Question about Dell Latitude C640 Notebook
Dell Latitude C640 Laptop
My Laptop (Dell Latitude C640) wont turn on at all, the power light is green and I can hear the fan but nothing happens! It also feels very hot, what can I do??
  • 121 Answers
Re: Dell Latitude C640 Laptop
Get to the main board of ur system there is a jumper near the battery .
change its position while power is off and get it back to its previous position. this way u will reset cmos to default.
if the computer starts hit delete to enter setup and load system changes then exit.
ps: defected processor could be the cause
Posted on Nov 14, 2007
0 characters
3 Points
I just bought a Dell latitude model number PP01L. When i plug the power cord into the AC adapter the light on it turns on. but when i plug in the adapter part into the laptop the light turns off and the...
Try it with all devices disconnected from the laptop. Sometimes defective USB devices will cause this. Then try it with no battery. This will isolate the problem for you. If it still happens with no battery or other devices, then the problem is either in the adapter or the laptop. If you bought the laptop new, then contact Dell tech support for help. If not, try a local shop. They should be able to connect another adapter to check the problem.
Apr 21, 2010 | Dell Latitude C640 Notebook
My Dell Latitude C640 problem might need an electrician's opinion
The connector can be replaced, an electronic repairer can do this for you.
May 08, 2009 | Dell Latitude C640 Notebook
Dell Latitude C540/C640
I think you are wasting a lot of effort, I know how you feel and sometimes you cannot win.
Junk it for parts.
I do volunteer work for Technical Aid For the Disabled (a charity organisation) and repair/refurbish laptops and computers for disabled people and I hate to see good computers go to waste.
Nov 14, 2008 | Dell Latitude C640 Notebook
Dell C640 won't power up
hi keith,
you have damaged the power slot on the laptop
sometimes it can be repaired by a service technician.
otherwise they may suggest you purchase a replacement motherboard
Sep 23, 2008 | Dell Latitude C640 Notebook
Latitude C640 is dead!!
I have the exact same issue. It's not the processor. If you have you power supply tested, you will probably find that it's not working anymore. The green light still comes on when plugged in, but it's not sending the "charge" to the notebook.
I have this issue with a couple of C640's. I've tested the machine by charging the battery in another (Pentium 3 Dell C600), then putting it back into the broken machine... woohoo it works.
Unfortunately I can't figure out why the power supply's keep on busting, I don't think that the power-supplies are faulty, or maybe they just get old, don't know, but the most obvious problem is probably something with the mainboard, which really sux.
Hope this helps,
Oct 09, 2007 | Dell Latitude C640 Notebook
Dell Latitude C640 Notebook Logo
716 people viewed this question
Top Dell PC Laptops Experts
Sudeep Chatterjee
Sudeep Chatterjee
Donna Sander
Are you a Dell PC Laptop Expert? Answer questions, earn points and help others
