Question about Frigidaire Affinity ATF8000FE
Wont fill with water, could it be the door latch switch?
    Genius:
  • Frigidaire Master
  • 1,585 Answers
Its called a door inter lock and it probly is at fault
Posted on Apr 03, 2015
Bosch frontloader will not spin or agitate
You can check the following things in your washer:
1. Is the washer door or lid closed?
a. If yes, does it filled with water?
b. if no: Please contact the manufacturer to replace the door latch.
And if it is not filling properly then there is a water supply issues like: hot or cold faucets closed or not open completely, hot and cold hoses reversed, kinked or pinched fill hoses, plugged inlet screens or insufficient water pressure
Jul 22, 2016 | Bosch Washing Machines
Washer door latch
Unplug your machine, remove the top panel, doublecheck all of the wiring is securley connected. Sometimes the wiring becomes loose due to the machine's vibration.
Jun 24, 2008 | LG WM-1832C Front Load Washer
Doesn't fill with water
Hi this could be serveral items that will cause this , 1. No water, 2. bad water valve. 3. door latch , 4. Bad controller 5. pump plugged up with food
Dose the door latch feel funny , dose it lock correctly ?
The latch is always the first thing i look at , check it out some more and get back to me , Frank
Dec 02, 2011 | Maytag MDB7100AWB Dishwasher
I have a LG topload intellowash WF-T7516LS as soon as i switch on the machine the water fills in and then it just shows dE pls help
dE stands for Door open Error. Your door is not closed properly or the door switch is not activated. Try to press the door firmly. If the error does not go then you will have to check the door latch, notch ( a protruding part which goes inside to latch & activate door switch) & the door switch for any damage. For Top load machines the notch is near the hinges & inside the machine.
Sep 22, 2011 | LG WM-2277HW Front Load Washer
Dishwasher will not fill with water. What could be the problem?
Dishwasher will not fill with water .
  • Check that the water supply is turned on. The valve may be located under the sink.
  • Check the door latch
  • Test the door switch
  • Inspect the float assembly
  • Inspect the fill tube for kinks
  • Test the float switch
  • Check the inlet valve filter screens
  • Test the water inlet valve
  • Test the drain valve lever arm
  • Check the drain valve
For trouble shooting click this link:--- http://www.partselect.com/dishwasher+dishwasher-wont-fill+repair.htm ----------- Thank you.
Jan 24, 2011 | Maytag Dishwashers
FDL fault code on kenmore elite washer
F DL
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Nov 08, 2009 | Kenmore Elite 45986 Front Load Washer
We have a dishwasher model:SHU9925UC/14. The problem is that when I run a cycle it doesn't fill up with water. Please can you help us.thank you.
Check this all causing not fill water:
  • Check the drained valve
The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow.
The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate.
It is a simple matter to determine whether the door latch is theproblem. Simply open the door, close the latch and select a cycle anddepress the switch. Note that if the test is successful, with the dooropen, the dishwasher will operate and water may spray out. Make sure tofirst remove all tools from inside the dishwasher. Do not reach insidethe dishwasher during the test. Now, inspect the cabinet where the doormakes contact with it and locate the door switch. It may have aprotruding button or spike or more likely it is a hole with a piece ofmetal or plastic inside it. You must fully depress that switch. If theswitch is recessed, then use a non-conductive object, such as a woodenpencil, to depress the switch.
If the dishwasher begins to operate during this test, then you have isolated the problem. The door switch is not being fully depressed when the door is latched. There are three likely possibilities:
  1. The door latch is misaligned.
  2. The entire door is misaligned.
  3. The striker for the door switch is damaged or misaligned.
To service the door latch, it may be necessary to access it in the control panel. Access varies by model; on some models you can remove just the control panel on others you must remove the interior or exterior panel of the door.
Before removing the control or interior panel, look first for exposed screws that may allow you to adjust the latch or the strike plate. You may be able to loosen the screws and shift the latch on the door or the strike plate on the cabinet. It may require some trial and error, but you can loosen, adjust, tighten and test until it latches properly.
Good luck ;
Don't forget to rate:
Jul 10, 2009 | Bosch Dishwashers
IT wont start washing
if it fills with water or has filled and wont go any further then suspect the door switch< latch assembly has switch> if it doesn't fill then possibly water valve not working,if neither of these seem accurate then please give more info
Apr 20, 2009 | Kenmore 42822 Front Load Washer
Wil not fill with water
  • The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched. The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
    It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch
    Sep 21, 2008 | Dishwashers
    When you start a cycle the washer fills then turns then sounds as though its trying to empty the door lock light flashes and 2 other display lights flash
    It means your door is not shutting or latching
    Check for debris and nothing stopping it from shutting
    If not replace door latch(some parts lists call it door switch)
    its most likely not actuating so it wont advance to the next part of cycle.
    if not latch could be bad control board, id try latch first is cheaper and more common
    May 02, 2008 | Washing Machines
    Frigidaire Affinity ATF8000FE Logo
    43 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
