Question about ASUS Computers & Internet
How do i charge it? and can i charge in on my asus 2 in 1 notebook?
Im not sure what plug goes where to input goes where to charge from the connection cord .
  • shadowchb Apr 03, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Be more specific as to what 'it' is, like make and model of device and how the asus 2 in 1 notebook comes into the problem.
    Problem Solver:
  • 10 Answers
What are you trying to charge
Posted on Apr 03, 2015
My ASUS K52 battery is at 58% and not charging why ?
Is this an ASUS charger and battery? Some ASUS laptops will not charge after a certain charge is reached, but it's usually in the 95-100% range to prevent overcharging.
If you bought an aftermarket charger, it may very well not have the amperage to charge while running the laptop.
Feb 13, 2015 | ASUS 156 K52 Notebook (AAC4001K52DRA1)
Why does my asus notbook not turn on and is blank?
Sounds like the battery is completely flat.
Ensure your charger is plugged into the mains socket and plug into your notebook. Leave to charge for about an hour, then it should switch on.
When you have finished using it, make sure it is shut down correctly and leave it charging over night for a full charge. (When it is switched on whilst charging, it takes much longer to charge.)
Jun 24, 2014 | ASUS B50A-B1 (90NQ9A1232244EQL150YB50AB1)...
Charging, but won't turn on
i'm leaning towards a bad charger, i'd try a new one first
Jan 06, 2014 | ASUS K52n-a1 Notebook
My battery do not keep any charge, but its condition was diagnosticated as "excellent" with specialized programs. The laptop works only with an automatic multi adaptor (Woxter brand). The system reports...
"plugged in, not charging" could a symptom of incompatibility between the charger and the battery.
If this is the case, once you unplug your ASUS ac adapter, the laptop goes off.
Anyway, it's still Ok to use the charger but you need to plug it in all the time.
Here is a little trick that I found that works.
1. Power up the Notebook with the battery installed,if you can.
2. Turn the computer completely off and remove the battery.
3. Power up the Notebook with AC power only (no battery installed).
4. Turn the computer completely off and re-install the battery.
5. Power up the Notebook.
6. The message no longer appears (at least for me it has disappeared).
Aug 12, 2013 | ASUS Eee PC T101MT-EU27-BK Convertible...
Why wont my eeepc charge ???
There could be three very good reasons I can think of immediately.
1) Check your power adapter to be sure it is working properly. You may want to find someone with a voltage meter to do this.
2) Check the power adapter plug on the laptop. These plugs are bad about becoming loose over time. When we use our laptops we tend to move them around especially if we are holding them in our laps. This causes the adapter plug to be pulled back and forth which can actually break it from the motherboard inside the laptop. No connection...no charge.
3) Be sure your battery is still good. Batteries can go bad like anything else and many times are the reason the PC won't charge.
Aug 26, 2011 | ASUS Eee 4G Notebook
When I start up the computer it only goes to the Asus black screen and no farther. I put in the recovery disc but nothing happens. I can get into bios but not sure what to do once I get there. Help
Remove your battery completely, plug the AC cord in and try a reboot ;)
(If you leave your battery charger plugged in on a fully charged battery it may cause a voltage issue preventing your Graphics card or other things to start.)
Aug 26, 2010 | ASUS X83Vm-X1 Notebook
I cannot get any volume out of my Asus EEEPC 1005ha. It is impossible to hear on skype and the volume generally is very poor.
Yes it has built in speakers there is a cable with two green ends one goes in the output on computer the hole to plug into will be green also and on the monitor there is a input for the other green end. Go to following site and look at 2.b hope this helps if it did make sure to click yes it helped button.
B52Computers
http://h10032.www1.hp.com/ctg/Manual/c01368612.pdf
Dec 05, 2009 | ASUS Eee PC 1000HA Notebook
Cant connect asus computer to tv via hdmi
Try turning both pc and tv off and connect, then turn both on. Also, make sure your Display setting are correctly configured. Goto Control Panel, Display and click on Settings Tab. If your still having trouble. Try changing your resolution and make sure that you have your TV to the right input. My TV has 4 HDMI 3 RCA 2Component 1 Digital Optical many USBs...can get kinda confusing. The connection should be numbered. Switch inputs with your remote til you get the right port. Then work on getting your pc to display correctly. Set your aspect ration to 16:9 first. Most tv and laptops are set this way. GOOD LUCK let me know how it goes.
Sep 12, 2009 | ASUS A2400H Notebook
Connecting my notebook with infocus
Try to double check if your connecting to port 1 of infocus, theres also a fn shortcut with your display setting i believe its fn+f8 or fn+f5 im not very sure  whats the command with asus try to doublecheck your user manual
Sep 18, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
51 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
