Question about Boating
How to remove the bow seat backrest in a 1998 Larson Sei 186 bowrider ski boat
SOURCE: how to remove backseat backrest to change seat cover from 05 f150
u have to start by taking the bottoms out. then the back there should be two bolt to take out and it slides up and pulls off
Posted on Jun 29, 2009
SOURCE: removing rear seat back
there my be bols holding the seats in place
Posted on Oct 21, 2009
steve_e_uk
  • 1675 Answers
SOURCE: how do you remove the headrest on a 1998 daewoo
hi normally you can do this by...pulling the headrest top its maximum height , at the bottom you should see two black plastic rings, on either side of these rings are little partitions push these inward and pull the headrest at the same it can be a bit awkward but if you do one side at a time or get someone to pull the headrest while you push the clips in can be very helpfull...hope this helps please vote thanks
Posted on May 11, 2010
Suzman
  • 642 Answers
SOURCE: how do I remove the
Remove the headrests (if equipped). Grip the lower seat at the front part of the seat and pull upwards to clear the clips(1), and the remove the lower seat.
Fold down the armrest and remove the bolts behind the armrest. The upper seat(backrest) is then pushed up, pulled forward and then moved either left or right out of the vehicle from behind the seatbelts.
Posted on Nov 15, 2010
philwalker78
  • 608 Answers
SOURCE: How to remove a drive shaft on a ski centurion
Hi, remove the rudder. Then undo the three grub screws on the engine coupling. They are at 90 degrees to the shaft and lock the shaft into the coupling. There will also be a small collar rear of the coupling that you need to take off the shaft. Then slide the shaft out. All this has to be done with the back of the boat raised clear of the trailer. Hope this helps, regards Phil.
Posted on Jul 18, 2011
1995 StarCraft 20ft bowrider. Where can I get an owner's manual?
Boat Manuals Now Available Free From Vessel Vanguard ...
www.passagemaker.com/.../boat-manuals-now-available-free-from-vesse...
Nov 14, 2013 - Boat owners are often frustrated by the diffi. ... I ask for a boat manual1995 20 feet limited sea ray . How long does it take if it is not in ... I am looking for theowner's manual to a 17ft 1992 Starcraft Bowrider. Jonathan Bonar ...
Nov 03, 2015 | Boating
Remove rear seat
Rear seat cushion-fold forwards,release plastic clip from hinge,remove wiring multiplug if applicable.Lift out cushion.(40% backrest)Tilt forward approx 20degrees,use a screwdriver to release catch retainer on outer pivot pin.lift backrest and withdraw from inner pivot pin.Lift the backrest from inside vehicle.(will only lift out if backrest is tilted forward 20degrees from verticle. 60% section can then be removed on saloons by releasing the lock with a finger and pulling from the anchor pins.On estates unscrew centre seat belt lower mounting and unscrew hinge pin from centre support. unhook upholstery clip and lift backrest from lefthand side mounting.slide backrest towards the door to release centre pinlug and withdraw backrest from inside the vehicle. Refit in reverse order.
May 22, 2015 | 1999 Saab 9-5
Witch model of boat do i have with ser no LAR75995H405
Sounds like a 2005 Larson. All boat manufacturers go by the last two digits to identify the year. The 180 or 186 is the model number which normally corresponds to the boat length: 186 meaning 18'6" and 180 meaning 18 feet.
Dec 23, 2014 | Boating
Where are the fuses located on a 1998 Larson SEI 186
some boats put them under the dash some inside the cabin if so equiped .
Jul 13, 2014 | Boating
Torque 1998 Tiger Shark 770 jet ski, blew out head cover gasket.
Inside-out in a cross pattern. Cases/cylinders 25 ft./lbs., Head 22 ft./lbs.i
Jun 29, 2010 | Boating
How do you remove the headrest on a 1998 daewoo
May 11, 2010 | 1999 Daewoo Lanos
Middel seatbelt will not loosen
I think you have to remove headrst bfore folding seat back down. You may have to unbolt seat from floor. 4 bolts.
Rear Seat Backrest —Split Bench Removal
NOTE: The 40% rear seat backrest must be removed before the 60% rear seat backrest.
  1. Remove the 40% rear seat backrest.
    1. Remove the nuts and bolts.
    1. Remove the backrest.
  1. Remove the 60% rear seat backrest.
    1. Remove the nut and bolt.
Installation
NOTE: The 60% rear seat backrest must be installed before the 40% rear seat backrest.
  1. NOTE: Do not tighten the nut and bolt at this time.
    Install the 60% rear seat backrest.
    1. Install the rear seat backrest.
    1. Install the nut and bolt.
  1. NOTE: Do not tighten the nuts and bolts at this time.
    Install the 40% rear seat backrest.
    1. Install the nuts and bolts.
60/40% rear seat backrest
  1. Tighten the 60/40% rear seat backrest nuts and bolts in the sequence shown.
40% Rear Seat Backrest
  1. Tighten the 40% rear seat backrest nuts and bolts in the sequence shown.
Jun 11, 2009 | 2005 Ford Escape
Boating Logo
59 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
