Question about Home Security
How do i change the combination - Home Security
  • 739 Answers
Changing combinations for a safe is specific to model and manufacturer. You should contact the manufacturer for a manual.
Posted on Apr 03, 2015
How reset combination lock
1. Open the lock with the factory preset combination of 0005.
2. Find the tab on the end of the part of the locking mechanism that has the numbers.
Combination Reset Tab
3. Flip the tab up (with the combination set to the open combination). When you flip the tab up, you disengage the number dials from the tumblers, so that you can reset the combination without changing the position of the tumblers.
4. Change the combination to the desired combination.
5. Flip the tab back down. The dials are now re-engaged with the tumblers.
Aug 13, 2014 | OnGuard Doberman Series Lock 8030
Is it possible to reset a Manifoil MkIV combination lock without having to send it away to a specialist?
Hi, by reset, do you mean you have the combination but want to change it?
If so, then you need the special combination change key that came with the safe and the instruction manual (there are copies of the manual online if you don't have that)
If the door is open, but you don't have the combination, there is a technique for finding the combination.
amania_r@hotmail.com
Jan 06, 2011 | Office Equipment & Supplies
How do I change the combination on my Unican 1000 keyless lock? thx john
The door must be open.
On models with the passage feature, make sure the passage feature is disengaged: turn knob or key should be in vertical position (A) (see figure 1).
1. Insert the DF-59 control key (B) into the combination change plug
assembly (
C) and unscrew the cylinder by turning the key
c
ounterclockwise. Remove the combination change plug to gain access to the combination change sleeve (see figure 1).
2. Turn the outside knob/lever once clockwise (all the way, until it stops) then release. The latch should not retract (see figure 4).
3. Enter the existing combination. On new installations, use the factory- set combination: depress 2 and 4 simultaneously, (release), then 3
(r
elease). You should feel a slight click as each button is depressed.
4. Insert the spanner wrench as shown in figure 2 to engage the combina- tion change sleeve (A). Gently turn the spanner wrench clockwise to the stop position (a slight click should be felt), then turn the spanner wrench counter-clockwise to the stop position (A) (see figure 3). Remove the spanner wrench.
5. Turn the outside knob/lever once clockwise all the way until it stops, then release. The latch should not retract (see figure 4).
6. Choose your new combination, write it down, then enter the new combination-depress buttons carefully (a slight click should be felt as each button is depressed).
Note: You can use one button or all five for a combination, but each button can only be used once. You can depress two or more buttons simultaneously as a step in the combination.
7. Turn the outside knob/lever clockwise once, all the way, until it stops, hold in position and make sure the latch is retracted (see figure 5).
R
elease the knob/lever.
Note: If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution.
1000/L1000 Series FAQ
Changing the Code/Combination
hope this helps
and here is the link to the change code web site
http://www.locksonline.co.uk/files/pdf/Simplex_1000_CodeChange.pdf
good luck
please take the time to rank my advice
merry christmas
Dec 07, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
COMBINATION CHANGE
No its a fixed combination from the factory,
you cant change the numbers or sequence.
Jan 28, 2009 | Sentry Fireproof Safe
Changing the combination
These sentry safes dial combinations are not built to be changed as they have no key change hole. Switching the order of the tumblers could be done by a trained locksmith. I would suggest buying the electronic sentry safes as these safes can be reprogramed.
Jan 04, 2009 | Sentry Fireproof Safe
Erased the code
FOR YOUR SECURITY THE
COMBINATION MUST BE CHANGED
WHEN THE LOCK IS INSTALLED.
position (A) (see figure 14-1).
combination change plug assembly (C)
key counterclockwise. Remove the combination
14-1).
2. Turn the outside knob once clockwise
14-4).
installations, use the factory-set combination:
(release), then 3 (release). You should
depressed.
Figure 14-2 to engage the combination
then turn the spanner wrench counterclockwise
14-3). Remove the spanner wrench.
5. Turn the outside knob once clockwise all
latch should not retract (see figure 14-4).
on page 26, then enter the new combination
— depress buttons care-fully
Dec 08, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
My master lock 1547 lock combination was changed and i cant open it
If you have the change key, you can insert into the lock and make a new combination. Only the Change Key witll allow you to change combination.
Artgirl
Jul 16, 2008 | Master Lock 5400d: Portable Select Access...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You must have the factory combination in order to change the combination that was added to the safe and the factory combination can not be erased if that is the combination you are trying to erase.
All you have to do is press program & type in the factory code 2 times & that will erase the number you created.
Then to add a new combination all you have to do is: press program followed by 5 new numbers. Then to see if they new number works, just type in the new combination & the green light should come on & you have 4 seconds to turn the handle
Apr 24, 2008 | Sentry Fireproof Safe
Home Security Logo
136 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
