Question about Reliance 1996-1999 Ford Mustang Expedition F250-f350 Aternator
Why does engine start at wide open throttle. - Reliance 1996-1999 Ford Mustang Expedition F250-f350 Aternator
    Sergeant:
  • 417 Answers
That's how most generators are designed so you don't damage anything running below the reccomended rpm. Some are equipped with an idle switch on the control panel so you can properly warm up and cool down the engine, but that's idiotic in my opinion they should ALL have that feature to prolong engine life. If you're concerned, an can reach it, hold the governor down so it forces the engine to idle for 20-30 seconds before and after use, but most things are made in china nowadays so who knows how long it will last even IF you did that anyway. Change the oil when it gets dark and keep the air filter clean. And make sure to drain all the fuel when you store it and run it dry so the carb won't get clogged up and you'll be fine atleast for a few years. You should listen to me, I've been doing this a while.
Posted on Apr 04, 2015
    Top Expert:
  • Reliance Master
  • 10,875 Answers
Throttle spring is busted,replace it
Posted on Apr 03, 2015
Craftsman DLT 2000 with Briggs and Stratton 25 HP. Engine runs at wide open throttle.
What is the float set at? What about the jets and fuel screw? Do you know what the fuel pressure is?
Aug 26, 2016 | Craftsman Garden
Had a p305 on my 2005 buick rendezvous engine light is on changed the coil pack. it still hard to start unless i mashed the gas. it stalls at the light
Starting Mode
With the ignition switch in the ON position, before engaging the starter, the PCM energizes the fuel pump relay for 2 seconds allowing the fuel pump to build up pressure. The PCM first tests speed density, then switches to the mass air flow (MAF) sensor. The PCM also uses the engine coolant temperature (ECT), the throttle position (TP), and the manifold absolute pressure (MAP) sensors to determine the proper air/fuel ratio for starting. The PCM controls the amount of fuel delivered in the starting mode by changing the pulse width of the injectors. This is done by pulsing the injectors for very short times.
Clear Flood Mode
If the engine floods, clear the engine by pressing the accelerator pedal down to the floor and then crank the engine. When the throttle position (TP) sensor is at wide open throttle (WOT), the PCM reduces the injector pulse width in order to increase the air to fuel ratio. The PCM holds this injector rate as long as the throttle stays wide open and the engine speed is below a predetermined RPM. If the throttle is not held wide open, the PCM returns to the starting mode .
You could have a dirty or bad mass air flow sensor .
You could have
Mar 25, 2016 | Buick Rendezvous Cars & Trucks
Wide open throttle engine will not pick up rpm like bad ignition
On most vehicles there is a wide open throttle cut out switch or it is programmed into the PCM/ ECM . Kills injectors ! To find out if yours has it , try an start the vehicle with gas pedal held to the floor .
Jan 05, 2016 | Cars & Trucks
Throtle gets stuck wide open i did tps worked for a day always pump to start runs ruff then goes bamm gets stuck wide open help me
You should not need to pump the throttle. That does not have any effect on starting the engine on a fuel injected car.
How do you un-stick the throttle ?
Dec 29, 2015 | 1999 Cadillac DeVille
Diagram distributor
Wide open as in wide open throttle?? You mean the engine is racing? Something is wrong with the throttle controls, or the throttle valve in the carburetor may be sticking open. Look down the carb throat. At its base will be the throttle valves-"butterfly" valves just like the choke valve on top of carb. The throttle valve should be closed at rest, or at idle, or when gas pedal is not moved. Rotate the throttle lever on the carburetor by hand (when gas pedal is pressed down, the throttle is rotated). The throttle valve at the bottom of the carb should open and close with the throttle lever.
If the valve is sticking, spray some carburetor cleaner down it, and spray the outside clean, too. Work the throttle back and forth to make sure it is free to move.
For a high idle, have the carburetor adjusted. Timing should be checked, too-that can cause a high idle, but wouldn't cause it to go wide open.
Let us know what you find. Good luck.
Dec 07, 2013 | Ford Ranger Cars & Trucks
Will not idle
Reconnect the governor rod back on to the carby throttle butterfly correctly. When stopped the lever will hold the throttle wide open and as it starts the lever pushes /pulls the throttle closed to the idle stop screw
May 31, 2013 | 5.5 HP GX160 Engine
My 2012 exc500 cuts out with throttle wide open and FI light flickers on.
The F1 light is an engine management error, take it to your nearest dealer and get them to run their diagnosis machine on it. You may have a mixture problem or an ignition timing problem.
Feb 18, 2013 | KTM Motorcycles
I have a 2000 Lincoln ls v8 3.9 it will only start when I hold the throttle wide open
A wide open throttle cuts off power to the fuel pump.
Is it possible one of the injectors is flooding the engine ?
Jan 28, 2013 | Cars & Trucks
Had 2 problems occur at same time after some repair. 1st. After repair started up an engine runs wide open with no throttle .Checked an cleaned T>P>S. an throttle body . Checked for vacume...
The only way an engine can run Wide open is if the throttle plate is opened all the way, allowing a large volume of air in to the engine. Check the throttle plate and see if it is hung up or possibly the throttle cable is frayed and holding the throttle open. It is not the injectors, they operate on inputs from the PCM.
Nov 13, 2010 | 1999 Jeep Grand Cherokee
When starting car engine will rev wide open.
check the throttle return spring, possibly broken or has come off
Jul 23, 2009 | 2001 Lincoln LS
Reliance 1996-1999 Ford Mustang Expedition F250-f350 Aternator Logo
56 people viewed this question
Top Reliance Electrical Supplies Experts
Craig Butler
Craig Butler
GFTALON
Are you a Reliance Electrical Supply Expert? Answer questions, earn points and help others
