Question about RCA Televison & Video
Connected an RCA sound bar to my RCA tv an the remote control wont work anymore
At first it performed erratically and later the tv remote stopped working. The sound base works well with Bluetooth from others equipment.
    Sergeant:
  • 314 Answers
You may have situated it so it is blocking the pickup for the remote. Your remote is talking but the TV can't hear it. Make sure no part of the front is blocked by the sound bar.
Posted on Apr 02, 2015
Testimonial: "Thank you Tom:The problem was corrected taking off the batteries from the sound base remote. Apparently being the same brand, the two remotes were interfering with each other. I am now using the tv remote to control the volume in both systems and when fine tuning the sound bar, I use its remote solely for this purpose."
I have just purchased a sharp HT-SB250 sound bar to go with my sharp 32" Aquos LED tv. The item came supplied with the RCA cable and having connected it to the sound bar and the audio connections in...
You have obviously connected the sound bar's RCA (red, and white) cables to the TV's IN jacks rather than the OUT jacks, OR you might have them connected to the RCA VIDEO jacks. Check it. Connect them to the TV's audio OUT jacks. Presumably, the inputs on the back of the TV are marked "audio out", and the IN connections from your sound bar must go into the OUT inputs on your TV. I can't imagine what else it could be causing the problem.
Jul 26, 2017 | Audio Players & Recorders
My Volume and Channel button won't work and so I have bout 2 remotes, neither of them have worked, one is the RCR311BR remote which has been noted to work for this tv. What else can I do
I have a 2000 model RCA P52923 and I had the same problem occur a couple of days ago. The sound hasn't worked for a couple of years, but the TV is connected to an RCA surround sound to resolve that issue. Most recently, while watching TV, it began to start scanning channels by itself. I shut it off and unplugged it for a couple of days, but each time that I turn it on, it begins to immediately start scanning each channel. Neither the remote, nor the channel buttons on the set are able to stop the scanning, and neither of them will perform any functions, including turning the set on and off.
Any advice would be greatly appreciated.
Mar 11, 2011 | RCA P52926 52" Rear Projection Television
I Have a 5.3 IR Remote and a vizio VSB200 Sound Bar. The remote will not program to the Sound Bar. The Optical Audio is connected to the TV. What do I need to do.
lojr,
We have code to use with amplifiers, TVs, VCRs, and DVD players. I do not have a code that will work on this sound bar. What is the code you are trying to use? Did Vizio supply a code with your sound bar. They do have codes to use for their TVs to program DISH remotes. Please let me know if you have a code or you can contact Vizio to see if they have a code available.
I have provided the Power Scan instructions on programming the remote to a sound bar. Use the VCR button to attempt to program the sound bar.
If you have further questions, please post it here.
Ray Calo
DISH Network - Executive Offices
Power Scan Instructions Power Scan Instructions
1. While at the sound bar location, point the remote at the sound bar. Press and hold the VCR MODE button on the remote until all four MODE buttons at the top of the remote light up.
filestream.ashx?id=435
2. Press the RECEIVER POWER button on the remote.
filestream.ashx?id=436
3. Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the sound bar turns off. This process may take several minutes.
filestream.ashx?id=438
4. Press POUND (#) on the remote. The VCR MODE button will flash three times.
filestream.ashx?id=440(VCR button instead of TV button)
5. Press VCR MODE button, then red TV button on the remote to turn on the sound bar. Press VOLUME on the remote to confirm the remote controls the sound bar. If this does not work, return to Step 1.
filestream.ashx?id=442
Remember to press the SAT MODE button to return to the Satellite mode to change channels.
Jan 13, 2011 | DISH Network IR Remote Control
Remote stopped working so I cant use the tv what can I do I was trying to set the firect tv remote and could not get it to work. After I tried that the remote to the tv would not work anymore. I tried...
your best bet is going to be contacting rca and having them send you out a new remote alot of the universals have a 50/50 chance of having the needed frequency so I try to say away from them
hope this helped
Robb
Apr 22, 2010 | RCA RCU600M Remote Control
Gateway 450ROG audio stopped working after connecting to TV
Go into Start / control panel / sounds / and see if any drivers are showing, if not then re-install, Go to vendors site to download driver for your laptop.
Just remembered little tip, can you see the speaker at lower right of screen, if not driver may not be there especially if it was before.
Jan 20, 2010 | Gateway 450ROG Notebook
I have a rcr3273 universal remote. my tv is rca. i had the remote programmed before and somehow it became unprogrammed. i dont have the instructions anymore and i cant get it working
hold down tv button and power button together until the lcd light turns on. then press the play button every 5 seconds until your tv turns off. press reverse every 2 seconds until it turns back on. press stop to save the programming code.
Nov 09, 2009 | RCA Universal Remote Control
Remote Control wont Work
I cant seem to program my RCA universal remote to my emerson tv
May 28, 2008 | RCA Universal Remote Control
TV won't change channel
child lock is actvated
Jul 16, 2007 | RCA F27450 27" TV
Televison & Video Logo
73 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
