Question about Boating
How do I set oil mixture - Boating
    Champion:
  • 238 Answers
Hello Corry,
What Make And Model Is Your Engine?
Posted on Apr 04, 2015
    Sergeant:
  • 186 Answers
It depends on the engine. Inquire at you local boat dealership or call them.
Posted on Apr 03, 2015
I have a 2002 Blazer and it is hard to start we replaced fuel pump,fuel filter,crank sensor unit , oil line ,oil pressure Gage, did Tune -up Rotor button ,rotor cap wires spark plugs
by not running the fault codes first , you have missed the real faulty sensor that is causing the problem
nothing of what you replaced is linked to hard starting, like , ambient temp sensor ( used to report the air temp for the setting of the rich mixture need for starting)
baro sensor ( used for reporting the air density used to set the mixture setting
Maf/ Vaf sensors ( again used for mixture settings)
heated oxygen sensors ( used to adjust the gas composition by reporting the results to the ECM
May 06, 2017 | Cars & Trucks
Need to know; oil mixture spark plug setting for a homelite textron 330, ser.#3D2360270, Ut#10609
Hi gandp1993..
50 to One...oil to gas ratio 1 pint of 2 cycle oil to 6 gallons of gasoline.
Spark plug setting... .28 - .32
Please take time to rate me
Sep 22, 2011 | Garden
Gas and oil mixture in car, car won't start?
BAd headgasket or you have a bad cylinder. You need to have a compression check done on your vehicle
Jun 24, 2011 | 2003 Mitsubishi Montero Sport
What is the fuel mixture?
hi there
pfrolander
the ratio of oil to petrol you should use is 50:1 ( that is 20 mils of hi quality 2 stroke oil per 1.0 litre of petrol you mix ) using hi quality sthil / husqvarna 2 stroke oil
1000 divided by 50 = 20 mils of oil per 1.0 litre of petrol
NOTE if you do not have any hi quality 2 stroke but some from your local garage ( that you may use in say a scooter for example use 40 mils of oil per litre it is richer
this will do the job
cheers hope it helps
May 27, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
What kind of gasoline?
  1. Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
  2. Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
  3. Pour the proper amounts of gas and oil into a fuel can. Shake the can well to mix it.
  4. Label your gas can with the mixture ratio. You can use the same mixture for other two-stroke engines.
  5. Shake your fuel can thoroughly every time you refuel. After a while, the oil will settle out of the gas, and shaking it up ensures that the oil and gas are properly mixed again before you put the fuel into your chainsaw.
Mar 06, 2011 | Garden
Do not know what mixture or how to use
40:1 mixture for the fuel:oil ratio.16:1 will cause your saw to barely run(if at all) and if it does, will fog out every mosquito for 4 blocks. You can use any reputable 2-stroke oil, though stay away from outboard engine oil. Get the good stuff that says Stihl, or Husquavarnah, or something like that. Even the Homelite stuff is ok. The oil tank takes regular bar and chain oil.
May 30, 2010 | Homelite ZR10926 16 Chain Saw
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I lost my manual-what is oil mixture ratio- I changed my setting when I went to Colorado this past summer I need them reset for lower elevation Where should they be turned to
The fuel to oil ratio is 50 to 1. Both mixture screws will need to set somewhat richer, about 1/8 to 1/4 turn each CCW. Proper setting for H is so that a warm engine running full throttle will 4-stroke, but 2-stroke immediately when cutting. L should be set so that the engine idles fairly smoothly, but will 'follow-the-throttle' when accelerated. These mixture screws have special 'D' shaped heads that prevents owner tampering--only authorized service agencies have the proper tool (I made my own D head driver!). Hope this helps!
Apr 01, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Fuel/oil mixture
3.2 oz oil in one US gallon yields 40:1 mixture.
2.6 oz oil in one US gallon yields 50:1 mixture.
Jan 15, 2009 | Humminbird 140c Fishin' Buddy
Boating Logo
57 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
