Question about GE Dryers
I need a thermostat and an element for a GE Medallion 850 Electric dryer repair man told me we can no longer find parts for this model it's too old. Anyone know of a website i'm having no luck.
    Scholar:
    New Friend:
  • 123 Answers
In USA
www.repairclinic.com
In Canada
www.reliableparts.ca
Posted on Apr 25, 2015
  • 739 Answers
Try this:
http://www.appliancepartspros.com/ge-thermostat-4-wire-we4m181-ap2044414.html
Posted on Apr 03, 2015
    Sergeant:
  • 268 Answers
Try calling GE Appliance Parts at 1-877-959-8688, or Sears Parts Direct at (888) 930-1491. If they don't have the parts, you probably are out of luck.
Posted on Apr 02, 2015
watugot
  • 290 Answers
SOURCE: Kenmore Electric Dryer Model # 110.62622101
I think on your machine the lower thermostat connected to one terminal of the element, you have a wire coming from the thermal cut off down to the top terminal of the lower thermostat, a wire from the lower thermostat to the timer, and a wire going to the other terminal of the element.
You probably have the wire from the cut-off correct as it won't reach the other terminals. You have crossed the other 2 wires. This caused 240V to short across the lower thermostat and burned it out.
You will need a new Hi-limit thermostat, which will include the upper cut-off as well. They come as a set part# 279816. This will be a little different because the new hi-limit will not connect directly to the element. There will be all the wire ends and instructions with it that you need to get it hooked up correctly.
There should be a wiring diagram inside the console of the dryer that shows which wires go where, but I am sure you have crossed the 2 wires below the hi-limit switch.
Post back if you need any help.
Thanks/Mike
Posted on Dec 02, 2007
Master_Tech
  • 770 Answers
SOURCE: GE DPGT750 not heating
check your email this manual will take you step by step thru the repair
Posted on Jul 08, 2008
SOURCE: Amana Electric Dryer runs but does not heat up - model ndw2330ayw -
I HAVE AN AMANA DRYER MODEL LE8217W2 ITWILL COME ON FOR A SHORT TIME AND THEN CUT OFF. I CHANGE THE BELT, THE MOTOR AND THE THERMOSTAT. THE DRYER STAYS ON , BUT WILL NOT HEAT UP. WHAT'S NEXT ???? PLEASE HELP!
Posted on Nov 06, 2008
TheMobilian
  • 8220 Answers
SOURCE: Electric dryer intermittently doesn't heat
If your dryer has a timer with quick connects which easily plug into it then you can possibly fix this problem. Yank both connects off the timer and remove the timer. Take the 2 motor screws off and remove the plate carefully. Clean the contacts on each leaf switch with a file. Put it back and retry. Sounds difficult but it isn't. Remember only the timer with the 2 quick connects.
Posted on Dec 22, 2008
rickzilla
  • 706 Answers
SOURCE: red dot heating element for electric dryers connect color wires
Hello necie7006,
Please use the link here http://www.pcappliancerepair.com/model-display.php which depicts the heating element configuration . If this does NOT provide you adequate details on how to wire the element, please get back to me and I may be able to help you further.
Regards,
Rick
Posted on Jan 09, 2009
Ge medallion 850 new elements and thermostats still not heating up
see this possible causes:
1) You must shure the heating element show continuity see the video>
2) Test for continuity the thermosta see the video how to do it
3)TEST THE thermal fuse, for open and replace.
4) Test any WIRES for loose, or broken or burn and repair.
5) If anything is o.k see the diagram. You must test the contact from the a) Timer for open, or dirty, or wires loose, broken or burn b) Test the selector temperatur for defective in order to get the heating element to work, and replace if necessary. God bless you
Jun 09, 2012 | Dryers
I have a GE electric dryer and can not find it in this list. Model # = PVXR363ED1WW and it is no longer putting out heat. Any suggestions ?
You have a bad element or thermostat. Check the continuity on those parts if you have a multimeter. Here is a link to show you how you can do this.
http://www.youtube.com/watch?v=_LoYkFc7NuI&feature=related
Nov 23, 2010 | GE Dryers
GE DCXR463EA1WW that has stopped heating.
Probably a bad heating element. Sometimes one side will burn out before the other, so it takes a lot longer to dry. Then the other side burns out and it won't dry at all. Usually thermostats last longer than elements.
Jul 25, 2017 | Whirlpool GEW9200L Electric Dryer
My GE Dryer dries but only after a longer time than before
One of your heating element is probably out of commission. You can replace it cheap. Here's how:
SOME REPAIR PICTURE
Dec 16, 2009 | GE DBSR453EBWW Electric Dryer
GE Medallion 850 oven self-clean instructions
how do i work the oven section i don't understand the settings
Oct 26, 2008 | Kitchen Ranges
Dryer no longer heats up on my Kenmore 417.94812301 laundry stacked unit
On your dryer the common problems found is either you lost some of your electrical power (check your fuse box) or you need a new heater #131475300 about $100 for the part.
Jul 28, 2008 | Kenmore 98702 Stacked Washer/Dryer
Element does not turn off.
  • actually is sounds like the centrifugal switch in the motor is bad.
  • the element should not turn on unless the motor is running.
  • the thermostats are in place to pick up the heat of the airflow, not necessarily the heat directly coming from the element.
Jul 01, 2008 | GE DCSR483EA Electric Dryer
HOW TO FIX A NO HEAT ON A GE ELECTRIC DRYER OVER 10 YEAR OLD
Either one of 2 ways to get to the thermostat on a GE dryer.....
depending on your model, you will have an access point on the back of the dryer to get to the heating element which has attached to it, the thermostat.
If there isn't an access point on the rear of the unit, open the front door of the dryer and remove the 2 screws in the top of the door opening. Using a small prybar, slightly apply pressure prying up the lid. On the inside of the face of the dryer in the corners will be 2 more screws, remove those and pull the face of the dryer outwards to you to about a 45 degree angle. From there, you will be able to lift off the face. Be cautious to unplug the wires for the door switch before pulling the face all the way out. There isn't much to a 10 yr old dryer, just take your time, study the parts and put it back just as you took it apart. For the replacement thermostat or heating element look at
www.marcone.com
www.partstoday.com
Good luck and let me know if there is any more trouble I can help with.
Mar 17, 2008 | GE DCSR483EA Electric Dryer
Dryers Logo
102 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
