the cover, serial number or photo , no one will be able to answer that question
you can go google and type in--- identifying mercury outboard models and types and power ranges --
there are sites that I found quite some time ago from mercury that was pretty good and if you have a serial number and horse power , you may get the answer
of course you could always take it in to a service dealer and have it identified
May 13, 2016 | Boating
90 horse mercury outboard tachometer quit working I've checked connections.
Faulty tachometer or rectifier or broken wire in loom,check if any current coming out of grey wire with engine running
Apr 08, 2015 | Boating
Serial number decode0B142498
Go to boats.net - Mercury parts - search under hp/serial range - select 20hp 2 cylinder - it will be under the first selection 0A730007 and up.
Aug 24, 2014 | Seloc Mercury Outboard Engine Repair...
Free Mercury Outboard ONLY, 2-40HP 1965-1989 Repair Manual 1-2 Cylinder, 2 Stroke
I have a problem with my 2 stroke 20hp mercury 1989,when I run 10-90% throttle it's works fine but when in 100% its only runs in 90% and doesn't sound normal like it's not burning right.
May 11, 2012 | Seloc Mercury Outboard Engine Repair...
My tach stopped working
If it's a machanical tech check for a broen line from the engine. If electric check for + voltage to the tech if ok tech if bad
Oct 14, 2009 | Faria Chesapeake Series Tachometer
Boating Logo
157 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
