Question about Samsung Televison & Video
How to switch from tv to dvd - Samsung Televison & Video
    Scholar:
  • 57 Answers
Your DVD will be (or should be) connected to your TV using either HDMI cable, Component Cables + Audio, Composite Video + Audio or other A/V connection. Your TV remote will have an input selector that switched the source signal within your TV. This can also be called source selector. In any case, you need to push this button on the remote to rotate through sources (if only one button) or push the button labeled DVD, for instance to select the DVD inputs. Please note that only one type of connection should be used such as HDMI or Component, but not both.
Posted on Apr 03, 2015
Tv stuck in dvd mode
There should be an input button on the tv to allow you to switch between dvd, tv and any other device you have connected.
Aug 22, 2014 | Akai LCT3201TD 32 in. LCD Television
How to use the dvd player how to play a dvd how to get a picture
should be with the remote---whatever input on the rear the unit is connected to you have to switch the set to THAT input to see the DVD
Oct 31, 2012 | Televison & Video
JVC XV-SA602 player - I just get red and blue wavy lines on my TV, but can get audio. I've checked my component video connections and they seem fine, but cannot get video or even the menu to come up on TV....
I found the problem, or at least the solution. I set the switch on the back of the DVD to "remote" and reset the TV settings on the remote (although they had not changed and were still OK). With the TV/Video switch set to "colorstream", I finally got the video from the DVD. This was odd, because my TV says it does not accept progressive scan and my settings have always been with the switch on 480i on the DVD. The only change has been a added cable TV DVR box capable of HD (although TV is not HD). Does not seem like that should affect things since the cable box just outputs to the TV. But, at any rate, this regained our picture.
Nov 23, 2009 | JVC XV-SA602SL DVD Player
Cant switch tv to play my dvd player. no button on menu for this
If the tv remote has a input control button(video/antenna), you should be able to play your dvd thru this .
Apr 29, 2009 | Televison & Video
Can't get the Samsung HT-z310 Home Theater to stay on AUX2
you need a fibre optical cable for this, simply you connect that from your dvd to tv and then set the input on the dvd to digi in. i have exactly same home cinema system.
Nov 27, 2008 | Samsung HT-Z310T Theater System
Unable to switch on DVD function on a Bush 14" combo
Switch on t/v press TV / DVD button on remote to ensure it is in TV mode. Select DVD by pressing
AV button once or by using input select menu
Press TV /DVD button until DVD RC appears on top left (The remote is now set to DVD mode)
Insert disc ensuring label is to rear of set and Auto play function will start
Oct 10, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Dvd player not connected properly to TV?
You might need one or both of:
RF modulator.
AV switch (perhaps from an old video game console)
The modulator accepts the RCA plugs from your DVD player (yellow, white, red) and outputs an RF signal.
You can then plug the ouput of the modulator into the aerial input of the skybox, via the switch, if desired.
Sep 28, 2008 | Cyberhome CH-DVD 300 DVD Player
I have a weird problem with my Pionreer DVR-420HS DVD Player. Whenever I'm watching a DVD or a programme recorded on the hard disk for some reason it switches back to the tv yet the dvd is still playing. ...
If you have connected the DVD to the TV with a scart lead, the lead could be slightly loose. In this case push all the scart leads in firmly.
Pin 8 of the lead carries a switching signal. When the DVD is powered on it tells the TV to switch to that input. If the switching signal is lost the TV will switch back.
May 05, 2008 | Televison & Video
Cars tv and ps2
I have a lightning mcqueen 13' tv model# C1310ATV, and a little purple car-DVD player model # C8000 for my grandson, I cannot get dvd to play on tv? Should I hook it up(dvd) to back of tv or the front of tv, and if so, is there a switch over button for dvd to normal tv watching. TV is hooked up to Direct tv and plays fine. But can't get dvd to play on tv, I've tryed channels 2, 3, and 4. But no picture. Again is there a switch over button or auxiliary button or ???
Your help and consideration, concerning this problem will be greatly appreciated by my grandson and myself. Thanks
Mar 30, 2008 | Disney DTD1363-CAR 13" TV/DVD
Televison & Video Logo
49 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
