Question about Kitchen Appliances - Others
I need pans - Kitchen Appliances - Others
    Top Expert:
  • Kitchen Appl... Master
  • 52,047 Answers
Suggest contact the maker of the unit and get them there
Posted on Apr 02, 2015
How to replace a oil pan gasket 2004 nissan xterra
are you referring to the lower sub pan or main oil pan? the lower sub pan on most nissan engines are fairly easy to diy. just unbolt all the fastening bolts and you would need a pry bar or screwdriver to pry off pan. remove the old liquid gasket on pan and on main pan mating surface and reapply liquid gasket. reinstall lower sub pan and install fastening bolt.
if you are referring to the engines main oil pan its a more extensive repair. you would need the correct tools and equipment such as trans jack and engine support holder.
Oct 11, 2014 | Cars & Trucks
How to change oil pan 1995 GMC vandura3500
I am guessing this is just like all vehicles and the oil pan is directly underneath the engine. You will need to buy a a new oil pan gasket and if you are replacing the pan, another pan. Take the bolts off the pan making sure that you allow the oil to drain out into a waste container. Once you get all the oil out, you can take the pan off. Scrape off any old gasket parts that might have stuck on the engine. Use some gasket glue and reattach the new gasket and pan. I would find out what level of torque you need for the bolts and use a torque gauge to tighten the bolts. Add oil and drive.
Oct 01, 2014 | Vehicle Parts & Accessories
Where do I check the transmisson fluid on a 2006 cobolt
The 2006 Cobalt does not have a dipstick check tube at all. It is normally a non-serviceable component unless there is a leak. When the pan is removed, for service you would normally add 6.9 US quarts to the transmission. I will paste the GM instructions for servicing the pan below.
2006 Chevrolet Cobalt
Automatic Transmission Fluid Filter and Seal Replacement
Tools Required:
• J 6125-1B Slide Hammer
• J 23129 Axle Boot Remover
Removal Procedure
1. Raise and support the vehicle.
2. Place the drain pan under the transaxle oil pan.
Notice: When removing the oil pan bolts, be careful not to damage the oil pan sealing surfaces. Such damage may result in oil leaks in this area.
3. Remove the oil pan bolts from only the front and the sides.
4. Loosen the rear oil pan bolts about 4 turns.
5. Lightly tap the oil pan with a rubber mallet or pry in order to allow the fluid to drain.
6. Inspect the fluid color.
7. Remove the remaining oil pan bolt
8. Remove the oil pan.
9. Remove the oil pan gasket.
10. Remove the oil filter. Use a long screwdriver in order to pry the oil filter neck out of the seal.
11. Check the oil filter seal for damage or wear.
12. As needed, remove the seal using the J 6125-1B and the J 23129 .
Installation Procedure
1. Install a new seal, as needed. Before installing, coat the new seal with a small amount of J 36850 or petroleum jelly.
2. Install a new filter into the case
3. Install the oil pan gasket. Use a new gasket if the sealing ribs are damaged.
4. Clean and dry the oil pan. Inspect the pan for damage and replace the pan if necessary.
5. Install the oil pan.
6. Clean and dry the oil pan. Inspect the pan for damage and replace the pan if necessary.
7. Install the oil pan.
8. Install the oil pan bolts.
Tighten
Tighten the bolts to 10 N·m (89 lb in).
9. Lower the vehicle.
10. Fill the transaxle to the proper level. Refer to Fluid Capacity Specifications .
11. Inspect the pan for leaks. Recheck the transmission fluid level. Refer to Transmission Fluid Checking .
Apr 27, 2014 | YouTube Videos
Is transmission fluid pan accessable from underneath car?
Yeah, that's how it is done. Use jackstands or blocks under car. Raise enough that you can work comfortably underneath. The pan is on the very bottom of the transaxle. Loosen all pan bolts a turn or two, then remove bolts from one end, letting pan start lowering, catch fluid with drain pan. When fluid level in the pan gets low, finish removing all pan bolts, and pull the pan off. Filter is right there underneath the pan.
Dec 27, 2012 | 1995 Ford Escort
How do I change the transmission fluid and filter? 1999 GMC Jimmy 4wd
Its not really that hard. You just need to take your time and a very large pan. Your filter is just in side the trans pan. The pan will have to be dropped. A ratchet and socket will make short work of it. Just undo the bolts on the trans pan( undo 3 corners and the bolts on that side, allowing the pan to lean to drain some of the fluid). Hold pan steady, and undo remaining bolts. Lower the pan. Now its time to scrape the old gasket off the pan and trans case. Please clean to metal, don't want leaks. Remove the old filter, and replace with the new one. Install the gasket to the pan, and bolt the pan back into place. If you put 4 bolts from around the pan, makes it easier to put the rest in. Now to refill the trans, you need a funnel and add the fluid ant the dipstick. Bring it back up to level. This job will take a beginner about one hour. Hope this helps
Jan 02, 2011 | 1999 GMC Jimmy
I have a Toastmaster bread and butter machine, model 1195. Need to know what size the bread pan is.... 1, 11/2 or 2 pounds, its not written anywhere on the appliance. Also, I need to replace the bread...
Bread pan Capacities
Here is how you determine the size of loaf you can bake in your machine. You need to determine the capacity of your pan. Fill your pan with water and measure the cups added so you know how many cups of water are in the pan when it is full to the very top. Here are the conversions:
1)If your pan holds less than 10 cups of water you can make: a 1 pound loaf
2)If your pan holds 10 cups of water you can make: a 1 pound loaf and a 1.5 pound loaf
3)If your pan holds 12 cups you can make: a 1 pound, 1.5 pound, and a 2.0 pound loaf
____________________________________________________________________
This is rare, but if you pan holds 14 cups or more you can make all the above plus a 2.5 pound loaf
FROM ANOTHER SITE:
To find your bread machine pan size:
Fill the bread pan with water and measure it out in cups
Less than 10 cups of water = 1 pound
11-13 cups of water = 1 1/2 pounds
More than 13 cups of water = 2 pounds
You don't need the bread pan cover unless you are making butter. If you are making bread you should always leave it off or it could melt from the heat of the baking cycle. The butter cycle doesn't use heat. Please rate this answer with testimonial/vote/rating etc Thanks!
Dec 28, 2010 | Toastmaster Kitchen Appliances - Others
Won.t shift into grear, how do i replace the tansmission filter?
TO DO A TRANSMISSION FLUID CHANGE YOU NEED HAVE TRANSMISSION FLUID ON HAND YOU NEED TRANSMISSION FILTER AND GASKET.YOU NEED 3/8 WRENCH THE RATCHET TYPE WITH METRIC SOCKETS. YOU NEED JACK TO RAISE VECHICLE SUPPORT VECHICLE ON JACK STANDS.YOU NEED A DRAIN PAN. ONCE YOU GET VECHICLE OFF GROUND.PLACE DRAIN PAN UNDER TRANSMISSION OIL PAN REMOVE OIL PAN DRAIN BOLT.LET FLUID DRAIN OUT IN DRAIN PAN THEN SCREW DRAIN PLUG BACK IN PLACE DONT OVER TIGHTEN.REMOVE OIL PAN AND GASKET. BESURE TO HAVE PAPER TOWEL ON HAND.MAKE SURE TRANSMISSION OIL PAN GASKET SURFACE CLEAN BEFORE INSTALLING NEW PAN GASKET. ONCE TRANSMISSION OIL PAN REMOVED. REMOVE THE OLD TRANSMISSION FILTER INSTALL THE NEW FILTER.THEN WITH NEW GASKET ON OIL PAN IN PLACE.OIL PAN NEED TO BE CLEAN SO THE GASKET ADHESIVE WILL HOLD PAN GASKET IN PLACE WHILE INSTALLING PAN AND GASKET TO TRANSMISSION.INSTALL OIL PAN BOLTS INSTALL THEM CRISS CROSS TORQUE PAN BOLTS TO 7 TO 10 FT LBS. LOOK IN OWNERS MANUAL FOR TRANSMISSION FLUID CAPACITY.BUY 10 QUARTS .TO BE ON SAFE SIDE SO YOU WILL HAVE ENOUGH FLUID ON HAND. IF YOU DONT HAVE NO TRANSMISSION FLUID CAPACITY. ADD 7.5 QUARTS FLUID.WAIT FOR 2 MINUTES.CHECK TRANSMISSION FLUID LEVEL ON DIP STICK. SHOULD BE ON THE FULL MARK.CRANK VECHICLE UP.LET IDLE FEW MINUTES CHECK TRANSMISSION DIP FLUID LEVEL IF DROPPED ADD LITTLE MORE.WHILE ENGINE IDLING GETTING WARM UP. KEEP EYE ON FLUID LEVEL.WHEN FLUID LEVEL STOP DROPPING. APPLY BRAKES HOLD FOOT ON BRAKES SHIFT THROUGH ALL GEARS TWO TIMES. THEN CHECK FLUID LEVEL SHOULD BE ON FULL MARK.CHECK FOR LEAKS WHILE ENGINE RUNNING.
Nov 19, 2010 | 1996 Ford F250 Crew Cab
I need to replace the oil pan in a 2001 dodge neon. Is this a DYI job??
Do you need to replace the oil pan it self or just the oil pan seal? This can been a DYI job, depending on your experience working with cars. You will need a your basic tools. (Jack Stands, Jack, Oil Container, wrenches and sockets, new oil and filter.) The first thing you will need to do is drain the oil. This is a good time to change your oil since you will be taking the oil pan completely off.
Steps to removing oil pan
1) Set car on jack stands or ramps in order to work under the car. (Be Safe, Be Smart!)
2) You will need a wrench or socket to remove oil drain plug and drain the oil out of the car
-This is a good time to change your oil, so replace oil filter as well.
3) Once the oil is drained you can take of the oil pan off. Most oil pans are just bolted. Not to hard to take of.
4) Once off this is a good time to clean the oil pan if your just replacing the gasket. Do not use lubricant cleaners like wd-40. Brake cleaner has worked for me, you can also ask your local auto shop or autozone for a good cleaner.
5)Replace the oil pan with new gasket making sure there are no tears in gasket and it sits well between the oil pan and engine block. (Make sure there is nothing in the oil pan as well that could cause harm)
6) once you replaced the oil pan its just as simple as putting oil back into your car like you are changing your oil.
Nov 02, 2010 | 2002 Dodge Neon
There's a big dent in my oil pan; it's not giving me an accurate reading on the stick. The stick says that it is over full by a quart when actually it is a quart low. and the pan also appears to leak. I...
I'm not sure the year and make of this car, but if its a newrer buick then its not to hrad to replace the oil pan, jack the front of car up and support it with jack stands, then remove the oil from pan. remove the bolts holding the pan, pan should drop down, you may have to tilt back and wiggle out, also you may have to drop the pump or pickup screen depending on how much room is needed to remove the pan.
Aug 16, 2010 | Buick LeSabre Cars & Trucks
Need to change the transmission filter
get your self the right tools, the filter, transmission fluid, gasket, gasket silicon, a good wide drain pan, clean rags, some cleaner to clean out the pan like brake parts cleaner. first find the transmission pan. once located undo the bolts around the pans flange or use the drain plug to drain all the fluid. if it doesnt have a drain plug then you have to take off the pan to drain it, messy! once the pan is off you should be able to see the filter and swap it out. clean out the pan, pan magnent, put your new gasket on and use some silicon, bolt it back on. fill the trans back with new fluid. this is straight forward approach. and dont mix the oil pan with the trans pan. the oil pan is under the motor( if that helps) let me know if you need any help or you dont understand something, thanks
Nov 07, 2009 | 1998 Honda Accord
Kitchen Appliances - Others Logo
559 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
