Question about Whirlpool Washing Machines
Top load, washer goes thru cycle and goes to next cycle, which is backward,
  • tom cassidy
    tom cassidy Apr 03, 2015
    Hi Janet Pasinski, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Top Expert:
  • Whirlpool Master
  • 10,875 Answers
Timer is bad
Posted on Apr 03, 2015
Is it normal for the washing machine to start and stop the spinning while the machine is in each cycle? Should it take over an hour to run one wash cycle?
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
Aug 13, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer goes thru cycle ok untill spin cycle gets error code out of balance, but machine not out of balance
That is not to say that the drum is not out of balance. Try running it empty and see if it happens.
Aug 09, 2013 | Kenmore Elite Oasis 27052 Top Load Washer
Cycle switch keeps tripping
Switch actuator (usually on washer lid) is probably broken if you can complete the cycle by depressing switch manually.
Jan 17, 2012 | Amana 3.2 cu. ft. Top-Load Washer
Washing goes thru fill cycle, and spins, clothes still wet and soap still in machine.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 09, 2011 | GE WBB4500EWW Top Load Washer
Drum will not empty water
sounds like its not going thru the complete spin cycle and empty could the timer control switch its all intergrated in one all the the different application s the cycles goes thru all report back to the timer control switch and when the cycle is complete the timer goes to the next cycle i f the timer is defective it well keep on going reguardless and go to the next cycle unfortunately the cost will run around 250.00 for the part good luck
Aug 10, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
My washer fills the tub, but when it goes to next cycle just hums
Your motor has failed.
Remove it from the washer to have it repaired or replaced.
Thanks
:D
Jul 20, 2009 | KitchenAid KAWS850L Top Load Washer
Washing machine does go thru spin cycle or drain water.
If the washer does not spin, take off the rubber bumbers inculding the little washers attached, inside the lid. It lowers the lid, which takes care of the problem. I had the same problem. Not anymore! Trust me, if nothing is wrong with any other part of the washer, this will work.
Apr 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer not going thru cycle
IF YOUR MACINE WONT PUT WATER IN IT WHEN YOU TURN IT ON ITS THE WATER INLET VALVE IN BACK WHERE YOU HOOK UP THE WATER. IF THE WATER GOES IN WHEN YOU TURN IT ON THEN ITS MORE LIKELY TO BE YOUR LID SWITCH. YOU CAN GET EITHER OF THE PARTS AT YOUR LOCAL APPLIANCE DEALER OR EASILY ON LINE. JUST HAVE YOUR MODEL NUMBER HANDY. GLAD TO BE OF SERVICE.
Nov 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
