Question about Humidifiers
Why does my machine keeps turning off - Humidifiers
  • 739 Answers
This question needs to supply more information than it currently does. Who manufactured your humidifier? Model of your humidifier? Details about when it 'shuts off', such as water level, temperature, etc.
Most humidifiers are designed to shut off when conditions reach an unsafe condition, such as water level too low. Generally this is sensed by some sort of float telling the device to shut off. Another method used is by monitoring the temperature in the device, after all 'humidification' is done by evaporating water into the surrounding air. If the temperature rises above 212 deg f (boiling point of water) it thinks there isn't any water left to add to the air so it shuts off for safety reasons.
The best course of action is to contact the manufacturer directly for details.
Posted on Apr 03, 2015
Humidifier spits out water rather than steam.
Descale the boiler. You do that by putting vinegar in as you would water, start the machine until is starts spitting water then turn off for 30 or so minutes. Turn it back on and let it run. If it stops spitting, dump out the vinegar and flush the boiler with water until you no longer smell vinegar.
Nov 28, 2016 | Humidifiers
Why does it make a constant hissing sound?
The fill valve inside the humidifier is leaking. This is a common failure as the valve clogs with mineral content from the water.
Jan 28, 2016 | Honeywell he225h8908 bypass humidifier,12...
Aprilaire 760 keeps running
Is this a newly installed unit it sounds as if there's a wiring issue. Could you show a picture of the wiring terminals. If this is not a new install try turning of your furnace fan.
Nov 02, 2014 | Aprilaire 700 Humidifier
My vaporizer keeps blowing my fuse
it has a short in it. if you are electrically minded you could open it, and try and find where, (probably an element problem)
Nov 12, 2013 | Vicks Warm Steam Vaporizer 1.5 Gallon...
General Aire 1137 Humidifier fan won't engage.
the lubracation used in the fan motor has an expected life of 5 years... once the lub is gone from the oillite bearings then the fan will stop .. you can put a couple of drops of oil on the motor bearings if you can get to them .. spin it by hand a few times to distribute the oil ... dont use WD40 or Teflon filled Oil .. use a light non gumming machine oil .. since you cant get that oil to permiate the porous bearings (done in a vacuum) then you will have to relube every year or so to keep it going .. you could replace the motor but that might not save much over a new unit .
Dec 23, 2009 | Humidifiers
Keep running
You should have a #50 relay hooked up to the main blower assembley to turn the 24 volts on and off with the blower to the humidistat. Alot of humidifiers sold do not tell you about the #50 relay. They assume that you are a hvac pro and you aready know about.
Good luck
HVAC Teacher
Mar 02, 2009 | Aprilaire 600 Humidifier
Water keeps running to Honewell 360A Whole House Humidifier
You may need to replace the valve that is wired to the furnace that controls the water flow
Feb 01, 2009 | Honeywell HE360A1027 Whole House...
Water Wheel won't keep turning
This humifier has a black drive wheel and a white idler wheel. On mine, the idler wheel froze up which caused the drive wheel to damage itself trying to turn the drum. First, free up the idler wheel and replace the shaft it rotates on. The idler wheel is still available but you'll have to fabricate the shaft using a machine screw and hollow shaft from your local hardware store. When the idler wheel turns freely, the drive wheel (if still in decent shape) can do its job of turning the drum. If not, you can replace the drive wheel (also still available). I recently put a small rubber band in the groove of the drive wheel and it enabled it to get the necessary grip on the drum.
It's getting harder and harder to keep these wonderful Bemis water Wheel humidifiers alive as the years go by. I wish they still made them because no other humidifier comes close.
Rick
Dec 18, 2008 | Bemis 4D7-800 Humidifier
Humidifiers Logo
520 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
