Question about Hammer Drills
Trying to change from drill to hammer on te22
  • 2712 Answers
SOURCE: hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Posted on Aug 27, 2008
smjdragonfly
  • 79 Answers
SOURCE: Hammer drill will not hammer.
Need a new clutch/tranny. You can find it online - look up tool parts on Google. Tool Parts Direct is a good source. Please rate me
Posted on Jun 18, 2009
  • 123 Answers
SOURCE: Hammer drill will drill but when set to hammer in
Make sure the bits that you put in there are SDS+ bits. You don't have an adapter in the drill do you?
Posted on Aug 08, 2010
emissionwiz
  • 76846 Answers
SOURCE: Dewalt dw511 hammer drill won't hammer, only
The hammer inside the drill head are most likely damaged ans/or broken, it is likely the best thing to do is just replace the tool.
Posted on Feb 16, 2012
H2_Brad
  • 425 Answers
SOURCE: i need a switch and brushings for my HELTI TE22 Hammer Drill
You need to contact a Hilti dealer either in person or online.
Posted on May 18, 2012
Need a cooling fan for hilti hammer drill te22
Claudette,
From my experience with Hilti tools, you have to send the tool back to them for repair. I have not had much luck in getting any parts from them. Sorry!
May 07, 2015 | Hilti Drills
Parts manual hilti te22
Try this page;
https://www.elektrikmotorbobinaj.com/urun/te22-acilim-semasi-teknik-resim/665
Dec 19, 2012 | Drills
For some reason my hilti te 22 is now stuck on reverse any ideas?
Hi David,
This is puzzling, since the TE22 was never designed to run in reverse. Neither can the electronics or the switch be the cause, since they too are not laid out to change polarity. The only cause i can think
Nov 22, 2012 | Drills
How to Replace Hilti TE22 chuck
You put the two flat sides on the end of the cap nut and lock them in a vice. You then put a wrench on the back side of the chuck which also has two flat sides. with the cap nut locked in a vise take the wrench and turn the retaining sleeve which has the two flat sides counterclockwise to break the cap nut loose. When it turns freely take the chuck out of the vise and turn the cap nut off. You then push the ribbed locking sleeve down to access an o-ring. You pull that off and it releases the locking sleeve and two roller bearings. You then pull off the retaining slv with the two flat sides and release the other two roller bearings. the chuck will then just pull off the shaft
Hope this helps
Sep 30, 2012 | Hilti TE 7-C 120V Rotary Hammer Drill
I need a switch and brushings for my HELTI TE22 Hammer Drill
May 14, 2012 | Hilti 284228 UH 650 Universal 1/2" Hammer...
Hilti te 22 no power
Most common for the TE22 was the switch and or cord. To get to handle off take a 5mm allen wrench and take the two screws off the bottem of the handle and then stick the wrench in through the hole in the top of the handle and remove the screw on the inside. Then take the two phillip screws off the side of the handle to seperate the two halves. You will need to take a continuity tester and read each cord from the plug to the switch. If that reads out continue to read the contacts on the switch. The cord you can replace but if the switch is bad there is not a replacment for it.
Hope this helps.
Nov 24, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti te22 trigger problem
the switch for the TE22 has been discontinued for years. Your best bet is to find a used one on ebay. Since it is a double throw switch somtimes you can get away with jumping one side "the bad side" and getting it to work for a while. The cord goes on the top connectors and the motor on the bottom. If you determine that one of them is bad then take the cord wire and move it directly to the motor connection below and secure it with the motor screw. A quick drawing below to show what I mean.
Hope this helps
Glenn
Nov 10, 2011 | Hilti Drills
Borrowed drill runs rotates but does not drill into the wall- has a bit in it. dumb I know- just trying to hang curtains. thks td
How about another really dumb question.... do you have it running in reverse??? Try changing the direction of the rotation...
heatman101
Aug 13, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Drill head
are you saying the chuck .be specific
Apr 10, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Drills Logo
210 people viewed this question
Top Hammer Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
shall39
Level 1 Expert
Are you a Hammer Drill Expert? Answer questions, earn points and help others
