Question about Garden
When im riding engine cuts out like im out of gas then dies ,with full tank after a few minutes will restart
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Check the fuel filter. If it is mostly clogged, you will get fuel through, but not fast enough to keep going.
If it is pretty old, the fuel lines might be ruined by ethanol in the gas. The inside of the old rubber lines looks like the rubber has melted. New fuel lines are made of material that is resistant to ethanol. Anyway, fuel should flow like water in a pipe. If it is sluggish at all, replace them.
Clean the carburetor. It sounds like the float is not moving right. It runs out of gas and doesn't refill right away. After it sits for a few minutes, it slowly refills, then you can go again for a short time. This is a shot in the dark for this problem, but I have solved 90% of running problems by just doing a quick carburetor cleaning.
Posted on Apr 02, 2015
How do I cure vapor lock?
If you're getting vapor lock, the bike will die after a few miles, and not restart for several minutes.
If the bike dies, immediately remove the gas cap and see if the bike will restart right away.
You could also ride it without the gas cap (try it on a tank that's 1/4-1/2 full, NOT fully full, because of gas splash) and see if it doesn't die after a few miles.
May 07, 2014 | 2001 Harley Davidson FLSTC - FLSTCI...
Engine starts runs well but after 45 minutes or so will die . I can choke as it starts to die and engine will continue running.When it dies will restart easily.Ihave replaced gas filter ,cleaned tank,new...
Carb. needs to be rebuilt. If your choking the engine it to keep the alive and you've cleaned and replaced everything else, I would recommend carb. overhaul.
Sep 23, 2013 | Garden
My YTH24V48LS will run good and mow for approx 30 minutes then just cuts out and the engine stops all of a sudden. It has done this from 1st purchasing it. The BRIGGS engine seems to run extremely hot as...
I had this same problem. Make sure fuel Cap is not too tight. There is three grooves on the backside of cap to let air in tank but if you tighten cap to hard it crushes these grooves to a tight seal. When vacuum in tank finally reaches same level as carburator suction then fuel flow stops and engine dies. When putting gas cap on just give it a spin and then maybe a 1/4 turn just to snug it. Next time it stalls take gas cap off and you should not hear air gushing in. If you do your cap was too tight and it will now start right-up.
Aug 26, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My yamaha 250f will crank right up then as im riding it, ut will cut off while in on the trail. sometimes it wont crank back up and have trouble strating it up..how do i fixs this????
Need more info on this one - how long do you get before it dies or is it dieing fist few minutes does restart again once engine cold (ie next day) is it regular does it do this every ride or has just happened couple of times lately is it running well then dies or is progressively running bad then stops
May 20, 2011 | Yamaha Fuoco 500 Motorcycles
Had a problem with my Sears riding mower late last summer. It runs for like 5 minutes then will conk out. I wait 5 minutes 10 minutes or so, it starts up and conks out again like after 3-4 minutes. I...
check your gas tank cap, it is vented, if it gets clogged up fuel will not flow properly and engine dies of fuel starvation. By waiting a few minutes you have allowed the pressure to equalize in the tank enough to get enough fuel for engine to run.
Mar 05, 2010 | Garden
While driving, the engine will lose power, as if the key were being turned off and on till it dies. After stoping for a min or two, the engine will restart, running fine again. Start driving again, and a...
Gas Cap. Sounds like the vent in the gas cap is stopped up. As the fuel flows out of the tank, a slight vacuum builds up. When the vacuum gets high enough, no fuel flow, engine dies. Let it sit for a minute or two, you get to go through the whole thing again. Kinda like the movie "Ground Hog Day". Try loosening the cap and going for a ride and see if that helps. Don't have the tank completely full. You don't want a lap full of gasoline. That could get uncomfortable fast. Oh yeah, I wouldn't advise smoking either or you'll look like the "Ghost Rider".
If you're running a fuel filter inline, this could be a problem as well. If you've gotten hold to some nasty gas, it could have your fuel filter nearly stopped up.
Also, you're bike is equipped with a vacuum operated petcock. The vacuum from the engine opens the petcock. I've seen lots of these petcocks fail. Check it with a hand operated vacuum pump or replace it with a pre-1994 model. I like Pingle petcocks the best.
Jan 19, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
Mower dies after running for a few minutes
It sounds like the carburetor is running out of fuel.First make sure the tank is full then loosen or remove the gas cap when it starts sputtering to see if that corrects the problem. Then with engine off remove the fuel line that goes from the tank to the fuel pump,hold it low and see if any fuel flows out of it,if not lightly blow air backwards to the tank,(with fuel cap off),then see if the line is plugged. Next remove the fuel line that goes to carburetor from the fuel pump,crank the engine and see if any fuel flows,if so the carburetor should be cleaned by removing it and disassembling it.
Aug 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Motorcycle dies while riding,like gas is cut off
Check fuel pump. You might have a bad diaphragm.
Jun 02, 2009 | 2002 Honda VT 600 CD Shadow
Idle engine cuts out
You need to get to the idle screw on your carb and srew it in until your idle raises up a bit, also put some Techroline (chevron) in your gas tank...1/2 bottle in Full tank.....Good luck to you friend....Tim
May 12, 2009 | 2003 Suzuki UH 125 Burgman
93 gsxr 750. engine dies after riding a few miles
Does it restart after a few minutes?
Then, check the fuel filter and hoses, could be clogged ;-)
Mar 25, 2009 | 2002 kawasaki ZX-6R
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
