Question about SWANN PRO-535 Multi-Purpose Day & Night Indoor/Outdoor Security Camera
Infra red will not work
Works on day but not night
No timer included
Posted on May 14, 2015
    Sergeant:
  • 337 Answers
Does it have a timer for the infrared for night vision?
Posted on Apr 03, 2015
NR676 Remote stopped working immediately after updating firmware. Smartphone remote app works. How can I get remote to work?
Check if remote is emitting infra red by viewing the infra red output from the remote.
You can view the infra red signal using a camera of a smartphone.
If no signal is coming out check the battery of the remote is recommended.
Sep 10, 2017 | Televison & Video
.Can not take pictures at night with my Moultrie 1100i trail cam. I was informed that there are numerous SD cards that should not be used.
Not being able to take pictures _at night_ likely has nothing to do with your SD card. If the SD card works during the day, it should be fine at night, too.
Any camera needs some light to take pictures. Many use flash to take night time pictures, or infra-red (IR) lighting. I don't know your camera well enough to know if you have either or how to configure how to turn that on.
Nov 11, 2015 | Max Electronics - Others
How do i use the flash so it will take pics at night? and what does PIR mean on the menu shouldi set Hi Lo or Med?
hi ,ill be suprised if theres a flash , it should just automaticly switch to night vision using infra red light,, as for PIR,,p.i.r stands for
passive infra red,, its like a beam that when disrupted will switch something on , in your case, "take a shot"the high medium and low just refer to sensitivity,,mouse , cat, dog . elephant ,
Oct 15, 2013 | Wildgame Innovations Axe 2 2Mp Game Camera
TZS-2
The voltage should be good. It is possible the Infra-red emitter tube might be at fault.
The night vision can work under a full moon, so test the vision part to make sure it is working correctly. If you have an infra red/IR remote control for your TB set, you can test the might vision using that remote to see if the night vision is working.
You can use a second working unit to see if the illuminator is actually working. The illumination is not visible light without assistance.
Jan 31, 2012 | Kalinka TZS-2 'Sova-2' Russian Night...
Why in total darkness does the unit just flicker with no picture? with infrared it works fine
these units need a very small amount of light to work at all, They amplify this small amount of light, with no light at all they have nothing to amplify! the infra red is a source of light so it can amplify that, At night they amplify street lighting or moonlight or starlight etc, hope this helps,
Sep 19, 2011 | Yukon 24021 Monocular
I have an Optimus H-5210 Infra-Red Heater and it's working great but last night while i slept, the pillow felt on top of it, burned a hole and i couldn't get the heater to turn back on. Is there a reset...
god please be carfull thousands of home fires start like this!!!!!!!
My guess is that a high temp cutout has opened. most likly it is not replacable.
Google search your model number / owners manual to see if there is resettable overtemp.
I was unable to locate but you may have more luck.
Remember infra-red heat warms items and objects in the room by absorbtion of infra-red waves this heater should not be near any flameable items! its designed to sit like 6 feet away from any thing and items in the room absorb heat energy then give it up to there surrounings.
please be carefull....
Mar 10, 2011 | Optimus H-5210 Infra-Red Heater
Power light turns on, Infra red illuminator works, cant see anything in scope. Reticule doesnt light up and no vision through optics. New battery etc.
Hello, bad image intensifier tube and possible ccfl with it coil. Major repair on MK238 scope. I think they make a generation 2 tube for this scope like 350,360,390, and 410. Call AT ATN. stewbison
Mar 04, 2011 | AMT Datasouth Aries MK238 Weapon Sight
My Night Owl Cyclops NOCC3 night vision monocular wont pick up the infra red light properly so I can't view anything at night!!!! I haven't the lens cap off in light only when it's dark out and it won't...
Hello, is the IR glowing red, don't look into the IR lens. Just place your hand in front of it and see the is a red glare on your had. If there is a red glare then IR is work.
Another thing when you taking a look see through the Night owl NV monocular there should be a green glow from the image intensifier tube, if not, then the NV monucular isn't working properly. stewbison
Feb 21, 2011 | Night Owl Optics Cyclops Compact NOCC3...
Sony trv18e a few things don't work
Night shot light is "Infra Red" and you can not see it directly though camera will shoot in darkness if you slide ON Night-Shot switch.
Regarding playback volume problem, I think built-in speaker is defective ( open ) and needs to be replaced.
Let me know if you want some more info.
Feb 16, 2009 | Sony Handycam DCR-TRV18E Mini DV Digital...
SWANN PRO-535 Multi-Purpose Day & Night Indoor/Outdoor Security Camera Logo
367 people viewed this question
Top SWANN Home Security Experts
Electro Med Services...
Da Doc
Outback Jack
Outback Jack
Are you a SWANN Home Security Expert? Answer questions, earn points and help others
