Question about Electric Garden
Where can I buy a replacement starter key for my electric mower
  • shadowchb Apr 03, 2015
    Hi Elizabeth Haslam, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Give the manufacturer and model number from the name plate on the mower.
2 Suggested Answers
SOURCE: Electric Starting Difficulty on Toro mower with Tecumseh engine
it sounds like to me that the starter pully is getting caught up on the worm gear ,this could be because of dirt or grass getting in the way make sure that no grass or dirt is around the worm gear
Posted on Mar 04, 2010
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
42 craftsman rider electricity at solenide non at starter.
Check power at solnoid on cable coming from battery. 12-13V. With key turn to start should have 12-13v
May 22, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Can I add a electric starter to a 173cc MTD engine
possibly but the cost of fitting a starter motor,flywheel with ring gear, ignition switch,charging coil,wiring and battery would cost almost as much as buying a new key start mower!!!
Jun 05, 2014 | Mtd Garden
Toro Electric Start Problem
Remove spark plug and observe condition. Fouled with oil, bad motor. With plug removed pull rope several times to blow out cylinder. Spray WD40 in spark plug hole, pull rope several times see if oil blows out. Spray a lot of starter fluid in spark plug hole, replace plug. Spray starter fluid in air cleaner area of carb, try to start. Replace spark plug, try to start. Ensure oil is full, all mowers have a low oil sensor now. 30w oil. Always use Stabile in gas.
Jul 04, 2012 | Toro Garden
When I try to start engine, the fuse is go out. I think that the problem is between start switch and starter. When apply gasoline directly to carburator and start the engine from starter, it run...
This machine is known for electrical problems.
The PTO switch is not high quality and tends to short out. Your model's key switch, if plastic needs to be replaced every few years becuase wear on the components tends to cause shorts in the electrical system. Last but not least check the resistance of the PTO clutch coil. It should be no more that 8 ohms resistance. If so replace it too.
You can buy parts for a good price from a store like www.arcolawn.com. They sometimes have better rebuilt or aftermarket parts.
Dec 15, 2010 | Craftsman 21 Hp 42" Lawn Tractor Riding...
Mar 03, 2010 | Garden
PLEASE HELP! My husband is driving me crazy about Riding Mower
Sounds like the gear on top of the starter is stuck or broken. Inspect starter. If it's broken, the starter must be removed to replace the starter drive. You may need to buy a Starter Drive Kit. If you starter has a flat piece on top held on by a retaining ring, it's part # 696541. If you have the older type starter with roll pin holding the drive on, you need part # 696540. You probably have the first one. To install the retaining ring, use a 3/8 socket to tap it into the groove. Dwain
Jun 17, 2009 | Briggs & Stratton Garden
Toro Electric Start Mower Barely Turns Over
this is easy to point out the problem. if it is still under warranty get warranty replacement of the starter is not you might be better off just buying a new mower might be easier and cheaper because if your not still under warranty with it it will cost you quite a bit of money if you can't replace it yourself it will cost you the amount of the new starter and it will cost you the amount that the shop's labor fee which can vary a lot depending on where you take it.
Jun 13, 2009 | Garden
The electric Starter motor will not stop running
If the starter continues to spin after the engine is started..replace the key switch, it is bad
Apr 10, 2009 | Garden
Garden Logo
Top Electric Garden Experts
dannydoesita
JohnPaul Robertson
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
