2 problems with TV (LG PLASMA model # 42PC5D-UC) 1) TV blurry (see pic below) 2) EZ scan only finds 18 channels
  • 739 Answers
Looks like you have a bad connection between your TV and your signal source....
Are you on cable? satellite?
all it takes is one bad connection to wipe out 90% of your signal...
Posted on Apr 03, 2015
SOURCE: LG 42in plasma - Green dots on HDMI channel
Cheers mate, is there anywhere you cold think of that would be able to deal with these kind of problems at all?
Posted on Feb 20, 2008
  • 814 Answers
SOURCE: LG Plasma TV 42''
These problems are probably bad inverter board that supply the inverted voltages to the back lights. It also could be a failure of the back light itself. This problem should be taken to a service center, where they can test the inverter board and the back lights. You can got to the website of the product and check out the frequently asked questions to see if your problem or similar one have been posted and answered. Hope this helps you with your problem.
Posted on May 14, 2009
  • 668 Answers
SOURCE: I have a LG 50PX1D-UC plasma TV with a black vertical line
You could have a Driver Board that has a loose connection or a Ribbon Cable that has a intermittent connection to the Plasma Panel, or a defective Plasma Panel. Either one could cause the problem and I would recommend only a Qualified Service Person to check it out.
Here is LG's Customer Service Number. 1800-243-0000. They could direct you to a Local Service Facility.
I hope this helps,
Sky Assoc
Posted on Oct 25, 2009
dbTVfixer
  • 79 Answers
SOURCE: channel scan only finds 1
the LG will scan several tuning bands TV, DTV, CATV, CADTV
you must let it work through all of these in programming mode.
use the channel up and down button to see just what it has picked up.
the Manual Channel menu will allow you to add or delete what channels you want to surf.
if your programming in unsuccesful, unplug the TV (power) for five seconds then plug back in (reboot)
and attempt the complete setup all over again.
if it still fails, your tuner is bad...which means you need a new main board.
Posted on Apr 13, 2011
gopakumarg43
  • 74459 Answers
SOURCE: factory reset of lg 32lc2d
Hello
you want to reset all parameters of your TV to Factory default, I assuems and posts this solution.
1. Press the "Adjust" button on the remote handset; press "Up" or "Down" button to select the "Reset" option.
2. Press "Enter " button and Use " >" or "<" button to select "Yes".
3. Press "Enter" button.
All parameters will be set to its original Factory Defaults.
Posted on Feb 06, 2012
Need to retune free view as has never been done since buying
Hello
To retune your Lg tv, do the following. At first connect the antenna socket at its back side with antenna firmly.
hannel Search
Automatically finds all channels available through antenna or cable inputs, and stores them in memory on the channel list.
- Run EZ Scan again after any Antenna/Cable connection changes.
- A password is required to gain access to EZ Scan menu if the Lock System is turned on.
1. Press the MENU button and then use UP/DOWN button to select the SETUP menu.
2. Press the FORWARD => button and then use UP/DOWN button to select EZ Scan.
3. Press the ENTER button to begin the channel search.
Allow EZ Scan to complete the channel search cycle for ANTENNA, and CABLE
ok.
Jan 14, 2011 | LG 42PX5D 42 in. Plasma HDTV
LG 42LB5D-UC cannot find channels when scanning
No,Ur Digital antena not getting a good signal,because of lanscape like hills or big buildings,blocking the signal,that why u not getting good signals,or no signals at all.Buy another name brand digital antena with a stronger signal amplifier.Or buy a digital roof antena,well help or solved these problems.
Mar 20, 2010 | LG 42LB5D 42 in. LCD Television
LG plasma TV turned off, after the picture very light
I think you have a defective power board. the pop sound in coming from the board and giving you a low output voltage. do it yourself price about two hundred for parts.
Feb 18, 2010 | LG 42PC5D Television
42" LG Plasma tv, no picture - black screen, but have sound.
Most a likely a problem with your Y-Sustain board which will then not drive the screen giving a black picture. The fuse on the board may be open circuit & need replaced but most likely you will need to have the sustain board replaced.
Oct 27, 2009 | LG 42PC5D Television
Broken plasma screen
You need your Tv product code wich is located in the back of the TV next to the serial number.
you can get one directly from LG ($500-$800) or you can try EBAY, look for a TV non working with a good panel, it doesn´t matter why is not working as long as the panel is in good condition, the price range is wide but you can get one for $150-$250.
And no you can not use any 42" plasma.
May 16, 2009 | LG 42PC5D Television
I have a LG 42PC5D plasma TV and there's a sound delay on all channels. I'm using a HDMI cable from a Comcast DVR convertor directly to the TV. Is there a firmware update that's needed? If so, how do I...
firmware is mostly used by commercial TV´s, try using your TV with other device or an aerial antenna.
I believe the problem is your comcast DVR convertor.
May 16, 2009 | LG 42PX5D 42 in. Plasma HDTV
LG 42PC5D Sound Lag
Turn the volume on the TV all the way down. Its becasuse you have the sound come from both sources. its kinda fun to play with.
Sep 24, 2007 | LG 42PC5D Television
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
