Question about Senco FN65DA F-15 15 GA Fusion Finish Nailer
I have a senco f-15 cordless nailer it makes a noise as i try to shoot but won't shoot how do i fix
    Top Expert:
  • Senco Master
  • 51,188 Answers
Suggest you contact them LINK http://www.senco.com/contact-us
Posted on Apr 03, 2015
Senco nailer won't fire nails, but the firing pin dents the wood almost 1/4 inch.
Hi Jes,
Are the nails moving freely in the magazine if you pull the mag spring back? If so, then the driver blade is not returning to top dead centre - leaving enough of the blade to stop the next nail moving into the nose. This could be caused by a slight back pressure in the cylinder so, check the exhaust is clean and free of any swarf. Or check the O Ring on the driver blade, even though you've just replaced them....
Mar 01, 2013 | Senco & Frame Pro 601 Framing Nailer
Wont shoot nail every time pin wont return all the way up
Some reasons the driver/piston assembly won't retract fully:
- damage to the o-ring (LB1003) around the piston
- cylinder (BA0165) is scored badly
- driver (EA0167) is bent, twisted or warped
- o-ring (LB1023) around bottom of cylinder (in groves & covering small holes) is stretched out or out of place.
- Seal (BC0492) at bottom of cylinder & under bumper is damaged or gone
Aug 11, 2012 | Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2...
Senco Finishpro18 just stopped shooting nails. Took it apart put it together. Shoots a couple of nails then stops. Press the nailer against the target pull the trigger and air comes out of the handle.
I just had the same problem with mine. Exact same symptoms. My guess is that your gun hasn't been used in a while.
I called Senco and they recommended removing the top cap, removing all o-rings (one at a time) gently stretch them, put a small amount of lithium grease in the o-ring track, and replace the o-rings. This fixed my problem and I hope it fixes yours!
Senco has awesome tech support for their tools. I will not buy another brand because of their support. 800-543-4506
May 15, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
Senco 601 nailer shoots 2 nails each time the trigger is pulled.
the 601 had a design flaw, in the nose, where the nails hit as the are being pushed forward, the peice was made out of a peice of metal that was too soft, it wore down and that is where you get the double nail problem.
Senco offered a trade in, this was years ago, for a limited time and gave us credit towards new guns, which we gladly did
Dec 31, 2009 | Senco & Frame Pro 601 Framing Nailer
SENCO COIL ROOFING GUN DOESNT ADVANCE NAILS EVERY THRID OR FOURTH NAIL DOESNT ADVANCE
Clean the track and piston by removing nail tray (there are a couple of allen screws)and removing the gunk from the nail tape and if you have been shooting something glued that to. Remove head assembly and thoroughly clean and oil that also. that should fix you right up I have a couple of these guns and that is typical.
If that is no the problem rebuild the gun it is worth it as they are a great air gun
Hope this helped
Dec 15, 2009 | Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2...
Shooting two nails instead of one
i would double check the plunger to make sure its resetting after each fire.
Oct 30, 2009 | Senco FP18 FinishPro 18 - Gauge Brad...
Senco FN65DA F-15 15 GA Fusion Finish Nailer Logo
359 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
