Question about Hilti Drills
Hpw do i change from drill to hammer on hilti te 22
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
The "sleeve" below the chuck slides and twists.
If it is in the forward position it's in drill mode, because the chuck can't hammer, pull it back and it will be in hammer mode.
(the picture shows the black plastic sleeve in the forward position, which can be pulled back over the metal that is still exposed)
Hpw do i change from drill to hammer on hilti te 2 - 7a08aef7-a85d-4ded-8ada-fcaa111c3009.jpg
Posted on Mar 31, 2016
rowdy45176
  • 2176 Answers
SOURCE: Hilti TE-60 hammer drill
what I would do if you have a fax machine is call 1-800-879-8000 and request a schematic on this tool first. Some of their products are not that easy to disassemble. I never have worked on the TE-60 but have on some of their other products and they are all different. Hope this helps
Posted on Dec 19, 2008
  • 123 Answers
SOURCE: hilti te-72 hammer failure
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
Posted on Oct 09, 2009
  • 165 Answers
SOURCE: Hilti TE 10 drill. It doesn't seem to hold the
Probably a missing ball problem---contact Hilti website.
Posted on Feb 27, 2010
ftw1952
  • 10319 Answers
SOURCE: Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Posted on Mar 11, 2010
  • 123 Answers
SOURCE: te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Posted on Jul 23, 2010
My friend gave me a hilti T22, what kind of bits do I need for it?
Is it a TE-22?
If so check out
http://www.bamanufacturing.com/page_ref_6.htm
Looks like TE-22 uses tapered shank bits
a TE-22P uses SDS plus shank bits
I'm not familiar with a T22
Dec 11, 2014 | Drills
What hilti hammer drills use TE-C bits? I want to buy one
TE2, TE4, TE6, TE7, TE30, TE40. The 30 and 40 are only corded, (not cordless).
TE-C bits come TE-C (standard head) and TE-C3X which is a high performance bit. SDS is the industry term for this connection.
Dec 09, 2012 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Reset service light on hilti te 706
I have one Hilti Mechie , TE 706 Avr, Now Red Light Only Blinking ,Mechine Not Working
Jun 12, 2012 | Hilti TE 70 Hammer Drill Performance...
Where can I get parts for hilti TE 22 and UH 650
http://app.xtremelocator.com/custom/hilti/SearchForm.php
Well, I would follow this link and put in your zip code. Call the service center that is closest to you, and see if they have the parts that you need. I do know that the TE 22 is discontinued, but there may still be some parts on the shelf.
Here is a link to the breakdowns. You will have to select > and then >
http://www.us.hilti.com/holus/page/module/home/browse_main.jsf?lang=en&nodeId=-114925
Nov 21, 2010 | Hilti 284228 UH 650 Universal 1/2" Hammer...
Te70 hilti hammer drill
Jul 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Mar 11, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Feb 27, 2010 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
Need brushes for an old style hilti te17
Hilti should be able to provide you with them. If not contact a local motor repair outlet and find brushes the same size, they are very easy to change on the TE series.
Failing that Hilti offers a trade-in program for their tools.
Dec 31, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Drills Logo
381 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
