Question about Dishwashers
There is a stale smell inside the dishwasher. How do I clean the inside of the dishwasher to get rid of that smell?
    Problem Solver:
  • 6 Answers
Try backing soda that should work only 2 tbl spoons good luck
Posted on Apr 03, 2015
    Sergeant:
  • 268 Answers
Try dishwasher cleaner (Finish is one brand). Available at Sears, Home Depot and most hardware stores. Follow directions on package.
Washing machine drum always smells of stale water. Have tried hot washes, washing machine cleaner kits, cleaning filters, leaving door open, have also checked machine is correctly plumbed in but cannot get...
This will potentially sound odd, but run the 90 degree cycle with 3 dishwasher tablets in the drum. The smell is bacterial and probably the result of a build up of residue from biological soap powder (Which is simply bacteria that eat your stains). Dishwasher tablets are anti-bacterial and will kill the bugs making the smell
Jul 12, 2011 | Whirlpool Washing Machines
Odd odor coming out of dishwasher upon opening it. Smells like rotten milk. What is the best cleaning solution?
After a dishwasher is installed the hose rarely comes to mind - unless a problem occurs and a repair person comes out to inspect the job. If the hose was installed improperly, or if it is lying in a position that does not let it drain, stagnant water will create a bad smell. Examine the hose that is probably inside the kitchen cabinet beneath the sink. If the hose is lying in the bottom of the cabinet, it is probably full of water. A film begins to form inside the hose and the odor begins to grow. The next time the dishwasher is used, the stagnant water ends up on dishes, and in the meantime it can cause a bad smell inside of the dishwasher. Hang the hose at an angle on supports in the back of the cabinet. This alone might get rid of the bad smell inside the dishwasher.
Check the Seal
A dirty dishwasher seal can be a source of a bad smell. Before deciding the dishwasher needs to be replaced, check the seal - especially at the bottom. Old food and grime builds up in these areas and can cause a particularly bad smell. Clean it with a solution of diluted bleach and hot soapy water. One teaspoon of bleach for each quart of water is sufficient to kill germs and the odors they create.
NB I decided to add a little bit of vinegar to the machine after I unloaded it. Sure it would smell pretty strong for a while but then the smell would dissipate. Voila! For two weeks now my dishes have not smelled whatsoever.
Jun 23, 2011 | Maytag MDB6709AW Builtin Dishwasher
Inside smells like stale water
YOU NEED TO RUN A (CLEAN CYCLE) ON THE WASHER.THIS CAN BE DONE WITH A 1/2 CUP OF AUTOMATIC DISHWASHER SOAP AND HOT WASH CYCLE. YOU SHOULD BE ONLY USE 2 TABLESPOONS OF H.E. SOAP IF THE WASHER TO PREVENT THIS
Apr 26, 2010 | GE WBVH6240F Front Load Washer
Dishwasher smells has a 'wet dog' smell
its the food and the steam together. its normal.
Aug 23, 2009 | GE Nautilus 24" Built-in Dishwasher
Doesn't get dishes clean
Remove the lower spray arm, the filter and the volute cover. Check for a foreign objects inside.
If there is nothing wrong then the pump & motor has to be replaced.
- The part number for the pump & motor assembly is AP3160640
Here are the break down diagrams for the Frigidaire dishwasher Model MDB125RGS0
Aug 22, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Put through entire cycle, standing water and dishes still wet, only 1 yr and 3 months old!WHY!!!!!!!!! It also has a musky or bad smell like food in the trash sometimes smells. 500 series 6 cycle stainless...
take the drain hose into a bucket and see if it pumps out.
if it does check for blockages where the hose goes to.
most likely is a blocked pump, the pump is assesable from in side the sump, you may have to get rid of all the water before you can see the cover, check instruction book.
Smell is usually caused by a warm cabinet left too long ( more than aday) with the door closed.
If your pump has been poor it could be stale water trapped in the sump.
Jul 16, 2009 | Bosch Evolution 500 SHE45M06UC Built-in...
Smells fishy
You probably have rotting food scraps in the food trap. Take the bottom arm off, remove the filter, and clean. You can also add some bleach to the bottom of the tank and run the dishwasher empty to sanitize the inside. Run a second empty load to rinse. This should help rid the dishwasher of the nasty smell.
Jul 05, 2009 | Dishwashers
Bad smell on dried dishes after being washed.Stale water smell.
Try Running Goo Gone Through It Although It Smells Like Oranges It Removes Stains As Strong As Sap. Also Try Running The Dry Cycle While Its Empty Two Or Three Times.
Jan 06, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
correct, no filters to clean, but what you are smelling is soap residues that have built up on the heating element and when it goes thru the heat dry cycle, it burns the soap causing the odors.
trying the cleaners you have may help but the cause is the residues. you need to use a d/w cleaner like d/w magic or citric acid. if you just run the unit with the waterheat option and vinegar in a bowl right side up in the top rack, it should rinse out the residues then dont use to omuch soap and only use dry powder soap. no tablets or liquids.
run hot water at the faucet first and then be sure to use the heat option. it may take a few cycles to get rid of the odor but it will go away as you get the unit cleaned out.
Jan 06, 2009 | Dishwashers
Stale smell on crockery after wash
Most commonly, this relates to sulfides or other impurities in the water itself, but may also be caused by a buildup of food soil within the washer. Smell a clean glass of water. Does it smell stale also? If no, clean the screens and wash water sump/tank within the machine.
You can also clean the inside of the machine by using a commercial grade dish machine detergent and increasing water temp if possible.
If the water smells stale, consult a local water expert for guidance in resolving
Aug 19, 2008 | Dishwashers
Dishwashers Logo
94 people viewed this question
Top Dishwashers Experts
Owen Barnes
