Question about LG Dryers
Can I change my LG Tromm dryer to electric with a conversion kit?
  • LG Master
  • 2,374 Answers
Nope
Posted on Apr 04, 2015
LG Tromm electric dryer model DLE5977B is making an extremely loud humming noise.
Humming is caused when the slow start capacitor on the motor fails. Better to buy a new dryer as the motor is usually around $160. Yours is $145. I suggest you take professional advice on such a high outlay rather than risking the advice of someone who hasn't physically checked the machine. I have two pro dryers in my hotel fail, and they buzzed.
LG Dryer Model DLE5977B Parts
Feb 02, 2017 | LG Dryers
How do you get lg tromm dryer belt around drum and idler pulley
Lisa, Check the attached links, video shows how.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dryer Belt Replacement LG Electric Dryer Repair Part 4400EL2001A
How to Change the Drive Belt on an LG Dryer DLG3788W
Mar 08, 2016 | LG Dryers
Can I change my LG Tromm gas dryer to electric with a conversion kit?
The short answer is no, at least not economically. A hard case tinkerer could probably do anything, but the two dryers (gas vs. electric) have to have internal designs of the heating mechanism so different that there is not a conversion 'kit' that could be made that would do the job at a price much less than buying a new dryer.
Apr 02, 2015 | LG Dryers
Lg tromm electric heater has no heat
check ur heater element, the hi limit and the thermal cut off fuse.
Aug 27, 2014 | LG Tromm Electric Dryer
Loud banding noise in my LG Tromm DLE7177
Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Feb 11, 2013 | LG Tromm Electric Dryer
I have a LG Tromm DL62524W my dryer no longer is getting any heat , and on the settings it says its on the cooling setting and I tried to change the settings.
It's possible that the high limit switch has failed and needs to be replaced. You will need to tear down the machine to get to it.
Good luck
Jun 16, 2011 | LG DLE2532W Electric Dryer
My LG tromm dryer wont heat and i don't know how ignite the pilot
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 02, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Gas Dryer to use Propane vs natural gas
The difference between a natural gas appliance and a propane one is basically the gas nozzles. For example if you have a gas stove and you lift up the top, under the burners are the small gas nozzles. The problem is there are no standard when it comes to these nozzles. In other words they are not interchangeable form one brand (Whirlpool to LG) to another or from one type (washer to furnace) to another. What you can do is contact you locale propane dealer and ask them if they have any suggestions. Also look on line for sites that may offer conversion kits like RV dealerships.
Hope this helps.
Sep 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
NO it is not normal if it is only that old ....I would Call LG service it will still be under Warrty..(unless you are drying ball bearings)
Good Luck
Feb 16, 2008 | Dryers
Dryers Logo
63 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
