Question about ViewSonic VSD220 22 Touchscreen Smart Display - TI Dual Core CPU
Why wont this device start up?
It shows a green light on the power button and the screen shows it on with the the three birds.
My kindle will not turn off
Did you try
Instructions
  1. Frozen Screen or Unresponsive Kindle
    • 1 Unplug the Kindle.
    • 2 Move the power button to the right and release. You should see a green LED light for two seconds.
    • 3 Move the power button to the right and hold for five seconds. The green light should blink three times and then the screen will go blank. Release the power button after it does.
    • 4 Turn the device back on by sliding the power button to the right and releasing it.
    Perform a Hard Reset
    • 5 Perform a hard reset if the previous steps are unsuccessful or if the Kindle screen is showing lines.
    • 6 Slide the power button to the right.
    • 7 Hold for 15 seconds.
    • 8 Recharge the battery if the device continues to be unresponsive.
    • 9 Restart the Kindle after charging.
Read more : http://www.ehow.com/how_7655306_reset-kindle-3g.html
Jul 29, 2014 | Amazon Kindle 3G
Htc first won't boot
Try holding volume Up and volume down together then the power button----hold all three until vibration starts.......that should get you to a factory reset.
Dec 04, 2013 | HTC First Android Smartphone AT&T Locked
Tv powers on, see three birds in color then flickers and fades to white
The problem must be with its main digital processor board. It will be best to make it confirm. Contact any service technician. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | ViewSonic N1930W 19 in. LCD TV
Screen won't turn on
You can try to do the monitor self test.
Monitor Self Test:
1. Physically test the monitor autonomously from the computer.2. Switch both the monitor and the computer off, and then disconnect the VGA cable le from the computer.3. Turn the monitor on, pressing the power button for about three seconds. The self-test screen will come up .4. If the image is clear, bright, and shows red, green, and blue, the monitor is working properly. Video issues may be due to the video resolution in the computer, and not the monitor.5. If the image is not apparent and intense or the colors are not accurate, then the trouble is with the monitor or some of the (OSD) settings. In this case, test your particular monitor's information for OSD.
It is always important to check the color of your power light for so you can distinguish if the monitor is defective. Getting red lights on the the power panel states that the power section of the monitor is faulty.
Dec 03, 2011 | Emerson Televison & Video
My xbox360 powers up with a green light from the middle and thats it , it don't work or connect to the controllars (not wirelessly or by the usb port) . and the four circling light don't work .please help
switch the xbox off and if you have any hard drive etc connected to the xbox or usb devices disconnect them , then switch it back on while holding the sync button, the one you press to pair the controllers with , hold that for 30 seconds and then release it, see if it will show up on the tv. If it still wont show anything on the screen , check all cables, borrow one that you know is working to try on it. if that doesnt work try another power supply. The best way to test it though is to take it to a friends and unplug there xbox and use their leads and power supply to see if yours boots up. Another check you can do is hold the sync button in and press the eject button , if an error is happening the ring of lights will change , you need to press eject 4 times, without letting go of the sync button, each time you press it the red lights will come on, code is as follows
Four lights =0
three lights = 3
two lights = 2
one light = 1
so if you get 433
then your secondary error code is 033
reply with what your error code is here
Apr 16, 2011 | Microsoft Xbox 360 Console
I have forgotten N78 phone lock code can you help me
Do a hard reset but keep in mind this will restore to its factory default settings
Turn off the mobile phone.Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button.While holding these three buttons, press the power button to switch on the device.Release your fingers when the screen displays the Nokia Logo and the language selection menu further.
www.usedcellphoneshop.com
Jun 07, 2010 | Nokia N78 Smartphone
Tom tom wont switch on
try a battery replacement
Jul 24, 2009 | Tomtom ONE 3rd Edition GPS
Canon pixma mp-610
Try resetting the printer:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Jul 19, 2009 | Office Equipment & Supplies
MY ARCHOS PLAYER WONT WORK
Just watching a movie and my archos just froze in mid play , did a switch off to rest it and guess what it wont restart , ses ARCHOS in green at the start but wont reeboot have tried the reset button inside but no joy what so ever , any tips or advice 'or shall i just ship it back to Archos ....
Jan 05, 2008 | Archos 605 WiFi Digital Media Player
ViewSonic VSD220 22 Touchscreen Smart Display - TI Dual Core CPU Logo
545 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
