Question about Asko W620
I love my machine, but lately it stops on the letter C alot, but not always. It still washes well. I have checked drainage, bits blocked in it, and cleaned the bars inside the machine
How can I stop my washing machine end indicator light coming on before cycle has finished?.
sound very much like you have a blocked pump or a drainage block. If your machine outlet is connected to a push on spike under the sink, remove it and check Its not blocked. If that is clear CAREFULLY remove the filter cap, Usually on the bottom righthand side of the Machine. I say carefully because if there is water in the Machine it will pour out and flood so do it a bit at a time till its empty. Check the filter it may be clogged up, if it is thats your problem if not it needs further investigating. time to call the repair man. By the way whilst you may have economy 7 I would never advise putting your machine on at night and going to bed if anything should go wrong you are not there to switch off, Ive seen some real nasty stuff over the years where machines have gone rogue unattended, it really isn't a good idea although Thousands would disagree.
Aug 03, 2014 | Tricity Bendix Washing Machines
My asko w6222 shows F3 and stops. What is an F3 - some kind of error?
Drainage error
If F3 is flashing on the display, there is a
drainage problem. Check:
• that no objects are stuck in the drainage
hose outlet.
• that the drain pump is not blocked by foreign
objects. Clean the pump (see the
"Care and cleaning" chapter).
• that there are no kinks in the drainage
hose.
After taking the necessary action, run the
Drain program or press the Door Opening
button (key symbol) to empty the machine. If
the problem persists, contact the Customer
Care Center at
1-800-898-1879
www.askousa.com
May 30, 2008 | Asko Washing Machines
Washing machine wont complete drainage at end of wash cycle
Look under the washer tub where the drain hose comes out and attaches to the pump. Your pump impeller is either clogged or worn out. Try removing the pump and checking from there.
Jan 07, 2008 | Fisher Paykel EcoSmart GWL15
Bosch next 500 series stops mid-cycle
I had a similar problem, after ruling out the following
kink in drainage hose
no blocking of filter
drainage pump ok
ok we eventually found out it was the heater, sounds strange I know as you would not necessarily relate the heater to mid cycle stop an drainage problem....but it sorted ours
ours hope this might help
help regards R
Apr 15, 2014 | Bosch Nexxt 500 WFMC3301 Front Load Washer
All lights flashing
Try powering off the machine using the main power switch for at least 10 seconds, then power back after holding down the top solo and start/stop simultaneously.
You may need to check the drainage pipe and water inlet for blockages. Under the filter inside, you can remove part of the drainage system by removing the silver clip and pulling on the plastic segment.
Wash this through, it has a lovely ball bearing inside, but don spend too long wondering how big it is. Big it is.
Check the tubes, for kinks etc... Always disconnect the water supply before detaching the inlet, and be prepared for a mess, if you do decide to remove the drainage outlet pipe.
Failing this, the following post may help:
Check out this solution to the Miele 24 in G646SC Plus Free Standing...
Feb 18, 2014 | Miele 24 in. G646SC Plus Free-Standing...
Hi Ihave an electrolux EWD 1477 washer/ dryer. It keeps showing up an error 20 (E20) and starts beeping and stops working? Any ideas what it could be? Thanks kindly
Drainage problem. If it is a new installation the possible causes can be:
- The drainage hose is too deep in the drain (can only be max. 10 cm. in the drain, and the drain height may be a minimum of 30cm and a maximum of 80cm from the floor);
The drainage pump may be blocked (clean it);
- The drain is clogged.
You will LOVE Electrolux for this... Go to:http://electrolux.co.uk/en-gb/Support/Troubleshooter/?Command=Detail&CategoryId=98&SymptomId=1412&DetailId=1412
....and click on START ANIMATION for a complete explanation of how you clean the filter on your machine
Jun 23, 2011 | Electrolux Washing Machines
Washing machine drainage blocked how do you find the blockage
remove the hose that lead in and out of the drain pump.make sure to check the hose that comes from the bottom of the tub to the drain pump.also look in the pump for anything small that can stop the pump from turning.
Mar 14, 2010 | Washing Machines
Display reads "pump blocked"
TURN OFF MACHINE AND UNPLUG THEN DO THE FOLLOWING:
Open the pump filter cover:
23294f2.png Remove and uncap drainage hose to empty detergent and then replace the cap.
Unscrew the filter and clean it, inspect the filter cavity inside the machine for matter that might be blocking it. Check the waste hose that leads out of the machine to see if there is a restriction somewere.
Oct 15, 2009 | Siemens WM14S794GB Front Load Washer
Not emptying
i have just had the same problem, u need to check that the drainage pipe is not blocked if that doesent work check that the pump that sucks water out of the machine is not blocked(this pump is inside the machine at the end of the drainage pipe)it probably has some blockage in there x
May 01, 2008 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
