Question about Dishwashers
It looks like a faulty or blocked water inlet valve. Is there a service manual for it so I can find a spare part?
  • shadowchb Apr 03, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Like maybe the make and model of the dishwasher?
    Champion:
  • 208 Answers
Find the plate that has a model and serial number/ go online for local supplier. Solenoids are usually no very expensive to just swap out instead of trying to fix.
Posted on Apr 04, 2015
    Sergeant:
  • 337 Answers
Take both hoses off check to see if the screens are plugged
Posted on Apr 03, 2015
Testimonial: "already done. no blockages. and yes, the tap is turned on!"
  • Anonymous Apr 03, 2015
  • Jerry Smith Apr 04, 2015
    Can you list make and model?
Hotpoint Ultima WF860T
Alarm
code Description of fault User
code Effect
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Jan 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
WHIRLPOOL DISHWASER MOD ADG8100 fault f6 is on what is that
There is a problem with intake water.
Could be:
- water tap closed
- water inlet hose blocked
- faulty water inlet valve
- faulty flow meter
Opening the water tap within the first 30sec. of the program cycle rasets the failure F6. After another 30sec. water inlet valve will close due to safety reasons.
Dado
Jan 10, 2015 | Whirlpool Washing Machines
How to fix the washer "f" notification?
If doesnt drain the water first, then the pump outlet filter is blocked
Dec 02, 2014 | Maytag Neptune MAH5500B Front Load Washer
I have candy washing machine typ goy 105,after two minutes she stop working and red light start to blink 5 times
Please check your water flow at the inlet, if there is no flow then the inlet is blocked, the inlet valve is faulty or the water level sensor is faulty if the water overfills.It can also be related to a faulty controller board.
check this link for tips : Inlet valve.
Feb 12, 2013 | Washing Machines
Water keeps coming into the machine, looking for electric valves.
The solenoid valve is under the machine. It will be a block of metal installed with fittings into the water pipe and it has a plastic cylinder attached to it. The cylinder will have two wire terminals on the end opposite the valve block and is typically about 3/4" dia. x 1 1/2" long.
Jul 04, 2011 | Dishwashers
Intake drain light is on and dishwasher won't start
Hi there - possible the inlet valve is blocked or faulty - have a look at the valve if its blocked first if not then the inlet valve is faulty... the problem is the G638 has 2 inlets - one is the the waterproof syatem with a large grey contration fitted to the tap, the other is located beneath the machine , a bit hard to get at...
will require a disconnection of services empty water from machine - tilt on the back - 4 screws on the bottom tray - here you will find the valve - should be located on the frontish right side..
Do be careful if you pursue the latter as its a delicate with little space to work with and costly if you break something else in the process...
Have a think about this first...Yes? then do remeber to disconnect the power.....
happy weekend
Jun 30, 2011 | Miele 24 in. G638 Plus Free-standing...
Water no going in
Hi.
You will need to pull out the appliance and check the hoses at the back. Ensure that inlet hose is not kinked or blocked, and ensure that there is enough pressure from the faucet connected to the dishwasher.
Once you are sure that the water source is OK, you will need to test water inlet valve and water level sensor.
Inlet valve is tested reading Ohms at valve solenoid contacts. The valve is generally faulty if it does not open when energized. dual valves can also be tested swapping contacts between the two inlet valves' solenoids.
If the inlet valve is OK, then the water level and overfill devices must be tested, as this can prevent the inlet valve from opening.
The water level switch is often a floater switch. The machine can also use a pressure switch and an overvill device that fills a container. Floater is tested ensuring that the floater is not stuck or sinking, and verifying that the switch connected to the arm is opening and closing. Other way to test the float switch is by jumping it.
Some of the tests described is suitable for a technician or for an experienced DIYer. Always disconnect power before performing any maintainance.
If you need to contact a technician, call the number listed on the use and care manual or use the Fixya Products Repair & Service Directory.
To get parts and diagram try Entering the model number on one of two websites listed here.
Regards.
Ginko.
Nov 02, 2010 | Dishwashers
My washer only get a little water and my clothes dont get clean
could be blocked inlet hose/filter/connection. If water flow is ok to inlet valve on rear of machine, it's probably a faulty inlet valve. Replace valve with new unit......Good luck....Nomess
May 14, 2010 | Washing Machines
When starting a new cycle no water fills in. It just makes a buzzing sound
An inlet valve can buzz normally...However, if water is not flowing it probably means that the inlet valve is faulty..Make sure that the filters on the inlet valve are not blocked..If they are clear it's probably a faulty valve... Good Luck....Nomess
May 13, 2010 | Washing Machines
Dishwashers Logo
63 people viewed this question
Top Dishwashers Experts
