Question about Dishwashers
How long does the wash cycle run? - Dishwashers
  • 739 Answers
This depends on make, model, water flow rate, age of the unit, hardness of the water, size of the plumbing, actual voltages being supplied, which 'cleaning' level selected....
Suffice it to say that your question ranks with 'Why is the sky...?
Posted on Apr 03, 2015
Long running wash cycle for whirlpool quiet partner 2
Hi there
The quickest wash cycle is the "1 Hour Wash" and is 58 Minutes long, but if your incoming water is below 120 deg. F or 49 deg. C you are looking at approx. 1H20 min.
Regards
Phillip
Mar 28, 2015 | Whirlpool Dishwashers
Samsung DMT300RFW Builtin Dishwasher will not run past wash cycle. I start it and it fills and the wash cycle starts but won't cycle past the wash cycle. No error codes.
What do you mean, it won't "run past the wash cycle"? Do you mean it stays in the wash cycle forever? Or do you mean it quits in the wash cycle and doesn't rinse or dry?
Oct 18, 2014 | Samsung DMT300RFW Builtin Dishwasher
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
My washing fills and drains properly, but will not agitate or run the spin cycle. I sounds like it is going through the cycle properly, but will not turn the drum (spin cycle) or agitator.
Try picking a different wash cycle, instead of your annual quick wash cycle opt for the longer wash cycle and then you may find that the spin cycle may kick-in, hope this works for you, good luck!
Apr 17, 2011 | GE WBSR3140DW Top Load Washer
How to get rid of the stale smell from the atf8000 front loader washing machine
first things first we need to purchase a cleaning tablet from local grocery store called affresh tablets in your laundry detergent aisle ,
then clean out filter sump assymbly in bottom corner of washer som washers have an axcess panel in the bottom righ or left hand corber uncrew filter cap and drain in to bucket or a shop vac .
clean debris out of filter and reinstall the filter screw cap in tightly ..
check your console for a clean cycle option in your wash cycles an select put one affresh tablet inside of washer drum and run cycle..
if you dont have a clean cycle thats ok select your hotest water wash cycle or sanitary cycle put one affresh tablet inside washer drum and run cycle ...
after cycle completes always leave waher door cracked open when washer is not in use ,,, reccomend running an affresh cycle once every month or if u notice stagnant water smell the more often you wash with hot water the less chances of smell
Jan 24, 2011 | Washing Machines
Hobart LXIH stuck in Wash mode after running multiple loads. Shutting off breaker for several hours fixes problem until multiple loads have been run again and then it is once more stuck in Wash mode.
How long does it stay in the wash cycle? Indefinitely? Does the display continuously show "WASH"?. If it stays in the wash cycle indefinitely (i.e. continuously shows "WASH" for significantly beyond approx. 3 minutes), it's probably a control board malfunction. If it continues to wash after the "WASH" indicator goes out, it could be a shorted wash motor relay on the relay board or a fauly control board.
If the internal rinse water booster heater doesn't reach it's programmed setpoint temperature in time, the dishwasher will run an extended wash cycle to give the booster heater more time to finish heating the rinse water. If this is what's happening, the wash cycle would last approximately 3 minutes, then it would rinse regardless of whether the booster heater has finished heating or not.
The booster temperature thermistor may be bad, giving a false booster temperature reading, causing an extended wash cycle as described above. The booster heater elements or contactor may be bad, preventing the booster heater from heating and reaching proper temperature, also causing the same extended wash cycle to give the booster more time to heat.
Jan 06, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Washing Machine not running the cycle.
What make and model is your washing machine?
Jun 07, 2017 | Miele W1903A Front Load Washer
I turn the dishwasher on normal wash and never stop washing i let it run for 2 hours and stiil running
Your dish washer probably has a "turbidity sensor". This is an infrared sensor that checks the condition of the water and adjusts your wash cycle accordingly. There is probably build up on the sensor (especially if you have hard water) and this is causing it to run so long. The easiest fix for this is to run a cleaning cycle on the dishwasher. Start your empty dish washer on a heavy wash cycle and wait for it to start filling with water. As soon as it starts to fill, open the door and pour 1/2 gallon of white vinegar into the bottom of the unit. Close the door and let it run its cycle. At the end of the cycle, run a second cycle and see if things improved. If things still are not better, you may have a bad sensor. If you have more questions, write me back. Hope this helps!
Dec 16, 2009 | Dryers
Face Clothes and Towels are smelling bad after being washed and dried in my Kenmore HE3 washer and dryer. Have tried running an empty cycle with bleach only, washed small loads with hot water, pre-wash and...
Try running an empty heavy duty wash cycle with a pint of vinegar added to the water, run wash cycle for two or three minutes then turn the machine off for thirty minutes then restart and let finish the full wash cycle
Aug 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
When the washer gets to 1 in the cycle, it doesn't stop washing.
try running the test cycle or running delicate economy in that cycle it gets up to 150 degrees in the very first cycle let it run 15 or 20 min see if the water is screaming hot it is not and Luke warm it is not heating it is most likely a control board heaters very rarely go out
Jul 24, 2009 | Bosch SHU5316UC Dishwasher
Dishwashers Logo
49 people viewed this question
Top Dishwashers Experts
