Question about Home
What does this code mean I have changed the battery already
Yamaha wr125x no spark,checked continuity on wires from ignition to ecu,changed coil and plug,engine light flashes when turning over.fault code flashes 19..anyone help.tried ecu on my nephews bike and
Did you read up on what that fault code means? I'm stumped personally. You didn't mention checking the plug wires though, but given how thorough you're being I'm guessing you already replaced them.
Oct 26, 2014 | 2010 Yamaha WR 125X
Code 41 for a 1999 chrysler sebring jx convertable 6 cyl 2.5
No vehicle after 1995 has a code like that
PO40 & PO41
Google OBD2 Codes P0 40
Mar 03, 2013 | 1999 Chrysler Sebring
What is code 43
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Restart your computer if you haven't done so already.
There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
Undo the change if you can, restart your PC, and then check again for the Code 43 error.
Depending on the changes you made, some solutions might include:
Jan 23, 2013 | Lenovo Computers & Internet
Want to change the phone security code but i forgot the previous one. the original 12345 was already changed. i forgot the succeeding code.
Security code lost means, you get the master reset code for that one.......
you can get the master reset code for your Nokia model mobile, through this site http://www.wickedunlock.com/nokia-dct-master-code-service/rs11wp10/
It has the best services for the master reset codes and unlocking codes for mobile phones.........
Nov 12, 2010 | Nokia 6300 Cellular Phone
What do the engine codes 12, 51, and 17 mean on a 1995 Jeep Cherokee 4 cylinder , 2 whd, 5 speed. It has a rough idle, really low fuel mileage, and not much power. Just recently started this problem.... I...
Code 12; Means the PCM sensed the battery was disconnected and after 50 key cycles, this code will disappear. Code 17; Means the engine is cold too long after start up. Engine coolant temp remains below normal operating range during vehicle travel. The thermostat is stuck open; replace the thermostat. Code 51; The O2 sensor stays below center voltage outout. And indicates a rich fuel condition. This is caused by the stuck open thermostat.
Oct 22, 2010 | 1995 Jeep Cherokee
Heats up drains battery fast
heats up?do you mean the unit itself heats up fast?if that so.you unit has a short circuit inside on it thats why your battery drains so fast...,but if its not,the problem is on your battery.Not even a battery can charge is meaning that your battery is still good.If a battery has defect or let me say it is already weak,it will not already stored a longer life of a power.,becoz if that so,the current or well known as the ampere is already goes down than the given specification when it is new..and thats the reason why it is already fast draining.
Oct 31, 2009 | Garmin Rino 110 (14 Channels) 2-Way Radio
I've already download power mp3 but its not installing in my N660
it can be mean your installation is corrupt or your phone is infected by a virus.
try to hard reset your phone with entering code *#7370#
after that you will ask for some code,enter 12345 for standard code or enter your code if you already change the code.
REMEMBER,all data in phone storage will be erased,
include your phonebook.
after that your phone will be restart.
Jun 08, 2009 | Nokia 6600
Brake light and battery light stay on Nissan Sentra 2000
now that u changed atl did u rest codes have them reset ya or unplug battery for few min back in see if code comes back then ok
Oct 06, 2008 | 2000 Nissan Sentra
Code #12,43,43,43,72,55
code #43 is for a cylinder misfire, since there are 3 codes, this would mean there are misfires on 3 of the cylinders.
code #12 means the battery has been disconnected within the last 50 key cycles (nothing to worry about unless you didnt disconnect the battery)
code #55 is just a code to let you know it has reached the end of the list
code #72 means the catalytic converter efficiency is low.
knowing the P-code would help alot more.
there are a few ways you can start to diagnose this problem, change the spark plugs, wires, and coil pack. if it isnt this, then you can go more dramatic and change the catalytic converter because it might be clogged and therfor causing the misfire
Jul 15, 2008 | 1995 Dodge Neon
Home Logo
483 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
